Question about Acer Aspire Predator G3610 Desktop Computer
My acer predator G3610 starts beeping when i am trying to start it. How do I stop the beeping without damaging the computer
The beeping doesn't have time gap between them. It just continually beeps. I had this trouble before, but then it stopped when i unplugged all wires that were going to the computer except the power cord. I shut the computer, waited like 4 hours and turned it on. then it didn't beep anymore. But now i have the problem again! Please somebody help...!
  • Acer Master
  • 7,733 Answers
Your HD is burn.Change and reinstall the OS.
Posted on Dec 06, 2012
Pinky01
  • 209 Answers
SOURCE: computer beeps and screen is blank
The computer beeps when some components are missing. Check all the connections.
Please try to press F8 at the boot, and choose Safe mode. You will see then if it is the hard drive the problem.
If you have more information after the T180 for the model number, can you indicate it please. You might have to update the BIOS.
Posted on Sep 11, 2008
PcExpert
  • 293 Answers
SOURCE: Acer Aspire T690 startup problem
MEMORY PROBLEMS Hi, FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 19, 2007
samaddar07
  • 639 Answers
SOURCE: acer aspire T180 wont start
Remove the side panel and remove the RAM.
Clean the RAM slot with dry brush or cloth.
Clean the RAM.
Fix the RAM back in the slot.
Close the cover and Start the PC
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Posted on Jul 13, 2011
Giddion
SOURCE: Acer Veriton 6800 PC Desktop will only beep will not boot.
reseat ram for a fast beeping and disconnect the power supply both the big and 4 pin connectors for 2-5 min plug in and boot. Plus you do not have to have pairs of mem only if you wand double data rate
Posted on Jan 10, 2008
  • 233 Answers
SOURCE: ACER Aspire- beeping sound - 6seconds when I power machine on
The beeps are telling you there is a hardware failure (POST). The number and length of beeps will give a better indication as to what has failed. Write back with that info and someone on this web site will interpret this for you.
Posted on Jan 19, 2009
Acer Predator G3620 beeps four times when started. Screen no signal, keyboard and mouse no lights. ? Anyone knows please ?
Four beeps indicates that something isn't right inside the case. It may be as simple as the video board coming unplugged or something like that. It may be that the memory card has come out, I think that may be the beeps are saying. Open the case and check for loose stuff.
Oct 13, 2015 | Acer Computers & Internet
Predator g3610
Use a different PC with a working internet access.
Go to your manufacturers website and download the driver from them.
Then use a usb thumb drive AKA flash drive and save the downloaded driver in it.
Take with you the usb thumb drive and plug it in on you offline PC and install the driver from it.
Aug 17, 2014 | Acer Computers & Internet
My acer 5741 boots but after 1 minute starts beeping once every 5 seconds.the beeping stops when i do something on the computer but starts again when the computer is idle.otherwise it works fine.any ideea?
Could be the cmos battery low voltage, the processor may be too hot, the video firmware may have errors ... could be all manner of things.
Try updating your drivers after checking the cmos battery.
May 12, 2014 | Acer Aspire 5742 Notebook
New gpu
To upgrade the GPU you need to see what expansion slot it has on the motherboard for after market video cards. Once you know that then you can buy any card that has that expansion slot configuration. The thing you run into that really you shouldnt because your pc is fairly new. Is how much ram you can allow to allocate to the new card. The way you are clear of this issue is to buy a card with the ram built on then its not allocating any. As well be sure to go into bios and turn the other card off if its an onboard. Tell the pc to look at the new slot for video boot. This will stop any lag on boot.
Apr 19, 2014 | Acer Aspire Predator G3610 Desktop...
Acer Predator AG3 Beeps then Shuts off
could be anything, if you're able to open up the box this solution might work http://www.techspot.com/community/topics/bsod-bad_pool_header-reboot-loop.99006/
scroll down to the bottom for Darkgreen's solution
Jan 01, 2014 | Acer Predator GT7700-UQ9300A Gaming...
Pc turns on beeps once short and turns off
Hmm I found out my hard disk is making that sound but it works..
Nov 26, 2013 | Acer Predator G3610 Desktop Pc Intel Core...
Acer Veriton 3900 Pro - I have a green light on the front but the computer will not power up
If your computer no beep when starting just check the videocard and RAM or memory inside and remove it then clean with the pencil eraser or rubber in the pin and insert back again then try to power on your computer. If did not solve the problem just check your monitor if did not have a problem. But if your computer have a one beep when starting it means no problem on your computer. The problem is in your monitor it could be have a damage.
May 13, 2010 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
Acer Aspire Predator G3610 Desktop Computer Logo
1,748 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
