Question about Cisco 7941G IP Phone
I cant test my 7941g because i keep getting a small bullseye on the bottom left corner of the screen
When i plug the phone into my switch it says it is upgrading but nothing happens and then i get a small bullseye on the bottom left of the cisco screen
    New Friend:
  • 26 Answers
Your phone is trying to connect to a TFTP server address to download a firmware and/or config file update. You need to figure out what IP address it is trying to connect to (You may have to use wireshark or another packet sniffer to determine this).
Once you know the IP it is trying to connect to, you'll need to set up a small network with a TFTP server running on that same address, and feed the phone a firmware update and/or config file. It will likely not fully boot unless it gets a firmware update.
Cisco Phone 48V Power Supply
Posted on Dec 06, 2012
5 Suggested Answers
SOURCE: Ethernet Disconnected message in POE 7941G IP Phones
the first problem will be to check or replace the cable that you use to connect the phone or check the jack that you use
Posted on Jul 12, 2007
fcollingwood
  • 58 Answers
SOURCE: Inline power problem: cisco ip phone 7941G
You need to ensure that each port that has a phone plugged into it is configured with power over ethernet configured switched on.
Posted on Mar 21, 2008
RPaterson
  • 48 Answers
SOURCE: Cisco 7911G definitely dead?
You are very close to fixing your problem. You will need the correct firmware and files; these are proprietary but you should be able to acquire them from your certified reseller. Alternatively, here at IdacomUSA, we have the proper firmware on hand, and can flash the phone for you to get it back to life. Call us at 1-800-903-9190 or visit us at http://idacomusa.com
Posted on Feb 11, 2010
  • 97 Answers
SOURCE: how power need Cisco 7941G-GE IP Phone
These phones can take their power from a Power over Ethernet switch, where all you need to do is plug the phone in to the switch and it gets its power from there.
You can also get power cubes for these phones, but they do not come with the phone as standard, as most people like the convenience of having the power coming from the switch, and not needing to use up a further power socket in the floor/wall.
Hope that this helps!
Posted on Nov 08, 2010
My power button is not working my phone was switched off could you pls help me to switch on my phone. power button is not at all working my battery is full and it was switched off.
Sometimes plugging in the phone (into the charger) allows the phone to boot. Maybe your battery is simply empty? Charging the phone is a good idea regardless.
Also, try booting to safe mode to test the power button:
  1. Turn "OFF" the Galaxy S6
  2. Press and hold the Power/Lock button at the same time until you see the "Galaxy S6? logo
  3. When the logo shows up, immediately hold the Volume Down button, while releasing the Power button
  4. Keep holding the Volume Down until your phone finishes rebooting
  5. If it was loaded successful, a "Safe Mode" will show on the bottom left corner of the screen
  6. Let go of the Volume Down button
  7. To exit "Safe Mode" press thePower/Lockkey and then touchRestart
Dec 14, 2015 | Samsung Galaxy S6 Edge
Wont boot
Remove ALL media, DVD,CD, USB, etc. Unplug, remove battery, plug in, reboot. If that fails, reseat the Memory Mods. Replace the CMOS battery, remove HDD and test.
Mar 18, 2013 | HP G60-438NR (NW150UA) PC Notebook
How power need Cisco 7941G-GE IP Phone
Nov 06, 2010 | Cisco 7941G-GE IP Phone
When I plug the 7941 cisco phone up to our network on a POE switch, it responds with the message "Ethernet Disconnected", but when we plug another Cisco 7941 phone to the same line it works perfectly... We...
I would check your duplex settings. Often, if you hard code the duplex settings or have a mis-match; one end may not talk properly. Also, have you tested the wiring? Do you know the ethernet is okay for sure? TechRx, Inc. - techrxgb.com
May 12, 2010 | Cisco 7941G-GE IP Phone
Numbers 1 2 3 appear on screen and small + in box in right hand corner cant see what they are for or how to get rid of them
Just draw your finger from left to right across the centre of the screen and you should be back to normal. Don't know what the numbered boxes are though.
Jan 24, 2010 | LG GT505 Cell Phone
Set auto view text
push the messages button (the bottom left corner in landscape view) - this takes you to the menue
push the same button again - this enters settings
push down and ok - this goes to text message settings
push ok - selects auto text
push up, then ok - changes from "off" to "on" then selects
that should do it!
Apr 19, 2009 | Samsung SCH-u740 Cellular Phone
Bottom left corner of SciPhone is not working.
have you tried the calibration option in you settings options? it should allow you to recalibrate it.
Apr 02, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Handsfree sign top left of phone
hi,
try to clean the bottom part of your phone..
where the charging pin is located.
try to clean the part where you plug your headsets..
Aug 19, 2008 | Sony Ericsson K610i Cellular Phone
Mar 20, 2008 | Cisco 7940 IP Phone
Cisco 7941G IP Phone Logo
805 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
