I cant get my air conditioner to go on. - Heating & Cooling
  • carl carpenter
    carl carpenter May 11, 2010
    check your circuit breakers, is your air handler in the attic or a closet. window unit or a package unit
  • 3 Answers
Yes.. first check circuit breakers on the outside unit. then.. make sure the power disconnect beside the outside unit is put in correctly. Sometimes a technition will replace them upside down. if you have power to the unit and it still has not came on.. make sure the unit is getting a "Call signal" from the thermostat. if there is a call signal from the thermostate reaching the outside unit, then listen for a "CLICK" when the thermostat is turned up and down. The click is the sound of the "COntactor" making contact when the unit recieves the "CALL Signal" This means the UNIT is most likely getting 220 volts, Check the voltage input to be sure with a Volt meter. IF you are still getting power and the unit is not running.. the run capacitor is most likely bad.
Posted on Jan 12, 2009
What is the expected life span of LG air conditioner?
What is the model of your air conditioner. With out that information i cant help you with your ac repair problem. If you need any other help check out AC Repair Boca Raton we got you covered
Life Span of Central AC unit are about 10 to 15 years.
Jun 22, 2016 | LG Heating & Cooling
How do you adjust the temperature on this unit?
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. West Palm Beach Air Conditioning
Apr 18, 2016 | LG LMN125HVT Air Conditioner
Compressor not cutting off when temp goes boiiow set temp
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.Air Conditioning Delray Beach
May 18, 2014 | LG LSC121PMA Split System Air Conditioner
WHERE CAN I FIND AN AIR FILTER FOR Whirlpool Air Conditioner Model ACQ062MM0
It depends where you are. This company has them
http://www.repairclinic.com/Shop-For-Parts/a16b5d619658/Model-ACQ062MM0-Whirlpool-Air-Conditioner-Parts?z=100
Mar 10, 2014 | Whirlpool ACQ158XP Wall/Window Air...
Cant get it to blow cool air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 05, 2011 | Heating & Cooling
Cant get heating to work
adjust temp e.g. 39 deg Celsius or high and turn on heat,but first you must turn off air conditioner then select heat rating and turn on a.c.
Jul 05, 2009 | Heating & Cooling
LG BG8000ER Air Conditioner Problem!!
go to ca.lgservice.com find find owner's manuals under quick links and then fill in your product information to obtain a copy of the instruction manual.
Jul 31, 2007 | LG BG8000ER Air Conditioner
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
