Question about Electric Mobility Health & Beauty
I have a Sterling Micro 3 wheeled scooter. When I turn the throttle off the scooter carries on rolling and does not stop like it used to. Anybody know whats gone on my scooter?
  • Electric Mob... Master
  • 1,263 Answers
Hi, Okay first of all the throttle pot may not be returning to the central position any-more normally this causes a error condition, a bleeping sound, the other thing is the brake is not working correctly , it be worn or not releasing , Do you hear a click when going forward or backwards ?, Some Sterling's work with the brake disconnected so check the wiring.. remember 24v is applied to the electromagnic brake to release the plates allowing you to move, keep me posted please. Gewiz
Posted on Dec 06, 2012
  • 32 Answers
SOURCE: Reverse on 3-Wheel scooter won't work.
throttle pot, cheap fix
Posted on Apr 03, 2009
gewiz
  • 1263 Answers
SOURCE: when turning on the charger for a bec sterling 3
what the charger is showing that ?, it has a digital display ? please supply more information
Posted on Jun 13, 2009
  • 103 Answers
SOURCE: charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Posted on Jul 23, 2009
bunnydawg
  • 5158 Answers
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Posted on Sep 08, 2009
Testimonial: "thanks for the answer so quick il phone them tomorrow"
  • 23 Answers
SOURCE: would like a owners manual for a sterling Elite XS
I couldnt find the 3 wheel version, but the four wheel is in pdf at
http://www.scootamart.com/media/manual/elite-xs-4-mobility-scooter.pdf
hope this helps
Posted on May 06, 2010
Testimonial: "thanks not the exact model but will be of great help"
Stopped going when free wheel lever accidently pushed forward. Put back. Still wont start.
Check for error codes. Move free wheel lever in and out a few times in case the brake micro switch is not making correctly.
Check speed control is not turned down low.
Mar 21, 2015 | Pride Celebrity X 3 Wheel Scooter
I REPLACED THE THROTTLE CONTROL ON MY PRIDE V10 SCOOTER AND RIDING IN GRASS IT STOPS AND BEEP 6 TIMES
6 beeps =
Throttle lever (pot) is not in center position. Return throttle lever
to center position, then turn scooter OFF then ON.
Mar 07, 2015 | Pride Victory 10 3-Wheel
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Feb 07, 2015 | Razor E100 Electric Scooter
How do i fix a throttle on a sterling sapphire mobility scooter
The Sterling Sapphire is not sold in the USA so, you may want to verify this information with a local technician however; 7 flashes or beeps is commonly a throttle issue. When the problem starts and you have been driving for awhile, ensure the throttle lever is in the stop position, turn off scooter, wait 10 seconds and turn scooter back on. If that does not clear your problem: There should be two set screws (very small) that you can tighten with an allen wrench on the throttle lever. Make sure those are tight.
If this is a continuous problem, you may need a new throttle potentiometer.
Apr 29, 2014 | Health & Beauty
Why does my scooter stick in reverse when i push forward & stop when i push reverse
Hi, it could be that the throttle has turned around within the throttle lever therefore no longer centre, look under the throttle stem, you should see a cross head now that should be in align with you when sitting on the scooter...you will need to loosen the throttle and realign if that is the case...
Regards
Rob
www.gewizrepairs.co.uk
Apr 24, 2014 | Pride Mobility Products Pride Mobility...
Charging sterling elite 2001 scooter batteries
Jul 20, 2009 | Pride Mobility Products Go-Go Elite...
Electric scooter support
Most electic scooters cruise well because they use the same type of wheel that are used by inline skates to minimize rolling resistance. The wheels are also about three times as large as skate wheels so they glide much better than smaller inline or skate wheels. Accelerate the scooter and cover ground.
Aug 27, 2008 | Amigo HD450 3 Wheel Scooter with 33AH...
Health & Beauty Logo
135 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
