Question about ASUS M2N68-AM PLUS Motherboard w/ AMD Phenom X3 8600B Processor Bundle (M2N68AMPLUSW8600B)
Phenom ii x4 965 m2n68-am plus
Phenom ii x4 965
3 Suggested Answers
  • 43 Answers
SOURCE: M2N68-AM PLUS does not support cpu AMD Phenom 9750
No it does not. although it says it supports sockets AM2, AM2+, and AM3 and the Phenom 9750 is an AM2+, the Phenom 9750 has a wattage requirement of 125 watts. This motherboard ONLY supports CPU's up to 95watts! You would either need to get another motherboard or another CPU (or both and make a second computer).
Side note: also keep in mind that if using this motherboard with an AM2+ CPU, it will not be able to handle 1066MHZ memory (or higher) in dual channel mode, in order to get this speed you will either have to take out the second dimm or run both dimms at 800MHZ.
Hope this helps!! (and if it does, please rate or leave comment. It will be much appreciated!!)
Posted on Feb 12, 2011
leethedeuce
  • 4472 Answers
SOURCE: I have the m2n68-am plus
Yes they do. If you go get the newest bios update it supports new CPU's. Just follow this link:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM_PLUS/#download
Thank you,
Lee
Posted on Apr 18, 2011
Is the Am3+ socket also possible for sapphire AM3RS890G2?
am3+ socket is what the socket is listed on the motherboard, so if you have a CPU that fits only AM3+, the CPU wont fit it unless directed by the CPU manufacture seeing that AM3+ is for AMD processors only if you have a older AM3 CPU it might fit the AM3+ motherboard if listed, this paticular model only lists AM3 and fits Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6
Aug 10, 2014 | Sapphire Technology PC-AM3RS890G2 Desktop...
Power shut down shortly after bios loads
Check the processor and heatsink/fan. If there is a bad contact between the heatsink and the processor, or the fan fails to turn the BIOS will shut the system down to protect the CPU from overheating. I hope this helps.
Mar 02, 2012 | ASUS M2N68-AM PLUS Motherboard w/ AMD...
Hi, I'm running an AMD Phenom X4 9500 off of a Asus M2N68-LA (Narra3) board. What, if any, processor could I upgrade to on this board in order to get better speed? TIA Peter
Narra3 supports X2 up to 5600+ up to 89 watt Socket AM2 Processor (currently AMD Athlon™ X2 6000+) AND X4 up to 9600+ up to 95 watt Socket AM2+ Processor (currently AMD Phenom™ X4 9600+)
Sep 23, 2011 | Computers & Internet
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
There are 7 non-metallic small washers in my m2n68 barebones kit. when I install the motherboard to the chassis, do I use these washers with the mounting screws? if not what are they for?
Probably red on one side? Like paper almost?
These simply provide a buffer between the screws and the circuit board to prevent pressure cracks when over tightening the screws. Some people use them on drive mounting screws to lower vibration noise.
Cheers!
-Lucas
Feb 20, 2011 | ASUS M2N68-AM PLUS Motherboard w/ AMD...
Feb 12, 2011 | ASUS M2N68AM PLUS Motherboard AMD Athlon...
I just bought a asus M2N68-AM SE2 mob and a amd athlon 64x2 6000 processor and it comes up this model does not suport this cpu. others have same problem. I just want to no what cpu will work. what are...
Supports: AM2+ Quad-Core CPU/AM2 CPU and 45nm Phenom? II CPU Here is the complete list; your CPU is not listed. http://usa.asus.com/product.aspx?P_ID=2UWzsrOiRbMPGYpw
Oct 16, 2009 | ASUS M2N68-AM SE2 Motherboard
Which graphics card ican use in ASUS M2N68-AM SE2 mother bord amd athlon 64 5200+
unfortunately, this board does not appear to have slots for upgrading its graphic card.
Model Brand ASUS Model M2N68-AM SE2 Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 Chipsets North Bridge NV Geforce 7025 / nForce 630a chipset Memory Number of Memory Slots 2×240pin Memory Standard DDR2 1066 Maximum Memory Supported 4GB Storage Devices SATA 3Gb/s 2 SATA RAID 0/1/JBOD Onboard Audio Audio Chipset Realtek ALC662 Audio Channels 6 Channels Onboard LAN LAN Chipset RTL8201CP Max LAN Speed 10/100Mbps
You are stuck with the integrated card.
Jun 28, 2009 | Computers & Internet
ASUS M2N68-AM PLUS Motherboard w/ AMD Phenom X3 8600B Processor Bundle (M2N68AMPLUSW8600B) Logo
159 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
