Question about Acer Aspire 5100 Notebook
Right touchpad button not working...
What would be the "right click" of a mouse isn't functioning for my Acer Aspire 5100 touch pad. I recently reformated the laptop - about 2 months ago but this problem started about 24 hours ago...
How do I turn off the touch pad on my Acer Aspire 5742 laptop
Thank you for using fixya. My name is Carlo.
There are two ways that you can do to turn off/on the touch pad in your acer aspire.
1. Press FN + F7. It will turn off the touchpad and will turn on once you press the same buttons again.
2. If the buttons do not work. You can do this:
1. Go to control panel>hardware and devices>Devices and Printers>Mouse
2. CLick on the last setting on the right.
3. Click on Disable in the Mouse Properties.
5. Click OK.
Just go to the same area when you want to enable your touchpad again.
I hope this helps.
Carlo
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Mar 01, 2011 | Acer Aspire 5742 Notebook
Acer aspire 5517 touch pad not working.
Also on this laptop you can hit Fn+F6 to enable or disable the touchpad as well there should be a touchpad disable button to the right of the power button that can be very easy to accidentally press.
Mar 15, 2010 | Acer Aspire 5315 Notebook
Hi.my touchpad don't work at all!!I can't do anthting with my touchpad.
The pad may be defective buy a cheep wireless usb mouse for it and use it to work without the pad. the pads do wear out and the replacement would be over a 100 Bucks.
Jan 15, 2010 | Acer Aspire 5100 Notebook
How do I turn the synaptic touch pad off on my acer aspire
This should be an easy fix...after many months of trying to disable touchpads on machines that did not have the one button disable feature either in the control panel or on the touchpad itself I discovered it was one of the function keys.
Press function (FN) and the "F7" key...press again to re-enable. Good luck!
Dec 21, 2009 | Acer Aspire 5100 Notebook
Acer aspire one touchpad right button not working
you can try using the function key ( fn ) and the touch pad key on my acer it is the F7 key hold the fn key and press and release the touch pad key that will turn the touch pad mouse off and on also goto control panel / mouse and try switch primary and secondary see if that will make the right button work if not its probly hardware related and your best bet is to keep the external mouse going rather than fixing that one
Mar 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Touchpad on acer aspire 5100 series is locked
plug in a usb mouse, go to control panel>system>harware>device manager and click on the + sign next to pointing devices. Right click the touchpad and click on uninstall. Reboot the laptop and unplug the usb mouse. This should pick up the touchpad as new hardware and reinstall it. Hopefully this will resolve the problem.
Dec 29, 2008 | Acer Aspire 5100 Notebook
Not working right click of touch pad of Acer Aspire 4710z
Hey!
What operating system are you running? All I could find was a manual for your model: http://tinyurl.com/6gc7pl
If you are using Windows XP, you might try going to Control Panel -> Mouse -> On the first tab (Buttons) check "Switch primary and secondary buttons." then hit "Apply".
Try left-clicking (currently assigned to be the right-click) on your Start button and see if the menu with "Explore All Users" on the very bottom opens. If it does, then your touchpad is most likely defective and would have to be fixed (www.fixmyacer.com). If the menu doesn't come up, then it is a software issue and is 100% fixable.
Matt Newelski
www.newelski.com
Dec 08, 2008 | Computers & Internet
Touch pad
go to my computer, right click, properties, device manager, look down list for mice and pointing devices, click '+' sign, you will see your touchpad, right click select uninstal, then restart notebook it will reinstall itself and should be working as normal.
Sep 03, 2008 | Acer Aspire 5100 Notebook
THE 4-way scroll button IN MY ASPIRE 5100 DOESNT WORK
Double click the icon in the toolbar. Click the device settings tab and then hit setting. select buttons in the list on the left side. Hit the plus sign(maximize) and select scroll up button action....scroll down button action...Etc. For each action select what you want it to do and just hit apply and move to the next. Once you have selected the action for scroll up, down , left, and right hit apply again just to be sure and try it. It should work. I just did it on my 5630 but Im assuming it works the same.
Aug 14, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
189 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
