Question about Canon SELPHY CP780 Thermal Photo Printer
Canon celphy cp780 paper feed
This printer has just started having problems feeding paper. Have tried using compressed air to blow off the rollers, but no resolution ... paper is not drawn in.
  • 6 Answers
SOURCE: Canon PIXMA MP600 printer - paper feed
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
The above illustration shows a PIXMA MP500
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
Posted on Jun 12, 2008
SOURCE: Paper Feed Problem
Hey I had this problem too for about 6 months. Just press the "Feed Switch" button under the main display to switch it from feeding from the tray under the printer.
Posted on Oct 22, 2008
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Posted on Nov 10, 2009
  • 117 Answers
SOURCE: paper is not being picked up by 'feed rollers'
please folow steps to fix your issue
Turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
Hope it can solve your issue
Thanks for using Fixya
prakash
Posted on Mar 23, 2010
SOURCE: Paper wont feed into printer no paper jam
In the comments section Blumm suggests pushing a piece of cardboard (like the back of a legal pad) through the feeder as far as you can. Turn the printer off and then on again with it in there. Pull the cardboard out and check for any foreign objects that have been pushed through.
It worked for many people including myself - I got a piece of plastic and it works wonderfully again!
Posted on Jul 31, 2010
What is code error e03
Printers & Copiers
Code error E03
Nov 14, 2014 | Office Equipment & Supplies
Printer won't feed paper through
Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the back, by opening the rear door.
Be sure there is no paper or debris hidden anywhere. Open up the rear door and use a flashlight to explore the inside. If you see any paper, have patience in trying to remove it, now gently pull using a side to side motion. If you use a tool for assistance, like a pair of tweezers, or pair of needle nose pliers, put some tape on the jaws of the pliers to help prevent the shredding of the paper.
Another good item to have handy is a can of compressed air. This can be used to blow out any built up dust or fine paper particles that may be embedded inside the printer and the sensors after much use.
Reboot your computer
Try cleaning the paper sensor and rollers
The sensor can be located by opening the front cover where the ink cartridges are. While looking inside just to the right of center manually feed a piece of paper like the printer does automatically. You should see a thin black lever move up and down as you push the paper in and pull it out repeatedly.
This is the paper jam sensor. ANY foreign object in the way of this sensor will cause a three orange light flash indicating a paper jam. Very hard to find without a flashlight. Another good idea would be to blow out the printer using a can of compressed air.
Clean the two Rollers Lightly dampen your lint-free cloth with water or alcohol. Squeeze it out to ensure that it's not too wet. Hold the cloth in one hand and press it lightly against the first roller. With your other hand, gently rotate the roller until you have cleaned it all the way around. Be extremely careful. Do not use too much pressure. You might have to run it through a few times to remove all of the residue
Or Still having Problem Then follow Us For Canon Printer Support
Mar 19, 2014 | Canon Pixma iP6600D InkJet Photo Printer
The paper gets stuck on one side and will not go through the printer
There's probably a tiny bit of paper stuck somewhere in the paper feed path. To start with, open all the covers that can be opened and inspect for debris. You could try using a can of compressed air, to blow out any junk you find.
Failing this, the printer may need to be disassembled and inspected for broken gears, pickup rollers, etc. That's not really a DIY job, so you may wish to consult your warranty.
Feb 28, 2011 | Canon PIXMA MX310 All-In-One Printer
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Roller Cleaning is completed.
Sep 06, 2009 | Canon PIXMA MP190 All-In-One InkJet...
I have a cannon mp 240 bought it 7 months ago have barely used it, just purchased 1st set of ink cartriges. have printed maybe 4 pages since replacing.. Now says out of paper, wont feed sheets in. help!!
Check the rollers that feed the printer paper through. Use compressed air to clean out the printer and rubbing alcohol on the rollers once you clean them. If the rollers aren't grabbing the paper, then maybe a gear is not working properly.
Canon offers a one year warranty, take the printer in and get them to service it instead of trying to fix the problem yourself.
Sep 01, 2009 | Office Equipment & Supplies
Paper Jam
Open up the doors and blow some compressed air throughout the paper path (where the paper travels up). Make sure to blow air onto the sensors, because paper dust can coat them, causing false jams.
Does the paper get out of the tray at all? There is a feed roller that feeds the paper up into the machine; if you remove the paper tray you can see this roller -- it's big and gray and has grooves across it -- above where the paper sits toward the front of the printer. Blow air onto this roller as well, and if you have either D-ink or a rubber rejuvinator, clean the roller with a lint-free cloth.
Also make sure the paper is snug in the tray and not bent or crooked.
Feb 03, 2009 | Ricoh Aficio AP410N Laser Printer
I have a canon pixma pi1800 i will not take the paper... it keeps saying paper jammed!! i tried cleaning rollers etc... tried printing a test shhet.. it says printing finished but i hadnt done it as it...
Here's a few things to try :
1. Blow it out with compressed air blower .especially the rollers and the paper feed area make sure there are no bits of paper or dust in the paper feed area and in the front access area that could be causing the jam.
2. Verify that the cartridge carriage moves to the service area when the front door is opened (as if to change tanks)
3. Verify that the timing belt, drive belt, gearing and rollers all look normal.
4. With the computer off, unplug the printer's power cord and USB cord for about 3-5 min
after plug it back if the problem still persists then move to the next step
6. Completely uninstall the printer's driver and software. Then reinstall the printer's drivers only.
Retry after each step.hope this helps
Jan 17, 2009 | Office Equipment & Supplies
My PIXMA iP6210D is feeding paper incorrectly
ok look for anything that might have fell in to it..if the paper feed area is clear check the rollers for paper that might have not cleared or dust build up ...if its just dust build up get a can of compressed air and try to clear it you might want to also try to use a vacum to clean it also...good luck and let me know it if this doesnt help there could be other things to try...
Nov 04, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Paper Source
ASF
Cassette
May 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon SELPHY CP780 Thermal Photo Printer Logo
146 people viewed this question
old marine
old marine
