Question about Samsung R519-53S Notebook
R519 move ac power cable light flicker on/off
If I move the ac adapter cable around the battery starts to charge and laptop power on, move the cable and disconnect and turns off. Suspect one of battery, ac adapter, dc power jack socket or worst a motherboard, has anybody had this issue also, Thanks
    Scholar:
  • 156 Answers
This could be an AC adapter problem.Use another same rating adapter for teating.Check your ac adater volt and ampere at output terminals using a good quality digital multimeter. If OK, check the battery also. Then only suspect motherboard and power jack. Hope this helps
Posted on Dec 05, 2012
  • paul Falconer Dec 05, 2012
    Thanks a lot mate, its like stabbing in the dark.
  • benman Dec 06, 2012
    I have sent a troubleshooting tip to you. The steps mentioned to confirm that the problem is with adapter or motherboard. This is what a pc tech normally do at first. Anyway that was a good comment. I have got a chancea to lagh and hope get 5 more years in this earth. thank you
  • 2567 Answers
SOURCE: my samsung r519 laptops battery will not charge
Please refer to the following article for a full explanation of how to diagnose & troubleshoot this problem:
http://www.fixya.com/support/r6416948-troubleshooting_laptop_power_failures
Posted on Oct 20, 2010
laptopwill
  • 115 Answers
SOURCE: I replaced the DC jack
There is. It would appear that the DC jack was not the only thing that was fried. If all your solder connections are correct, the mother board may have been damaged be the shorting of some part on the board, and burned open. Look for fuses, and "resistors that are have a "0" on them. they should read a short. if you find nothing. the board is damaged beyond repair.
Posted on Apr 18, 2011
  • 6771 Answers
SOURCE: laptop screen flickering diffrent colours
Hook a spare monitor to the video ouput usually on the back, if picture okay! the problem is the new LCD screen or video cable which you replaced, if both show the same symptom it is the video graphics card normally built into the motherboard.
Posted on Apr 02, 2012
  • 6771 Answers
SOURCE: my computer doesnt recognise the ac power charger
The DC jack in the laptop is a common source of trouble, and in this case may need to be replaced. The computer will need to be dismantled down to the motherboard to address the issue.
Posted on May 01, 2012
joecoolvette
  • 5660 Answers
SOURCE: Hey, I have a samsung R60 Plus laptop for a few years now, and its out of warrently and the DC jack power socket has just stopped working. I ordered in a new DC jack for the power socket and soldered
Whew! Not being able to see the motherboard, and damage done, and you need advice?
Okay, onward.
Let's start with some basics first BEFORE you go on.
1) Use a 25 Watt soldering iron, or just stop. Use a No.2 chisel tip.
Use a soldering iron holder with a damp sponge in the base, or have a damp sponge nearby.
(Or use a soldering station)
Keep the tip clean, and well tinned. (Tinned = thin coat of solder)
2) Use .030 Rosin core solder, and Rosin paste. Buy a small brush for the paste.
3) DO NOT linger too long, or you will burn the motherboard, and lift the circuit trace 'hole', right off of the motherboard.
(Crude explanation of a circuit trace, is the thin copper 'wires' on the motherboard)
Lift the circuit trace off, and you will be soldering a jumper wire, (With insulation on it), to an area back on the circuit trace away from the 'hole', and over to one of the DC Power Jack leads. ('Pins')
3) Linger too long on a circuit trace, and it will burn. It will Not accept solder anymore. You cannot tin it.
(Time for the jumper wire again)
4) To remove a DC Power Jack, turn the motherboard upside down. I hold it with one hand. Then use your fingers, and thumb to apply pressure on the jack.
The tips of your fingers, and thumb, act as a fulcrum against the motherboard. While applying steady pressure, (Don't get carried away), apply heat to one of the DC Power Jack leads.
As the lead starts to come out, S-T-O-P
The other leads are still holding the jack to the motherboard.
The procedure is to heat one lead, and pull it slightly out. Then go to another lead near it, apply heat, then pull it slightly out.
Keep going around until all leads of the jack, are free from the motherboard.
HOWEVER, go S-L-O-W. You have all the time in the world. Don't believe me? Mess it up, and you have no place to plug your AC adapter in.
After you heat one lead, and pull it slightly up, allow the motherboard to cool down. (Cool to the touch)
Go to the next lead, heat it up, pull the lead slightly out, let the motherboard cool down.
Once the DC Power Jack is free, there may be a thin skin of solder covering the circuit trace holes, where the leads of the jack was.
This is FINE. Leave them alone.
When you go to install the new DC Power Jack, you will be pressing the leads against the solder covered holes. Touch the tip of the soldering iron against the solder covered hole/s, and the leads will poke through.
