Question about Whirlpool Duet GHW9150P Front Load Washer
Washer wont drain
It says F 02 and we have checked everything the manuel says but it still wont drain
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Remove the bottom panel and clean the drain filter.
Posted on Dec 06, 2012
Wont drain
This is a very common issue on these units, you an fix it yourself! The link below provides a video that explains how to clean the drain pump its the most common issue on this unit and it can be completed in several minutes.
http://www.appliancerepairlesson.com/2010/11/02/washer-wont-drain/
Good luck with your repair!
Mar 04, 2011 | LG WM2487H Front Load Washer
F2 code is on, wont complete the spin cycle, try to reset with cancel and goes to 12 minutes, what is wrong with it?
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Keep in mind it is cold winter and the drains could be frozen or slow in the western hemisphere.
More here
Dec 20, 2010 | Kenmore Washing Machines
My Kenmore HE3t is flashing F02 and wont spin...what can I do.
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 19, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet washergets a code 2 when it gets to spin cycle.wont rinse and spin
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washer drum wont spin.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 29, 2010 | Kenmore HE2 Plus Front Load Washer
02 sonata wont start. the fuel lineoff @ the
theres a fuel pump relay in the power distribution box under the hook you manuel should tell u wich one
Feb 12, 2010 | 2001 Hyundai Sonata
I get the error code S02 on my Duet washer. It
02 is a slow drain,
yopu can check your pump
take off the back wall and hoses,, have towels ready
you will loose water,,
inspect the inside of the pump and all hoses
Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kepp getting a code f 02 then washer wont do
Open the bottom panel (3 screws on bottom) then you should see a drain clean-out. Unscrew that, there is probably something stuck in there. Have a pan ready to catch the water when you un-screw it. Good luck
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3 washer- 1 year old
Have you followed all the instructions on this link?:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If all you have checked is the drain hose, you need to check the drain pump reservoir and the drain hose PRIOR to the pump (coming from the bottom of the wash tub). Rugs are notorious for collecting and holding large amounts of dirt. This dirt will pack together in the drain lines and pump and clog it up. I hope I'm not too late with this post. I was hoping to save you some money. Let me know if the helps.
Jul 21, 2008 | Kenmore Elite 45986 Front Load Washer
Washer will not leave the drain cycle
Press PAUSE/CANCEL twice to clear the display then
It's because of a Long Drain condition. If the drain time exceeds 8 minutes, the water valves are turned off the code is flashed.
But Note: After 4 minutes the "Sud" error is usually displayed, then 4 minutes later the error code is displayed.
Jan 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
