Question about HP PhotoSmart 1215 InkJet Printer
My printer does not startup...
When i plug it in, the power light is already on (its green). when i press the power button, there is no response from the printer. when i attached the usb from to the PC, it says that it cannot detect any printer. i already tried installing it from the CD but it says that the printer is plug and play and must be installed using the wizard.
any help please. thanks.
    President:
  • 8,637 Answers
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 22, 2009
Mg 5350 6502
Solution 1:
  • Unplug the printer.
  • Remove the faulty Cartridge
  • Plug in the printer and press and hold power button
  • Keep it held down. Press Resume twice, and this should reset the fault.
Solution 2:
  • The last cartridge installed may be faulty.
  • Install a new cartridge
Solution 3:
  • When error is indicated, turn power switch off so green light is extinguished.
  • Hold down resume button and hold down power button so both are held down at same time
  • When green light comes on, continue holding down power button and let resume button go, then press resume button twice.
  • Let power button go.
  • Press resume button four times, power button should be released before doing this.
  • Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on.
Nov 21, 2013 | Canon Office Equipment & Supplies
Absorbers full
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 31, 2011 | Canon Pixma iP4500 InkJet Printer
I have a canon mp 140 multifunctional printer. it shows in its display E8 - ink absorber full. The repair was done cleaning already, but still displays the message E8. What can be done? is there any...
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Mar 27, 2011 | Office Equipment & Supplies
Won't respond to computer, light on printer alternates flashing between green and yellow
  1. Start with the printer OFF
  2. Hold down RESUME button and then hold down POWERbutton
  3. release RESUME button
  4. press RESUME twice, then release POWER
  5. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Press 2 times for EEPROM reset.
Thanks, Jo
Feb 19, 2011 | Canon i850 InkJet Photo Printer
Please tell me how to reset my i9950 printer once the ink tank has been cleaned
Try this:
  • With the printer plugged in and powered off, press and hold the "Resume/Cancel" button, then press and hold the "Power" button. Do not release the buttons. The LED will be gree.
  • While holding the "Power" button, release only the "Resume/Cancel" button.
  • While holding the "Power" button, press the "Resume/Cancel" button 2 times, and then release both the buttons.
  • When the LED light is green, press the "Resume/Cancel" button 4 times.
  • Press the "Power" button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
  • Press the "Power" button to exit service mode.
Thanks, Joe
Feb 05, 2011 | Office Equipment & Supplies
How can i reset my canon pixma ip1300?
1. turn off canon ip1300
2. hold down resume button then press power button
3. keep holding down power button and let resume button go
4. press resume button 2X then let buth button go
5. green light will flash and then stop blinking
6. when gree light are solid press resume button 4X
7. press the power button, your printer canon ip1300 will turn off, if no press power button ance again
8. press power button to turn on printer, and your printer should response normal
i hope this helpfull
thanks for using fixya
Jan 27, 2011 | Canon Office Equipment & Supplies
Hi Everything is plugged in and power strip is on, but the printer just won't turn on. Is is a power supply thing? Worth fixing?
If it is the power supply, not worth it....
Try an EEPROM reset:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 23, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Wont print error 5100
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Turn off printer by pressing the power button
press the Resume button and press Power button.
Keep holding down Power button and release Resume button
Press Resume button 2 times then release BOTH buttons
Nov 19, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Blinking ornge light
reset your printer if you try you can i will give you 6 tips
Here this manual way step by step to resetting waste ink counter on printer canon iP4000.
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. Do not release the buttons. The LED light should be green to indicate that a function is selectable.
  2. While holding the Power button, release the Resume/Cancel button, do not release the Power button
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  4. When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  5. Press the Power button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
  6. Press the power button to exit service mode.
see you can where is blinking orange light
Sep 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Printer will not respond
Canon S330 Turn off printer
Jul 22, 2008 | Canon S 330 InkJet Printer
HP PhotoSmart 1215 InkJet Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
