Question about Refrigerators
Fridge motor runs for extended time before briefly shutting down.
NEC FR 454 (model with computer adjusted freezer temperature control). Only stops running for a short period of time (maybe 30 mins) then runs for upto 2 hours, even if the door is not open. Every repair man I have spoken to has said to throw it away, the computers are always breaking down and it's not worth repairing. Just wanted to make sure there wasn't something simple I could check first. Still keeps everythig cold, and the door seals are working well too. Thanks
  • stubbsy5555 Jan 27, 2009
    Thanks for your help. It didn't solve the problem, but there was plenty of dust and dirt on the coil, so can see how it may have.
At the back of the refrigerator on top is a removable panel hiding the computer element (mother board) of the fridge. It is replacable (i have replaced it a year ago) - you can do it yourself (buy a new element, remove the cover panel, unplug the old mother board and plug in the wires to the new one - is easy as;)
try to buy the element yourself , refrig mechanic quoted $ 500 for the element only so I found it myself from NEC people and paid only ca 150
good luck
Posted on Feb 08, 2009
    Sniper:
  • 51 Answers
About the only thing you can do is check the coils located either underneath the unit or behind it. they will have a fan that directs air over them to disapate heat. these become clogged with an incredible amount of dust over time and extend running time. u can go to a hardware store and purchase a coil brush for under ten dollars it is long and thin to remove dirt from the coils. use a shop vac also. hope this helps. please rate me
Posted on Jan 12, 2009
What temperature should you set a American style refrigerator
Turn OFF your fridge/freezer. Running the unit for an extended period of time will burn out the motor. You will need to get a technition in to check the thermostat operation.
Jul 15, 2014 | LG Lsc23924sw 33 23 Cu.ft. Sxs...
NEC FR 405 Fridge/Freezer
Hi Sound like your freezer needs a new thermo switch. The switch regulates the temperture and turns it on and off. Replace and your good to go.
Jan 21, 2014 | Refrigerators
Kenmore refrigerator stop cooling but fan working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Apr 06, 2010 | Kenmore 53642 / 53644 Side by Side...
Maytag P MFD2561HEB model the frig is not cold but the freezer is fine. How do we set the frig control?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 16, 2009 | Refrigerators
My frigidaire gallery FRS26ZSH refrige side is not working but the freezer seems to be keeping things cold... the fan motor is running, is this a compressor problem? help
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 15, 2009 | Refrigerators
Freezer blowing cool air, but not freezing.
Hello there:
first make sure that the back of the unit is clear of any dirt or obstructions
also make sure that the food is not stacked up so high that the air cannot circulate also you may want to check the temperature setting if the unit does not respond to a lower setting your refrigerant level may be low or than you will have to have the temperature controle thermistor serviced or replaced
Sep 15, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
I have to keep the temperature turned up to 9 in order to keep the food at 45 degrees. The fridge is only 3 years old.
If it's the freezer control you keep at 9, it's probably a defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
If it's the fridge temp control you're talking about The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 15, 2009 | Refrigerators
Refrig does not turn itself off except at very low
How to check stuff>
Jul 13, 2009 | Refrigerators
Freezer works fine but fridge has lost its temperature.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
Jul 02, 2009 | Refrigerators
Freezer frost buildup; fan constantly running; water filter
Just had mine repaired. Tech told me that the tempearature settings on the display panel are not EXACT science. The fridge is cooled by blowing air from the freezer to the fridge and when the sensor in fridge reached approx desired temperature, the damper is closed.
The noise you hear periodically (water dripping) is the heating rod melting the defroster (hence frost freeze), which unfortunately sometimes spills into the blower motor to fridge, causing frozen motor, causing the infamous ER FF error code and fridge failure.
I reluctantly had LG to do the energy saver fix (recall) and it replace everything that the internet users are complaining about.
Jun 27, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Open Questions:
GE Spacemaker JVM1339ww002 - looking for photo of plugs in control board plugs for reassembly or a wiring diagram? Disassembled without noting locations and now start & clear buttons do not work. I have a very old model GE spacemaker XL microwave, model# JVM1339ww002. I repaired the #1 key by cleaning contacts and reinserting the ribbon connector to the control panel. However, I did not photograph the connections. Some plugs have only 1 location where they fit. However, 2 pairs of plugs are the same size and I do not know the correct place to reinsert them. I took a guess & reassembled the microwave and it worked except for the start/clear buttons. If you press a number 2 shortcut for example, it will cook 2 minutes and the food is heated. However, start and clear do not work at all. These buttons DID work before I repaired the numbers. I contacted GE and they gave me a hard time about providing the wiring diagram which was removed or not inside my microwave. I am not sure if I reassembled the plugs wrong OR if I broke something else when I was repairing the numbers. Can anyone help me with the right locations for the 2 pairs of plugs listed below? And/Or tell me if it sounds like start & clear are a new problem or will be resolved by getting the plugs correct? These are the 2 sets of plugs that can be inserted in either location: 1) a pair of matching white plugs that snap in place along the bottom (1 has white wires only and the other has 1 white/1 black wire) 2) a pair of red and white plugs of equal size in the middle of the board. They are similar (but smaller) to plugs in wall outlet with 2 prongs. Similar to a wall outlet, you can rotate the plug 180 degrees and they still fit. In other words besides asking which plug is upper or lower, do I need to worry if the plug is upside down or this doesn't matter? The red plug has black wires, while the white plug has blue and white wires.
Apr 19, 2018 | GE Refrigerators
Refrigerators Logo
215 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
