Question about GE JKP15 Electric Single Oven
GE JKP14 WOP1WG Electric single oven, how do I replace the bottom igniter and where do I get a new one?
aborcass
  • 2651 Answers
SOURCE: F3 Error Code - GE Electric Oven JTP18
all ge codes f3 are saying ot replace thermal sensor, you can check the harness connecting them for a pinched or burnt wire i guess, as far as getting a part number , you can enter complete modle number her e and look for the sensor, i checked just the partial number you gave and a few different ones showed up
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 23, 2008
SOURCE: GE OVEN SINGLE ELECTRIC JKS05BW
I have the same problem. Mine is a self-cleaning oven. But I'm just preheating it 450 and it did it. Then this AM it did it while broiling.
Posted on Aug 24, 2008
  • 108 Answers
SOURCE: ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Posted on Nov 11, 2009
  • 476 Answers
SOURCE: GE single electric oven is indicating an f8
The F8 in a GE electric oven can be a bad ERC unit, check the following link read some more about the fault codes and "probable" causes: http://www.repairclinic.com/0078.asp. Good luck!
Posted on Feb 10, 2010
  • 3 Answers
SOURCE: GE JT930 Electric Single Oven Problem not working
power controller board inside control panel upper right side, normally gets trashed with power surge from utility company power issues
Posted on Mar 26, 2010
Our GE JKP14 Oven's Burner Element caught on fire. A small bit of it. Turning the oven off did nothing, but once we turned off the circuit breaker the fire instantly went out.
call in an electrician as turning off the switch should have stopped the fire
There may be a problem in the way it is wired up.
Apr 07, 2015 | GE Ovens
Tip
Replacing igniter
GE wall ovens have panels for regulator and ignitor wiring at the lower back of oven. remove all screws and plates to expose wiring. clip off defective igniter and use ceramic wire nuts to fasten new one. re-assemble.
I learned from local gas company that igniter is most frequent part to replace.
cost = $35
GE technical support = non-existent.
power of the internet - priceless!
on Jun 18, 2008 | GE JGRS14 Gas Single Oven
Oven wont light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 15, 2010 | GE Profile JTP18 Electric Single Oven
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
The igniter was bad i replaced it with a new one (seemed simple enough) but when i put it on broil or bake the igniter doesn't turn red, is there something i'm not doing?
The igniter is in 'series' with the gas coil that operates the gas valve. The gas coil is probably bad. You can replace the coil not the whole valve. Go to repair clinic.com and put in the model number and they will have it.
Nov 06, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
I have GE propane range #JGBS23WEH4WW , oven///solar
No, the gas valve for the oven is electric and requires a complete circuit (ie; igniter, sensors, etc) in order to operate
Feb 15, 2009 | GE JGRP17 Gas Single Oven
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Bottom burner not working
check the fuses in oven also check cartridge fuses in fuse panel also look for a burn wire.
Mar 06, 2008 | GE JKP15 Electric Single Oven
GE JKP15 Electric Single Oven Logo
98 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
