Question about Acer AL2223W 22" LCD Monitor
Power supply where can i buy new power supply of Acer 22 LCD AL2223W
  • 7,365 Answers
Try ebay
acerspareparts.com
superwarehouse.com
Posted on Dec 05, 2012
2 Suggested Answers
rasi5050
  • 109 Answers
SOURCE: acer al2223w lcd moniter is
it is the problem of the LCD panel .it is replacable .go for guarantee if not finished the period thanx plz vote
Posted on Apr 06, 2011
Al2223w
Look for swolen and bulging capacitors on the power supply board, this is athe most commonc ause for LCD monitor failure. Here is a link to information about repairing the board and what to look for.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_38&products_id=144
I hope this helps.
BuddyMc
Feb 25, 2012 | Acer Computers & Internet
My side bar on acer monitor screen has become white. How can I solve this problem? I was told to click on the auto configuration key but can't find it.
If you have a white bar running up the side of the monitor, then it is probably dead. Acer has 3 year warranties on their monitors so you should call them to see if you are still in warranty. If so, they will fix it free!
If more than 3 years old, try it on another pc. If it is the same on another pc, get a new monitor.
Hope this helps!
Regards,
Joe
Apr 04, 2011 | Acer AL2223W 22" LCD Monitor
Acer al2223w lcd moniter is blacking/blanking out upon boot up and also while the computer is on. any ideas on how to slove the problem?
Feb 28, 2011 | Acer AL2223WD (Black, Silver) LCD Monitor
How do i remove the back cover of my al2223W monitor?
Remove all the screws and the stand, then use thin flat blade screw driver to separate them starting at the bottom edge and work your way around, be careful on the cable attached to the front bezel.
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL2223W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Feb 10, 2011 | Acer AL2223W 22" LCD Monitor
Myscreen is too bright is it possible to change this?
You use the buttons. You press the middle button, if 3, and a menu will appear, navigate by repeated "presses" on the button, this will advance it through the items, then "Select" with the middle button, & use the buttons either side to go Up & Down, + or - in value, with the middle button as the "Select" or "End".
Feb 07, 2010 | Acer AL2223W 22" LCD Monitor
Screen is dimmed for 2-3 secs then it goes black
The fault could be a faulty inverter or a faulty CCFL lamp.
The inverter supplies high voltage to the CCFL lamp, if faulty the CCFL lamp can flicker or not light up. The CCFL lamp is a mini fluro lamp, and flicks on and off when faulty especially as it ages.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Oct 01, 2009 | Acer AL2223W 22" LCD Monitor
Acer 22" AL2223W monitor display goes black after a second
Look at the capacitors in the power supply. Replace them if they look bulged on wither side or leaking. Most likely it is the inverter (the flat object with copper coils about 2 inches long, 1 inch wide). Check the resistance with a multimeter to be sure its around 1000k on both pair ends. They supply the CCFL tubes with voltage. If one onthem is bad they are designed to shut off within 1-2 seconds. Note the inverter numbers and order the part from www.lcdparts.com. You won't get them anywhere as the parent company MoniServe makes the power supply board for Acer.
Sep 15, 2009 | Acer AL2223W 22" LCD Monitor
My Acer 22" AL2223W monitor display goes black after a second. How can i fix it my self?
The same thing happened to mine 6 weeks after purchase, Acer had to replace the power supply.
Sep 01, 2009 | Audio Players & Recorders
My Acer 22" AL2223W monitor display goes black after a few seconds, How can i fix it my self?
try hooking it up to another computer to ensure
it is not the graphics card that makes trouble...
if still the same prob, check the net if there are
known overheating problems for that model,
i personally recommend to see a technician, as repairing a monitor could make things worse...
up to u, good luck then
Sep 01, 2009 | Computers & Internet
Acer 2223W monitor stand
There are indeed generic stands which rotate between portrait and landscape orientation. This monitor, like most monitors sold today, has generic "VESA" mounting holes, in the 100mm x 100mm (MIS-D, 100, C) configuration shared with most other flat screen PC monitors, so they can easily be used with a variety of stands that attach to the 4 holes in the center of the back side of the monitor.
Apr 05, 2009 | Acer AL2223W 22" LCD Monitor
Acer AL2223W 22" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
