Question about Baby Lock Sewing Machines
Baby Lock Jane-thread gets in a big knotted glob by the bobbin, and I have to carefully cut it out as the can't move. it all gets caught inder the material, feed dog and bobbin?
How do I correct this,is it a tension problem, I just started sewing on this. It;s new and is on a quilt frame with a regulator and the feed dog is down, I have it set as it was in the store.
  • Baby Lock Master
  • 7,365 Answers
Try changing the needle
rethread the machine making sure to use every thread guide
try using a different bobbin--make sure the bobbin is turned the
right way
make sure the thread has not come off the thread take up lever
Posted on Dec 05, 2012
mallow1
  • 35 Answers
SOURCE: Thread tension?
I own this little gem of a machine. It definitely sews a perfect stitch. I'm assuming you own the green 3/4 size machine as denoted by your product number. The half size blue one pictured is incorrect.
Anyway, this machine sews a perfect stitch, due to the oscillating bobbin. Most sewing machines with rotary (drop in) bobbins don't have an easily accessible bobbin tension screw, which means your fabric is usually slightly puckered. Fiddling with only the upper tension helps very little. This frustrates me to no end for sewing long curtains, clothing side seams, etc. Wrong tension causes them to hang with puckers, making them look awful. With the Hello Kitty 3/4 size Janome, there is a screw on the bobbin case which allows you to adjust for every thread diameter perfectly. Always a perfect stitch, if you take the time to adjust this screw.
To adjust the bobbin for a perfect tension, load the bobbin into the bobbin case and thread it through the guide. Holding only the thread between two or three fingers, let the bobbin case dangle below. This will be slightly difficult, because the bobbin will want to fall out of the case. Don't worry, just don't move it around too much and it will stay in long enough for this test. If the metal bobbin case slowly drops lower, unwinding thread as it goes, the thread is too loose. Tighten the screw on the side of the bobbin case a little (about a quarter turn.)
If the bobbin case seems to be dangling firmly, give the thread a gentle tug, lifting up fairly quickly. If it doesn't release a couple of inches of thread, it's too tight, loosen the screw. You know the tension is perfect when a quick, light tug of the thread releases a couple of inches of thread.
Posted on Aug 16, 2008
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 3 Answers
SOURCE: needle thread breaks while quilting on machine frame
I think you might have better luck if you use 40 or 50 weight thread.
Posted on Dec 20, 2008
  • 3 Answers
SOURCE: Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Posted on Mar 07, 2009
kent581
  • 87 Answers
SOURCE: Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Posted on Mar 18, 2009
Bobbin trouble
possibly not enough upper tension .
Oct 17, 2015 | Sewing Machines
It says check for broken thread and the thread isn't broken
Pull both the top thread and the lower thread bobbin off. Check if there is thread caught in anywhere along the running mechanism, especially in the lower bobbin area. If there is no thread caught make sure the tension on the thread is not to tight.
Oct 01, 2014 | Baby Lock Esante
Bobbin stuck
I'm guessing you're meaning the " bottom" or "seated" bobbin. Generally speaking, anytime a bobbin won't come up, it's because of a thread, broken part, button or some such other surprise. Could be a small cut-off that's just now gotten caught up or the thread from the bobbin is caught up in itself and the bobbin has "locked up." The other reasons could be...is there an additional locking mechanism, like you might have for the fabric foot. Do you see anything that could be a broken part or needle blocking the way. Just take a look around in there w a light that is stronger and/or more flexible, wiggle a thin screwdriver or something...could be the bobbin "jumped it's track." Try rethreading everything and see if you can get a forward stitch AND a backward stitch. Don't force anything if you feel any resistance, could be simply that you stopped and cut (again, little thread) at just the wrong part of the stitch locking process. And when all else fails, go in from under the machine, this might be a chore if you have a more sealed up bottom plate, but perhaps you can pop it (the bobbin) out from that angle. Just be careful not to force anything into moving and if you have one of the newer models wherein that area has moving parts that are plastic, be especially careful. When you flip it over, you just might find the phone number for direct tech support for that unit. Good Luck and Happy Sewing!
Jun 05, 2012 | Brother SE400 Computerized Sewing Machine
How can i get the technical manual of model:FHSM-208
I'm not sure exactly which model you're referring to and I'm guessing you're meaning the " bottom" or "seated" bobbin. Generally speaking, anytime a bobbin won't come up, it's because of a thread, broken part, button or some such other surprise. Could be a small cut-off that's just now gotten caught up or the thread from the bobbin is caught up in itself and the bobbin has "locked up." The other reasons could be...is there an additional locking mechanism, like you might have for the fabric foot. Do you see anything that could be a broken part or needle blocking the way. Just take a look around in there w a light that is stronger and/or more flexible, wiggle a thin screwdriver or something...could be the bobbin "jumped it's track." Try rethreading everything and see if you can get a forward stitch AND a backward stitch. Don't force anything if you feel any resistance, could be simply that you stopped and cut (again, little thread) at just the wrong part of the stitch locking process. And when all else fails, go in from under the machine, this might be a chore if you have a more sealed up bottom plate, but perhaps you can pop it (the bobbin) out from that angle. Just be careful not to force anything into moving and if you have one of the newer models wherein that area has moving parts that are plastic, be especially careful. When you flip it over, you just might find the phone number for direct tech support for that unit. Good Luck and Happy Sewing!
Jun 05, 2012 | Sewing Machines
Pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
May 03, 2012 | PfaFF Sewing Machines
While sewing and finishing seam I went in reverse to knot. While resuming to sew again the machine began making beeping sounds and wont move forward to sew.
Raise the needle, make sure no thread is caught ( try clearing out the bobbin area), then turn off the machine, re-thread the machine, then power the machine back on. That should take care of it. ;)
Jun 22, 2011 | Singer 7436 - INGENUITY
I am having a problem with the thread knotting up on the bottom of my material. The needle starts to lock up and when I start checking the thread is all knotted up. I then take the bobbin out and it...
What you have going on is probably a bobbin problem. The knots are referred to as birds' nests and happen usually happen when your bobbin thread gets caught on something in the bobbin area. To be certain it's a bobbin problem, change your needle. Even if the needle looks fine, it could be just slightly bent and still look fine to the naked eye. If that doesn't solve the problem, take the fabric out of the sewing machine and turn the machine wheel by hand. Watch what happens thru the plastic window in the bobbin area, or if you don't have a plastic window leave the bobbin covering off. Is the thread catching somewhere and causing a bunch of thread to gather in the bobbin area? Be very careful when investigating in the bobbin casing/area-it's easy to chip things in there! Often times, a piece of something falls in there and can be pulled out with tweezers. Just as often, the bobbin casing is slightly tilted and needs to be straightened or has a chip in it and needs to be replaced. You can normally get a replacement on eBay, searching with your machine model number. Also, check out SewVacUSA. If you need help replacing the bobbin casing (it's easy, you just need to be careful), or if these solutions don't work, leave me a comment. I check back daily, so I'll get back to you within 24 hours normally. Leave me as much detail as possible and I'll do everything I can to help you!
May 11, 2011 | Singer 3116 Simple
Thread is knotting up
You probably are in need of a new bobbin case they are plastic and oif you have broken a needle lately it may have gouged the case and the top thread is getting caught and bunching up underneath. Visit www.stevessewandvac.com you can contact them and have a bobbin case sent to you.
Mar 13, 2008 | Baby Lock Ellure
Thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Feb 26, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
93 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
