Question about Visioneer PaperPort Strobe S-10
Parts visioneer paperport strobe s-10
Need cable and adapter
3 Suggested Answers
SOURCE: calibration sheet for Visioneer Strobe XP100
I made my own with a blank piece of paper and a sharpie. Make a solid black strip about 1.5 inches wide about 1.5 inces down from the top (short edge). about 1.5 inches below that make another one about 3 inches wide. Mine were at an angle but it still worked. feed it striped side down small line first. so esentially the first strip hits the entire width of the scanner all at once then it will see all white again, then all black again but wider this time. then all white till the end of the page. I based my mesurments on a picture so i have no real measurments but mine did work. if anyone has an actual page please take some mesurments and post them on here plz. well hope it works for you.
Posted on Aug 29, 2009
SOURCE: Loaded Visioneer Strobe XP 300
Did you calibrate the scanner on the Windows 7 machine? When you calibrate, a file is saved on the host computer - if you do not calibrate, everything is black.
In case you dont have a calibration sheet, I just uploaded one to FixYa - it will take a few days for moderators to review it, but then you can print it out on both sides of a single sheet of paper (so that the arrows are pointing at the same end of the paper, but on both sides of it) and use that to calibrate your scanner - make sure that you have 'edge to edge' printing turned on, as there cannot be any white space on the sides of the black space.
Posted on Nov 12, 2010
Have an older Visioneer 7100 USB Scanner, Has worked fine for more than 10 years, Now I can't get any scanned objects to appear on my Paperport Desktop. Have no problem using scanner with all other...
Have you upgraded to newer version of windows? Have you tried reinstalling Paperport? (back up max files 1st) I have had a visioneer and still use Paperport 8. Often I have problems with Windows 8 and reinstall paperport now and then.
Mar 07, 2014 | Visioneer Office Equipment & Supplies
Can you also Fax with this One Touch 8900 ?
This is only a scanner. To Fax, you will need a separate fax machine or fax modem. If both the scanner and fax machine are connected to your computer, you will be able to scan the document and then fax it from the computer. (Depending on your OS/software, this could be easy or take several steps. For Windows Vista and Windows 7, you can use Windows Fax and Scan to do both steps. (However, the program doesn't scan to PDFs.) Paperport will also send a scanned document to an installed fax option. PaperPort is part of the third-party software that came on the CD with the scanner.)
Documentation for the Visioneer OneTouch 8900 is available here: http://support.visioneer.com/products/8900/default.asp .
I hope this helps.
(There are some email-to-fax and web-to-fax options but I have not reviewed them.)
Jul 14, 2011 | Visioneer OneTouch 8900 Flatbed Scanner
New windows7 CPU 64 bit Cannot install software PaperPort Deluxe 7.02. Help
Checking their website, v7.02 does not support Windows 7. Their drivers page lists up to Windows Vista, which should also work on Windows 7, but the only mention of a 64-bit OS is the fact that WindowsXP-64 is NOT supported. You will probably need to either a) get in touch with Visioneer and find out whether there is a patch or update that will allow v7.02 to run on Win7-64, or b) upgrade to v11 (the latest version of Paperport). Hope this helps!
Mar 16, 2011 | Visioneer One Touch 7600 USB
Loaded Visioneer Strobe XP 300 with PaperPort 11 on Win7 machine, but all scans come out black. Any ideas out there? Previously I had the same scanner working fine on an XP machine. Maybe there is an...
Aug 22, 2010 | Visioneer Strobe XP 300 Pass-Through...
I need driver for Visioneer Paperport 6100 Scanner
Go on line to the Visioneer web site. You can down load new drivers, manuaals and soft ware...Roy
Feb 03, 2009 | Office Equipment & Supplies
Visioneer 8100 and Vista
Help is here,
You have compatibility problems with visioneer and Vista, I helped a few people last week with the same problem.
I recommended them too www.cnet.com for the latest paperport download and got my Fixya button pressed.
Please remember to rate my efforts,
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Jan 19, 2009 | Visioneer OneTouch 8100 Flatbed Scanner
VISIONEER STROBE XP22 SCANNER
WE DID NOT HAVE A "CLEANING SHEET" AS WAS SUGGESTED BY THE MAKERS OF THE VISIONEERS. APPARENTLY OURS DID NOT COME WITH ONE UPON PURCHASE. HOWEVER, WE WERE SUPPLIED WITH A CALIBRATION SHEET. WE SIMPLY RAN THE CALIBRATION SHEET AGAIN ...... PROBLEM SOLVED.
Nov 07, 2008 | Visioneer Strobe XP 200 Path-Through...
PAPERPORT PICTURE FILE
Open your visioneer software. Scan your image then select the image and display it by clicking the desktop icon at the top tool bar. Then once your image is displayed, go to the pulldown "file" and choose "save-as". Select the format of your choice from the bottom pulldown of the "save-as" window. Of course name you image before saving.
Mar 25, 2008 | Visioneer PaperPort 3100 Flatbed Scanner
Visioneer PaperPort Strobe S-10 Logo
53 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Computer Links
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