Let's look at a DC Power Jack, for a Samsung R60 series of Notebook PC,
http://www.laptopdcjack.net/product_info.php?manufacturers_id=22&products_id=1051&osCsid=n9lotjmn6q04eka4n84gh1htp5
WAIT A MINUTE, this jack connects to a cable. You soldered the leads together, when you were soldering the cable on?
Better take the new DC Power Jack, AND the cable, down to your nearest 'Mom and Pop' computer repair shop, and let them do it.
Cost will probably be a song.
Regards,
joecoolvette
Posted on May 21, 2012
Ive got the Samsung R519, just bought a new battery for it but doesnt seem to have made a great deal of difference, its only 2yrs old! Wont turn on when on adapter & battery removed & no charging...
From the description you have motherboard issues, sub out the ram memory one at a time to see if you can get it started, no change! the dc jack in the laptop is a common source of trouble from no power to intermittent operation, at this point the laptop will need to be taken apart for further examination.
Jul 03, 2012 | Samsung R519-53S Notebook
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
Hi, my Fujitsu A1220 won't start up at all. I took out the battery to reset the laptop but when I put the battery back on or connect it via AC, it still won't start up. I see the Scroll Lock is brinking...
Here are some ideas to try.
1. Plug battery in and see by looking at the charging light if it's charging. The light should stay mostly constant during this process. If it is charging, then wait about 20 minutes. Unplug laptop and attempt to turn on with just the battery installed. If the laptop turns on, then you can be sure you have a bad AC adapter or a bad DC jack.
Uninstall the battery before attempting the next five steps.
2. Look for the light on the laptop that indicates that the AC adapter is plugged in. If that light isn't on, try plugging and unplugging the AC power jack and moving it around until the light shows its connected. If no light comes on, then it's possible you have a bad DC jack or the AC adapter needs to be replaced.
3. Try a different outlet. (I know it's obvious but it's worth a try).
4. If the indicator light is on and the laptop won't power on, then it's possible you have a bad switch board or stuck button. Make sure no buttons are stuck. Conversely, push hard on the power button and move it around in order to make sure you're making good contact.
5. If your laptop has another button that turns it on, such as an internet button, try that button instead of the normal power button.
6. Replace the AC adapter. Find and buy a compatible AC adapter online. You can usually find them reasonably cheap.
7. Replace the switch board and/or the flex flat cable that runs from the switch board to the mainboard. (This requires some technical know-how).
Hope one of these ideas helps.
Good luck and thanks for using FixYa.
Mar 08, 2011 | Fujitsu LifeBook A1220, LifeBook A6210,...
Power problem
Here are some ideas you can try when troubleshooting power issues with a laptop:
1. Plug the laptop into AC power.
2. Take out the battery.
4. Look for the light that indicates that the AC adapter is plugged in. If that light isn't on, try plugging and unplugging the AC power jack and moving it around until the light shows its connected. If no light comes on, its possible you have a bad DC jack or the AC adapter needs to be replaced.
5. If the indicator light is on and the laptop won't power on, then it's possible you have a bad switch board or stuck button. Make sure no buttons are stuck. Conversely, push hard on the power button and move it around in order to make sure you're making good contact.
6. If you know the battery has a charge, unplug the AC adapter and connect the battery. If it turns on then you can be sure you have a bad DC jack or a bad AC adapter.
8. If your laptop has another button that turns it on, such as an internet button, try that button instead of the normal power button.
Thanks for using FixYa.
Mar 03, 2011 | Computers & Internet
Yesterday my battery was indicating it was at 17%, so I plugged it in. Awhile later the "battery low" indicator came on screen so I realized it hadn't been charging. It still didn't charge if I...
You have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 27, 2011 | Panasonic Toughbook CF-51 Notebook
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
Yellow light flickers 4 times when trying to turn
If you don't get the flickering lights when you try to boot up with the AC adapter hooked up but no battery, it sounds like the problem is most likely a bad power adapter. Your battery is dead, and that's why you get the flickering lights, but the AC adapter is bad so you can't use it to power the laptop or charge the battery.
You can typically get a new adapter for $20 or so, or maybe even cheaper on eBay.
May 29, 2010 | Toshiba Satelite A10 Notebook
Problems with charging
This still could be either if the cord is being moved at the same time. when the laptop is able to turn on, Does everything (programs, software, etc) function properly? If yes, then we can narrow it to the battery or ac adapter.
To find out whether it is the ac adapter or battery, take out the battery, and see if the laptop powers up and stay that way. If it intermittently closes or shuts down, it's most likely the ac adapter.
If it stays powered on, even if you move it, then it's most likely a battery issue.
If you want to be sure before spending some money, go to a friend's, neighbor's or computer store with a with the same manufacturer (dell, toshiba, etc), and borrow their ac adapter to check
Nov 21, 2008 | Computers & Internet
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Samsung R519-53S Notebook Logo
142 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
