Question about Kenmore 659 Electric Dryer
Want heat up
Show me where the problem is
  • 45 Answers
The first thing we must determine is the type of dryer we are servicing. There are only two types; Gas or electric. If your dryer is electric, meaning it uses electricity instead of flame to produce heat, step one is to verify that the breaker to the dryer's electrical circuit is fully on. Since electric dryers require 240 volts to run, their circuit is run through a dual breaker switch. Sometimes only one half of the breaker switch will be off or fail which will supply enough power to make your dryer tumble but not enough for it to produce heat. Pop the breaker to your dryer off and on again and then see if the dryer will now produce heat. If it does, then have the breaker replaced. If it doesn't, you can verify that the dryer outlet is fully powered by testing it with a volt meter, You can learn how to use a volt meter here. If the outlet is fully powered then the problem definitely rests within the dryer.
Let's next deal with the failure common to both types.
You will need a continuity tester for this process.
After you have removed the power from your dryer and shut off the gas, you will also need to access the internal workings of your dryer. Directions for achieving access, specific to your brand, can be found here.
Most dryers have a thermal fuse located in the exhaust path. Depending on your dryer, the fuse will be found toward the front or the rear of your unit. Generally, if there is a removable back on your dryer then that is where you will find the fuse.
The two most commons thermal fuses you might find are shown in Figure 1. They are each roughly 1" in size. You will notice that the contact points are easily spotted for a continuity test.
In older units and some electrically heated units you will find a series of thermal fuses, looking like small tin cans, at various points along the heater assembly. These will also need to be tested before you can rule out thermal fuses as your problem. If any of the thermal fuses fails the continuity test, then it needs to be replaced. You can find reputable parts dealers at the top of this page.
Electric Dryers After proving your thermal fuse(s) is/are good in your electric dryer it is time to move on to the next most likely possibility, the heating element. A typical heating element is shown in Figure 2. The element, as are all dryer electric heating elements, is comprised of metal coils supported on a framework with two contact points where wires are connected to the rest of the dryer. A break in this coil will stop the dryer from being able to create heat. Test the two contacts for continuity. If they fail, then you need a new heating element. You can find a diagram showing where each brand tends to place its heating elements here.
If both the thermal fuse and the element show continuity it is time to call a professional to service your electric dryer.
window.google_render_ad(); Gas Dryers Gas dryers use a burner system to create heat. This system has a number of parts that are known to fail over time. Some you can test, some you must simply rely on symptomology to form your decision to replace or not to replace.
In Figure 3 you can see an entire burner assembly with the various parts labeled. Not all of these parts can be tested with a simple continuity tester. An ohm meter is now required to find your problem part. Directions on how to use an Ohm meter can be found here.
The parts prone to failure in your burner assembly are:
  • Igniter
  • Coils
  • Flame sensor
A burner operates in a fairly simple way. Once the motor is turning, centrifugal force closes the Motor Switch allowing the electricity to reach the Flame Sensor. The Flame Sensor allows the electricity to reach the Igniter, allowing it to heat up to a temperature high enough to ignite natural gas. Once the Igniter is hot enough the Flame Sensor breaks the Igniter circuit which allows the electricity to run through the Coils that open the gas valve. Gas then flows out past the Igniter and catches fire and the heat is drawn into the airflow within the dryer.
Posted on Jan 12, 2009
Where is the undercarriage heat shild?
the only heat shield there is or was is on the catalytic convertor .
Nov 07, 2015 | 1993 Toyota Previa
Using a wagner heat gun got sparks from nozzel with a white light no longer works, changed fuse checked fuse ok
the heating grids are burnt out if white sparks were showing.
when ever white shows up refected off steel that is metal burning off in the atmosphere with all carbon from the metal gone. Carbon keeps the metal in a solid strong form until the carbon is burnt out from heat
Mar 12, 2010 | Tools & Hardware - Others
Thermostat show AUX HEAT
A heatpump has two sources of heat. One is when the heatpump is operating in normal heat mode, and the other is typically electric heat strips.
The strips come on when the unit is going into defrost, when the unit is not able to keep up with the demand for heat (really cold temps) and when the unit is not working properly.
Whne the strips are on, the T-stat displays "aux-heat" to indicate the strips are in operation.
If the strips are working properly you should have warmer air than with the HP alone. Try switchin it from "heat" to "emergency heat" and see what it will do.
When the HP is not able to keep up with the demand for heat then the heat strips come on, but they typically come on only when the room temp has gotten well below the thermostat setting.
In that situation it would be normal to see indoor temps at 63 degrees when the T-stat is set on 70.
But when you set it to E-heat it bypasses the heatpump operation and goes directly to the heat strips. If they are working properly it should maintain an accurate temp in the home.
Jan 23, 2009 | GE Zoneline AZ55H09D Air Conditioner
MY drier heating element shows 9 ohms continuity, it also shows 120 volts into and out of it when the drier is running. But the heating element wont heat up?
Have you checked the voltage at the outlet? You're supposed to read 220-240 VAC at the heating element. Your dryer heating circuits require at least 220 VAC to work. The motor, however, only uses 120 VAC. That's why your dryer may be running, but the heating circuits aren't heating. I would go back and check your outlet. You may be missing one leg of the 220 service, or have a loose, burned, or broken wire in the plug or terminal block (on the back of the dryer). Let me know what you find. I hope this helps you.
Oct 17, 2008 | Whirlpool Dryers
Kenmore 659 Electric Dryer Logo
85 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
