Question about Haier Portable DVD Player PDVD7
Ac Adaptor does not charge DVD Player
I plug my ac adaptor into the side of the dvd player and if you hold the cord just so; the light will light up as charging; otherwise it does not charge. I do not know if it is bent on inside of dvd player or the cord is messed up. Can you order a new part fo this?
  • Anonymous Feb 17, 2009
    I am having a problem ac adaptor it doesn't fit anymore something is wrong with the adaptor or the player it self. How would I go by getting it fix.
    I am having problem with my ac adaptor doesn't fix anymore something is wrong with as adaptor or the player how we go by getting it fix.
    Problem Solver:
  • 9 Answers
I am well aware of what you are experiencing with your DVD player power connection. What has happened is that the power connector on the back of the unit is actually mounted on a circuit board by soldering connection tips. Unfortunatly it is not the best design because after the power cord has been plugged in and removed a few times it weakens and loosed these soldered tips and it nolonger has a good connection on the board. Short of removing the board and re-soldering the connection there is little else that can be done. Your expertise with a soldering gun depends as to whether or not you are successful in re-establishing the connection. It seems to me that if it is re-soldered, then it is just a matter of time before it breaks loose again and the board will damage after so many breaks. What I have done to repair this is to try and find a female connector like the one mounted to the board except find on that is on a cord instead. Solder the wire in the cable to the board and attact the cable to the case in a fashion that when the wire is being connected for charging that it won't pull the soldered connections out of the board. Sure, you will have a short piece of wire hanging from the rear of the unit, but this way you won't have to be concerned with the cable detaching and loosing your ability to use the unit with an AC adaptor or for charging the battery. I hope you can find a remedy for this that works. If you stumble across a better Idea Please let me know. best of luck!
Mike
Posted on Jan 19, 2009
I have a durabrand portable dvd player and I can not get the battery to recharge. I have unplugged it from the DC in jack and the cord from the wall. Reinserted the battery, then inserted the AC adaptor...
If your portable DVD player work with the AC power adapter in the wall outlet.100% the litium battery doesn't take any more holding charges.The litium battery should last u about 2 years with minium usages 2-3 hours a day.But that the DVD player and the litium battery must keep in very well conditon and wheather wise.Not in the heat or cold and the humitnity well shorten the lituim battey life very quickly and also could damages the portable DVD player too dosen't matter how much u used it.Tries webites like Amazon.com,Partstore.com,Ebay.com to buy a new litium battery or a compatible one.
Aug 25, 2011 | Durabrand PDV-709
My venturer PDV880 won't charge or turn on?
Check your ac adaptor to see if it has voltage with a voltmeter. Replace the ac adaptor, otherwise you need repair of your dvd portable player.
Sep 11, 2010 | Venturer PDV880 Portable DVD Player
How do I charge the battery pack that attaches to the back of the player?
did you get a ac adaptor with your player? if not you can get one on ebay the # is ADPV26A 20.00 and it plugs into the side of the player to charge the battery
Aug 15, 2010 | Mintek MDP-1815 Portable DVD Player
Missing AC adapter
If you look at your DVD player, it will have information such as 5V, 2.2A. This information will help you choose the correct AC adaptor. Head over to The Source, FutureShop, BestBuy, etc and bring the DVD player in.
As for a universal AC adaptor. These range from $15 - $50. Just make sure the one you get has the correct plug and voltage/amp range and polarity for it. The salesperson should be able to help.
Here is a picture of such an adaptor. This is a picture of the back of an electronic device, showing 5V and the polarity. If your player has no information with the AC port, you will need to look for a label on the device with this information.
Dec 01, 2008 | Mintek MDP-5860 Portable DVD Player
I need a AC adaptor and a AV cord.
Take your unit into Radio Shack. They should be able to match one up for you.
Jul 12, 2008 | Mintek MDP-1030 Portable DVD Player
Haier Portable DVD Player PDVD7 Logo
162 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
