Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Washing machine hi, i turn my washing machine on and half way through the wash it stops, it says 4E on the fron panel.its a samsung washing machine, can anyone help please?
  • zahoor Nov 21, 2007
    my machine is problem we are start the machine in water and go to washer/heavy & select the wash/heavy water is loss. fault this machine no water in machine dram.
  • Anonymous Mar 12, 2014
    Wash half way display E1
Hey 4E error comes in case
1. No proper water supply
2. The Outlet pipe sould be at AT LEAST 60 CM to max 90 CM HEIGHT ie to the height of the washing machine, try putting the outlet pipe to the holder at the back of the machine.
rohityadav79@gmail.cm
Posted on Feb 03, 2008
Following on from faxxell's comments (once translated!) I checked my element/senser and although this was fine I noticed the hose had a small hole where the drum had been rubbing against it. I cut the hose back, there was just enough slack and re attached it and all is now working OK
Posted on Oct 16, 2007
Exact same problems i have with this machine twice same problem ... we took the lid of and the pressure sensor switch was hanging off we attached it hoping this would solve it sadly didnt we then checked it again , then found a small hole at the top . we cut it off then re attached it fastened the clip securely , placed the lid back on switched mains on set the load and WOW it works lol saved us over £35.00 just for the part , would have cost more for the engineer to fix
please note my hubby is an electrician followed all safety as i hope you all will if attempting this
Posted on Jan 09, 2009
  • 3 Answers
Had a same fault code and a also sometimes had the reverse kept filling - soultion was that the small flexible pipe up to the pressure sensor had a crack (fatigue mahine was only 1.5 years old) in it next to the sensor - found it by sucking and blowing down the pipe while it was not connected to the sensor (with the electric off ) - Replacment pipe can be found at any good local washing machine parts shop/store
Posted on Jul 11, 2008
    New Friend:
Error 4E show on my machine the first time of usage
Posted on Jul 14, 2013
4E means there is no water going in. I had this problem as well. Check the manual, there is a trouble section, 4E is defined. Where your water hose connects to machine. Open the top, it is an in/out piece. That probably needs to be: a) cleaned or b) changed. I did the latter.
Posted on Jun 12, 2007
Verifica si tienes suministro de h2o dela red, luego verifica el funcionamiento de las electrovalvulas ( deben medir alrededor de 800 ohmios) ) y por ultimo verificar que esten siendo alimentadas por la tarjeta de control, si no esxiste alimentacion , verificar el estado de la tarjeta de control.
Posted on Jul 09, 2007
  • fernando cruz Jul 09, 2007
    hola de nuevo, debes verificar el estado del sensor de presion del h2o. este es un elemento redondo que se ubica cerca de las electrovalvulas y se conecta con el tambor a travez de una peque?a manguera. si existe corrocion en las conectores del cableado de este sensor se puede generar este mensaje de error, elimina la corrocion.
I have a samsung front loading washer and I am getting error code 4E and cant find book help
Water supply problem causing a 'time-out'.
The 4E (4C) error is displayed on the panel of my washing machine ...
www.samsung.com/.../the-4e-error-is-displayed-on-the-panel-of-my-washing-machin...
  1. Cached
4E (4C) ERROR. The 4E (4C) error indicates that the washing machine has detected that there is a problem with the water supply. The most common reason for this error is a blocked or kinked water supply hose.
There are videos here
samsung front load washer error codes 4e Google Search
Apr 05, 2018 | Samsung Washing Machines
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    2008 Samsung front end loader develops a 4E error
    When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
    1. Turn off the water source to the washing machine.
    2. Unscrew the hose from the back of the washing machine.
    3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
    4. Push the filter back into place.
    5. Screw the hose back onto the washing machine.
    6. Turn on the faucet and make sure the connections are watertight.
    Also, please check the following:
    • Make sure the source water faucet is turned on.
    • Check the water pressure.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
    Jul 12, 2010 | Samsung WF337AA Front Load Washer
    4E error....samsung J845
    Aug 23, 2009 | Samsung WF203ANW Front Load Washer
    4E showing on Samsung Washing Machine
    Apr 06, 2009 | Samsung WF337AAL Front Load Washer
    4e code
    I just checked the Samsung website - you can download the manuals if you've lost them (website below). Not sure what washing machine you have but a 4E on model J1043 (which is the machine I have) says to check the following:
    i_1.gif Make sure the source water faucet is turned on.
    i_1.gif Check the water pressure.
    http://downloadcenter.samsung.com/content/EM/200701/20070109165927703/EN/J1043-01986D_sub7_eng_050708.htm
    Hope this helps.
    Dec 26, 2008 | Samsung WF337AA Front Load Washer
    Samsung washing machine ji453s
    yes i did solve the problem, the water pipe leading to the sensor had a very small hole next to the clip which i disconected cut and replaced, problem solved.
    Sep 17, 2008 | Samsung WF203ANW Front Load Washer
    Samsung Washing machine fault
    The manual says Mke sure the soucre water faucet it turned on. Check the water pressure. turn off water and unscrew the hose from the back of the washing machine. it says to pull out the nesh filter from the end of the hose and ricse it under water until clean with a pair of pliers.also clean the inside and outside of the threaded connector. push the filter back into place, screw the hose back onto the washing maching. turn on the faucet and maike sure the connections are watertight.
    May 15, 2008 | Samsung WF203ANW Front Load Washer
    Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
    3,229 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    Paul
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
