How do i get my carousel to work
Carousel will not move
    President:
  • 412 Answers
If you can provide more information on the projector (Brand and Model name / number) and a more detailed description of the failure, I will try to assist you.
Posted on Nov 22, 2013
My kodak carousel auto focus 760 carousel does not move but the projector makes a noise when I press the buttons how can I get it to move
Your Carousel 760 Slide Projector is about 45 years old. One of the problems I have seen as Carousel Slide Projectors age is that the plastic parts in the projector get brittle and break. Given your description of the observed condition is that probably either the gear on the focus motor shaft or the gear it interfaces with (or both) that is broken. Given the age of the machine, parts will be tough to locate. Try: www.micro-tools.com
for the best chance to locate those parts. Good Luck !! Jim
Sep 07, 2013 | Kodak Carousel 4600 Slide Projector
My Kodak Carousel 650H has a stuck slide and the tray won't move. The stuck slide is lined up with the "gate index." I tried releasing the tray but only one side of the tray releases. The...
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
Jul 17, 2011 | Kodak Carousel 4600 Slide Projector
The lever that drops the slides gets stuck in the 'up' position when the carousel is on the projector but it works fine when there is no carousel attached. When it gets stuck you have to take the carousel...
If you are using a 140 tray with older slides, that's very logical! Over time, slides develop a "side-to-side curve". Because the Carousel 140 tray stretches the design limits of the projector to be able to accurately return the slide to the tray, the slightest bend or "dog-ear"(the fraying of the corner of the slide) will cause exactly the problem you're having. If you have a Kodak 80-Slide tray, try it. Chances are that it will work fine. If it does work fine, then you have 2 options: 1. Move all your slides into Carousel 80 Trays.
2. Have your slides re-mounted (that is, have the paper mounts replaced).
I hope this helps !!
Feb 14, 2011 | Kodak Carousel 4600 Slide Projector
Error code 505?
"505" indicates a motor error, meaning that a motor in the carousel is unable to turn. There are two motors in the carousel: one moves the disk carrier and the other moves the eject arm.
you need to send to repair, is a non resetable error
Jan 06, 2010 | Ziotek Media Carousel Plus, Beige Burner
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
Kodak Carousel Projector 760 H, Carousel will not move
Given the age of your Carousel 760H, the most likely cause is a broken "Link". The "Link" connects the cycle solenoid plunger and the slide change mechanism. The "Link" is made of plastic and gets brittle & cracks over time, rendering slide change non-functional. Parts are still available (www.micro-tools.com), but this is an involved repair is best left to a factory trained technician with a service manual.
Apr 05, 2009 | Office Equipment & Supplies
CD player does not rotate
Hi there.
There could be a couple of reasons. I doubt very much that it is due to the lens. First thought is that it is probably the locking mechanism. If you look at the cd loading mechanism, there is a small plate with a locking tab that moves into place to hold the carousel still when the unit is loading a cd. This plate slides along the bottom of the unit between the cd loader and the carousel.
Secondly, it could be that the carousel is jammed on the rotating platter that it moves on. A couple of screws and it should come out - be carefull not to bend anything!
Thirdly, check the stepper motor that turns it - but I doubt this is the problem either as you said you couldn't turn it by hand either. You will need to remove the carousel to do this.
Good Luck !
Feb 10, 2009 | Sony CDP-CX235 200-Disc CD Changer
Fatal Error 17H - toner cartridges will not advance
Open the front door and remove the toner bottle.
Look near the colour toner carts and you will see a small round hole. Jam a screwdriver in that hole and the carousel will rotate freely. Move the carousel round and remove each toner one at a time.
Oct 10, 2007 | Konica Minolta magicolor 2300DL Laser...
k24674
jasbo
jasbo
