Question about Refrigerators
GE refrigerator fan starts and stops
Fan slows then speeds up
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the complete model number of your unit?
Are you talking about the fan in the freezer?
Posted on Dec 06, 2012
3 Suggested Answers
SOURCE: GE model GSS22SGRBSS freeser fan slows down
Same problem and think this unit is a piece of JUNK. In 5 years of service i have had to replace the Water shut off Valve twice, and the heater located on the bottom of the freezer which helps to keep the freezer defrosted. The fan has a whistling sound constantly, within 2 days of putting something in the freezer it is full of ice. Sorry pal, but as I said this model is a piece of junk.
Posted on Mar 25, 2010
  • 1416 Answers
SOURCE: My 1998 GE refrigerator condenser fan keeps
A common question on on our site is about different fan sound that happen and the causes. These noises are often fairly easy to fix and some are the result of other problems.
If you are hearing a rattling sound or a squeaking, high pitched squeal coming from the bottom or back or the refrigerator then the condenser fan motor is probably going bad. Sometimes the bearing in the fan motor will even get so bad that the fan blade will start to hit anything that is close to it down there. This can create a very loud noise. This fan normally will be running when ever the compressor is running also.
As with any other problems you will want to get these things fixed promptly. If the problem is just a squeal a bit of light motor oil will do wonderful things for you. Many times though, you will have to order the parts needed to fix the problem. When repairing the problem make sure to remove all power the the unit and to wear gloves is possible, as there are many sharp edges in close quarters that will butcher you hands in no time.
The other fan that can cause sound is the evaporator fan. While this fan too can get worn and become noisy, it also can sometimes start to hit ice that is building up because of a problem with the defrost system of the refrigerator. Checkout my tips about defrost problems if you find a build up of ice and the fan is hitting the ice and making noise. This fan can also be oiled if needed, and it will also wear out and need to be replace occasionally. This fan usually will go off when the door is opened, so sometimes it makes it difficult to figure out exactly what is happening. By holding the door switch in manually, you can get the fan to run and troubleshoot it more easily. Make sure to remove all power before trying to service the fan. Spinning fan blades do not play nice with your hands!
For many refrigerators you will have to remove some covers or even the whole bottom of the freezer to get to this fan for replacement. Checking the exploded views at appliance parts websites can give you an idea of where the fan is located and what must be removed to get to it for replacement.
Both of these fans and the associated parts are available for most refrigerators online. Look for them at the appropriate spots in the exploded views of the units.
Good luck and thanks for using fixya.
Posted on Jan 19, 2011
GE Profile Side-by-side Refrigerator TFX28PBBABB
Most ge have a Multispeed fan control on board. But if you had to start the fan with your hand, I would guess it would be a fan issue
Sep 08, 2012 | GE Refrigerators
My side by side ge refrigerator model gss20iepjcc make a holling sound. it is caused by the fan motor in the freezer slowing and reving up constantly. what is the solution to this problem?
Normally this fan is silent in operation, and does adjust it's speed dependent on temperature requirements.
However - if it is on all the time, thee may be a fault with either the sensor or temperature control (main) board.
If the sound does actually stop for intervals - just buy a replacement fan, as the bearings may be corroded enough to make it noisy.
You can replace this as a DIY fix if unplugged, and the back panel removed.
Mar 02, 2010 | GE Refrigerators
My frig is starting to send a sound that is similar to wind blowing (I guess from the motor)
The board that runs the functions of your refrigerator is going bad. The fan is pulsating. Slowing down and speeding up. The noise will eventually go away and the fan will stop running and you will think the fan is bad but it is the board. wr51x10656 at about a cost of 160. to 180.00. Easy to do your self but follow instructions that come with board. It is located on the back of the refrigerator behind a metal plate. Good luck and thanx for using fixya.
Feb 27, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Sounds like heavy breathing
The # 5 thermistor , pt # WR55X10025, located at the bottom of the freezer , slightly in front of the drain , with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , and is associated with the fan speed . The " breathing " sounds like the fan speeding up and slowing down . Replaceing this thermistor , should fix the problem .
Jan 20, 2010 | GE Refrigerators
GE refridgerator fan speed changes constantly
I will try to answer your question . Your refrigerator had 3 thermistors in the refrig side , and 2 in the freezer side . These thermistors , send resistance messages to the main control board , mounted on the back of the refrigerator . If say #1 thermistor tell the board , I need to be colder , then the board will tell the damper ( small vent in the top of refrig section ) , to open . If the #2 thermistor tells the board , I need to be colder , then the board tells the fan to speed up , to get more air to the refrigerator section . #3 thermistor , works with the turbo cool switch , turning the fan to a high speed also . If the thermistors tell the board , we're all fine , then the fan will slow down , but still circulate to make/keep the freezer colder . If the freezer thermistors say , we're ok also , then the refrigerator will cycle off , until a thermistor asks to be cooler again . The fan works off D C voltage , in which fan speed is regulated (faster or slower) , by the thermistors "talking" to the control board .
Sep 12, 2009 | GE Refrigerators
Slow condenser and evaporator fans on SDL20KCSABS
Newer GE refrigerators use variable speed DC fan motors to improve energy efficiency. Fan speed is determined by the electronic control board. Your refrig is working as designed.
Please don't rate solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Mar 03, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
Fan in Freezer surging??
Replace evap fan motor. Should be a white plastic housing made by Panasonic.
Jul 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSL25JFR Freezer fan noise.
It is very common for the fan inside the freezer to develop a loud noise as it runs. Its in an environment that is hard on them, cold, wet. Its a small and simple motor, and you are right in believing there will be more problem in the future, as the stator is probably touching the housing. It has a sleeve type bearing, and its probably worn a little causing the shaft to wobble. Eventually it will stop completely and the freezer will get warm.
Mar 07, 2008 | GE DSS25KGT Side by Side Refrigerator
Ge profile artica refer fan speed PSS29NHPBWW
hmmmm no thats peculiar it will slow down and start back each time the doors are open also fan will turn on even if fridge is turned off if a door is opened londer than 3 mins. If the fan still operates irradicly even in the liner protect mode (turn refrig off open door for 3 mins, fan turns on) then the main board is faulty not uncommon for these refrigs.
Sep 28, 2007 | Refrigerators
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
