Question about MSI G31M3-L V2 Desktop Board - Intel G31 - Enhanced SpeedStep Technology - Socket T - 1333MHz, 1066M... Motherboard
No display motherbord - MSI G31M3-L V2 Desktop Board - Intel G31 - Enhanced SpeedStep Technology - Socket T - 1333MHz, 1066M... Motherboard
  • 3,799 Answers
If the fans are running, check your RAM, If they aren't-check you power supply.
Posted on Dec 06, 2012
No display of my motherbord
The problem is that the enable jumper for the onboard video is not installed.
Note: The POST beep should be occurring, to indicate there is nothing wrong with the motherboard.
If the motherboard onboard video is bad, install a graphics card.
Aug 24, 2015 | ASUS Computers & Internet
865 motherbord biasing problem if i can flash the
try to remove all cable ram and processor from motherboard.and take it out . clean ram and motherboard carefully using a new paint brush.then connect and switch on.
Mar 18, 2010 | Intel BOX PentiumD 840 3.02GHz 800MHzFSB...
Monitor will not diplay, like it's in perment sleep mode. I have unpluged it tried new cables, I am out of ideas, HELP!!
When you power up the computer press F8 key then enter in enable vga mode thne go to control panel and display property then change screen resolution to 1024*768 then check.But if you are not able to safe mode and other menu when you press F8 then follow below steps.1 by 1 and check.
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattach both.
Make sure motherbord is not ground with cabinet.
Remove pci cards from motherbord then check.
Let me know if you need further assistance.Thanks.
Nov 13, 2009 | Dell VOSTRO SLIM TOWER and , MONITOR 19...
Asus motherboard( A7N266-VM)
FOr reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defaults.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Make sure motherbord not ground with cabinet.
Nov 11, 2009 | ASUS A7N266-VM Motherboard
Intel d845gvsr motherboard p4 processesor if computer is on then no display . so i see , don;t heat processor.
First open cpu cabinet.
Refix RAM memory on motherbord.
Remove PCI cards from motherbord.
Open processor fan and processor then refix both.
Pull CMOS cell from motherbord for 15 minutes so all settings defaults.
Make sure your motherbord not ground with cabinet.
Then check.
If processor and circuit are heat high then put extra fan in cabinet.
Thanks.
Nov 03, 2009 | ASUS P5V800-MX Motherboard
HP Pavilion DV2000 no Display
First pull motherbord from cabinet some times motherboard is grounding with cabienet.
Then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reconnect ATX power connector to motherboard.
Then check.
If still same issue then open processor fan and processor then clean dust from all place in mothebord.
Then try.
If you still got same then something rong with your ram or motherbord.
Change ram then try.
Pull all card from PCI slot check motherbord only with RAM not even harddisk and other device.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
START UP PROBLEM
You need to reset bios.
Open cpu cabinet and pull cmos cell from motherbord chipset for 15 minutes then all settings are factory defaults.
Aslo you can reset settings with jumper settings .
Refix your RAM memory. Refix processor.
Reattch ATX power supply to motherbord.
Thanks for using fixya.
Please rate solution if it helps.
Jul 20, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Motherbord is not giving display
change the power supply and try agine
Apr 06, 2009 | Computers & Internet
Intel 845gvsr motherbord nos display.
with no ram you will get beeps that confirms your processor is working (as it cant detect ram) you could be using the wrong speed or type, also as Ghoaliass stated, if your using a couple of modules try one at a time, if it fails on the first, remove the stick and try anther one and so on until you at lease get a bios screen :)
Hop-e this helps,
XBM
Nov 26, 2008 | Computers & Internet
MOTHERBORD
agar display nai ata to problem ko aap plz sahe tara se define karain ge ke kab kese aur kahan se yeh problem hua hay???
thanks
Nov 08, 2008 | Computers & Internet
MSI G31M3-L V2 Desktop Board - Intel G31 - Enhanced SpeedStep Technology - Socket T - 1333MHz, 1066M...  Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
