Question about Kitchen Ranges
How do you replace oven control electronic range control for Kenmore model 91130169792
We called a repair man out and he said it was the electronic control panel(part WB27T10268) that needed to be replaced. Was going to charge 170.00 for part and 180.00 for labor. I can do it myself if I have directions. Please help
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
OK, this is a simple job for you to do yourself. First, be sure to unplug the unit before making the repair. To get to the control board, remove the end caps on the display and then remove the overlay. The control will be held in with 4 screws. Be sure to take not of the wiring connections! I always take a picture of the connections before I remove any of them. Here is the part to order.
Here is a diagram of the unit.
The part comes with a 365 day, any part, any reason return policy.
Posted on Dec 05, 2012
hotuna
  • 288 Answers
SOURCE: my control panel for the oven does not work(press buttons w/ no response
If the LED display is blank, then you have a power problem. first make sure there is power to the appliance. If you can determine this, then check the transformer on the control module. All these things require some familiarity with electronics and electricity. Depending on you is how to handle this.
Posted on Dec 01, 2007
jyackle5
  • 8197 Answers
SOURCE: kenmore range control panel not working
sounds like the control board blew on you replace it.
Posted on Dec 16, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag MGR5775QDS Gas Range Control Panel Problem
sure you can relace yourself, the part number, if you dont already have from previous repairs can be obtained fromthe sears website, or by calling manufacture direct. as far as a schematic there should be one located behind the range.
Posted on Feb 21, 2009
rylee_smith
  • 8619 Answers
SOURCE: F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 10, 2009
jsrock516
  • 5911 Answers
SOURCE: How to replace the electronic oven control on my Kenmore range
If the Electronic Oven Control (EOC) requires replacement, the following link gives you step-by-step instructions on how to replace one:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
This is not a difficult repair, but if you have questions, or require additional assistance, please post back and let me know. I hope this helps you.
Posted on Jan 10, 2010
Gas oven on Kenmore range model 362-75191890 went off midway through roasting Thanksgiving turkey. There seems to be no gas getting to the oven burner, even though the range top burners fire up nicely.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Kenmore Kitchen Ranges
Kenmore Electric Double Oven Mod 9114832592992 got F2 code in middle of selfclean what do I need to fix?
Hi, i found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
OR....
F2 Oven temperature sensor shorted Replace oven temperature sensor
OR
F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
Oct 26, 2010 | Kenmore Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Self-cleaning oven F2 error message
Well I found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
OR....
OR
Feb 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Jan 10, 2010 | Kenmore 92022 / 92024 / 92025 / 92029...
Error message on Kenmore oven
F-1 is not good. It basically means the EOC (electronic oven control is bad). There is a little test here for a little info:
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Electric oven 91141065791
Failure
Code
Condition Check/Repair F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC) F3 Open oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F4 Shorted oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F5 Pushbutton stuck Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC) F7 Computer logic interrupted (lock motor) Replace Electronic Range Control (ERC) F8 Computer logic interrupted Replace Electronic Range Control (ERC)
Oct 23, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
111 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
