Question about Maytag Neptune Washer
Water comes out hot no matter what setting we are using
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 06, 2012
Setting is on cold/cold, but only burning hot water is coming out. When I switched it to warm/cold, it got a little cooler but still not cold. The hot/cold setting is also just warm water, so the hottest...
This seems to me to be that the hoses are connected backwards. It matters very much which hose is connected to which inlet. Make sure that the hoses are on Hot to "H" and Cold to "C" on the machine.
Aug 29, 2011 | Admiral AW22 Top Load Washer
My washer no longer produces cold water, only hot, except for the start of the cycle. The machine will tell me that it's not getting cold water. It doesn't matter whether I set the water temperature at...
It sounds like the fill hoses are inverted. Most of the Fisher washers only fill with cold water after the initial fill. So if the hose are inverted then it will only fill with hot. Beyond this I'm at a loss. Good luck
Apr 23, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Have a old maytag want to know if its fixable for cheap model LAT8414AAE will final spin but no water is coming out yes the water is on and its getting power help!
when it goes into the final rinse the washer just uses cold water no matter what you have the setting on, start the washer and flip the setting to cold,does the water come into the washer?try it on hot and check that,if no water coming out on one of the settings do this shut the valve off to the water that feeds the washer,mark the hoses so you'll know where they went and disconnect them from the back of the washer,stick them into the washer or a sink or bucket and turn the water back on,if water is coming out of both hoses you'll know the trouble is just with the washer and i'd say the cold water solenoid on the water valve on the washer is bad and you'll need to replace the valve.
Apr 23, 2011 | Maytag Washing Machines
I set the water temp setting to cold, but it keeps filling with hot water. No matter where I set the dial, it fills with hot water.
check whether the hoses are mismarked when they come out of the wall.
the same thing kept happening to us (whirlpool cabrio) and i checked the temperature on the hoses coming out of the wall - cold was mislabeled as hot by the builder, and vice versa.
Aug 31, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Whirlpool washer GHW9150PW0 and it always washes on hot water, no matter if I set the temperature on cold. I turned off the hot water faucet and still the wash comes out warm. What is the problem?
these washers sense the water temperature that comes in to them and automatically adjust the temperature by turning on the hot and cold valve on make sure both your water valves on the wall are on all the way and water is coming out of each
Aug 19, 2010 | Whirlpool GHW9150 Duet Washer
No matter what the temp setting is at it only has very hot water
Your water temp is determined by 2 things. First the hook up to your water supply. If you are able to turn off the hot water valve that feeds the unit and then select a cold water only wash, do you get cold water?? If not then someone hooked up the hoses to 2 hot water feeds. If hot and cold feeds are installed right, the second thing is your computer which monitors the incoming temp through the boards atc control and a thermister. If you select cold, and only get a hum and the cold water valve is on, you may have to clean the screens in the valve of any sediment. If no hum, and no cold, dead solenoid on valve, but that would throw an error code usually. All fills are monitored by the board and usually begin with a hot/wrm mix and then changeover to a monitored cold temp , about 70 degrees.
May 05, 2010 | Kenmore Elite 45986 Front Load Washer
Only the hot water works
r u sure the cold water is getting to the washer if so u have a cold water solenoid and thats where your problem is probably gonna be it should have 2 wires put it on cold and turn washer on and check to see if u have power going to the solenoid if so and u have water gettin to the solenoid the solenoid is bad its a simple changeout and quite cheap
Feb 25, 2010 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire washer hot water only
sundsas if you have a bad temp select switch. only selecting hot/hot
Oct 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
LG Tromm hot water only
i have found the water inlet valve bad and also the main control board can cause it
Feb 24, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
