Question about Radio Shack Pro-2096 Base Scanner
PRO-2096 digital scanner display lines from top to bottom
We bought it at the radio shack store in salem, n.h. and 15 days before the warranty went out, the display totaly went out but you could still hear the action but the display was blank.
My grand mother brought it to the store and the MGR exchanged the display for the bad one. (that was good)
Now just over 34 days, the display on the NEW one has black vertical lines from top to bottom.
Is this a common thing with radio shack scanners.
My grand mother paid FULL price for the scanner for my grandfather who had cancer. He passed away and my grand mother is stuck with a $500.00 useless scanner. Can anyone help me fix this scanner.
Thank you all.
Bob
  • 1 more comment
  • rob8407 Jan 15, 2009
    Thanks for the reply !
    I tried all of that and still no change.
    The scanner works fine other than seeing whats on the display.
  • Anonymous Jan 18, 2009
    I have had my scanner for 4 months and worked great. Then turned it on one day and screen was blank but still heard action. I unplugged from power for 5 min and plugged back in and screen came back on.
  • rob8407 Feb 05, 2009
    Does anyone have a schematic, service manual for this rad shack black hole radio
  • 120 Answers
You can push on the display with your finger and see if you notice any change, if so it is probably a bad solder joint or crack in a circuit trace on the printed circuit board. Also with the unit unplugged you can open up the case and check for loose plugs by removeing them and then plugging them back in, then plug the scanner back into the wall outlet and turn it on to see if that helped. The voltages inside are low except where the power cord goes into the unit, at the fuse, and on the primary side of the transformer, so dont touch these areas unless you know what you are doing.
Posted on Jan 15, 2009
  • rah1379 Jan 15, 2009
    are you good at soldering? It could be the display or the ics that drive it. You might find another one of the same model on ebay for parts or buy the parts you need new from some of the electronic distributors online.Often its not the ics but a transistor or other component that regulates the power that goes to the display. Try searching online for a schematic or service manual and then we can see what parts to check.Working on scanners can be hard sometimes because they use surface mount components that are really small but with good eyes, a steady hand, and a little logic it can be done.I will see if i can find any service information on it, i have lots of websites saved, and books on this subject.
Pro-2096 Digital trunking mobile/ base scanner
hello,
Open the mobile and the refix all the connection inside maybe some loss connection make it faulty.
best ,
melnavz
Apr 29, 2008 | Radio Shack Pro-2096 Base Scanner
I have a radio shack pro 2096 that worked for years came home one day and no digital channels come thru anymore haven't touched a thing?!!
They have probably 'rebanded'- meaning that they moved the control channels. Go to radio reference dot com and see what the control channels are. IF they moved the 3 or 4 control channels and alternate control channels to the 700MHz range, then the PRO96 and PRO2096 probably cannot track it anymore and you will need a newer scanner from Uniden Bearcat or from Whistler. Let me know if there's anything else I can do to help.
Aug 21, 2013 | Radio Shack Pro-2096 Base Scanner
My pro 2096 has no volume
  • You have to uses external software on this scanner.
  • Custom GRE/Radio Shack Frequency Table
  • Table 1 ---
  • With WIN96 software for the PRO 96/2096 scanner:
  1. Prompt "MULTI TABLES"
  2. Prompt "EXTENDED TRUNKING TABLES"
  3. Do not prompt any "STANDARD PLANS"
  4. "CH LOW" 8192 "CH HI" 12287 "BASE FREQ" 453.0250 "OFFSET" 8192 "STEP" 12.5
  5. "CH LOW 12288 "CH HI" 16383 "BASE FREQ" 450.0000 "OFFSET" 12288 "STEP" 6.25
  6. Clear all other trunking tables, and prompt "OK"
  7. Now save your file.
  • Custom Uniden Frequency Tables
  • Table 1 -
  • Base: 452.0000
  • Space: 12.5
  • Offset: 380
  • Table 2 -
  • Base: 460.0000
  • Space: 12.5
  • Offset: 570
  • If you have not done this then you will receive no audio on digital reception.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 06, 2011 | Radio Shack Pro-2096 Base Scanner
Unlock code all frequencies for pro 2096 digital scanner
Sorry, but there is no magic code that will "unlock" your Pro-2096 or any other modern scanner. If you want a scanner with wider frequency coverage, you'll need to purchase one that comes that way from the factory.
Bill B.
Listening in since the 60's
Oct 07, 2010 | Radio Shack Pro-2096 Base Scanner
Display keeps going out of the pro 2096, it was repaired once,,,, is there any simple fixes to this?
Unfortunately there is not. This is one of the "gremlins" that plagued the 2096. From what I have been told by other 2096 owners, the problem comes from a fault where the ribbon cable (or flex) joins to the LCD display. You may want to try opening the scanner and checking the connection. Sometimes gently pressing on the joint with a pencil eraser can re-establish the connection.
Sorry I don't have a "quick fix" for you, but hopefully this will help steer you in the right direction for troubleshooting.
Feb 22, 2010 | Radio Shack Pro-2096 Base Scanner
My pro-2096 does not display any letters or
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Jan 22, 2010 | Radio Shack Pro-2096 Base Scanner
Looking for a part number for a
Here's a link to the parts list for your scanner. Parts can be ordered online or from your local Rat Shack store.
http://www.icomamerica.com/en/support/PartsAndService/default.aspx
Dec 19, 2009 | Radio Shack Pro-2096 Base Scanner
This is happing to most of the units and radioshack wont admit it.
Apr 18, 2008 | Radio Shack Pro-2096 Base Scanner
Backlit display and keypad fading
On the Driver Board of the Display,There should be Some Capicitors,They will tend to Change Value Causing the Display to Go Bad Also since its in a Car look for Bad Solder conns around the ribbon Cable that goes to that Board Goodluck TTech
Jul 06, 2007 | Radio Shack Pro-2096 Base Scanner
Radio Shack Pro-2096 Base Scanner Logo
277 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
