Question about E-Machines eMachines Desktop PC
Win 7 e5800 64 bit stuck in 32 bit will not load 64 bit op disk code not compatible loaded before. will load 32?
  • E-Machines Master
  • 27,725 Answers
If your computer is 5 years or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Dec 07, 2012
2 Suggested Answers
  • 85 Answers
SOURCE: Trouble updgrading to Windows 7
All is fine up to that point into the setup because it's generic up to that point. The chipset on the motherboard is not supported by windows 7 at this point. It is not the harddrive that's not compatible but is the chipset in the board that supports the operation of the drive. The compatibility wizard is causing all kinds of problem for MS. It could just be one little chip in the board that is hanging up your install. There are many topics if you Google Windows 7 forced install. People are saying some forced installs are working and some are not. Good luck
Posted on Jan 31, 2010
Testimonial: "WOW...thanks! I thought for sure I was going crazy. At least with your info I'm now looking in the right direction. Maybe if I update my bios?"
I have a Centrios Digital Film Slide Converter. Software says it is for windows vista.. but won't load.. something about 32 bit or 64 bit.
Apparently not :>(
Compatible with Windows XP, Vista and Mac OSX 10.4.3 and above.
Treat yourself to a new one. The old one is for 32 bit and you have Win 7 - 64bit.
Barcode Scanner Handheld Scanner
Aug 20, 2015 | Cameras
Install win 7 on 32 bit machine
Upon loading, there is a selection prompt. Select 32 bit configuration. There is also a Win 7 which is 32 bit, use this one if you have it.
Mar 08, 2014 | Dell PowerEdge 400SC Server
Qc848enu-Compatibility issue in Win 7 64 bit
Hello
It depend on the CPU if it is 32bit or 64bit. Windows 7 64 supports 32 bit software and 64 bit I suggest re-installing the software. It depend on the software if they have 64bit and 32bit you should install the version your PC is. Sometime 32 and 64 bit are embedded in software.
Feb 05, 2014 | Logitech qc848enu.exe
Cannot load software for Vista
downloading software for windows 7 from HP website will solve the problem but it should be of same 'bit' that is if your vista is 32 bit then go for win 7 32 bit or if your vista is 64 bit then go for win 7 64 bit.
Oct 30, 2013 | HEWLETT-PACKARD Office Equipment &...
Video controller for windows 7
From Microsoft:
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
IF your Notebook meets all other specs you would need the the above device/driver. which may or may not be compatible with the Toshiba, which was pre loaded with Windows XP.
Thanks!
Jimm
Nov 22, 2012 | Toshiba Satellite A40-S161 Notebook
Cannot get a driver to load off line. 64 bit windows7 no disk
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 964 Photo All-In-One Printer owners thread (W7)
Rick
Aug 14, 2011 | Dell Photo 964 All-In-One InkJet Printer
Please tell me which driver is installed for display compatible for win 7 64 bit
http://www.acersupport.com/
go to this page, chose your acer model chose your operating system (win 7 64 bit) then chose dispaly driver then click download, and you got driver that compatible with your laptop
i hope this helpfull, please rate very helpfull or helpfull if you think this helpfull
thanks for using fixya
Jan 20, 2011 | Acer eMachines 350-2074 Netbook
Trouble loading factory default backup disks
try the 32 bit windows 7, 64 bit has compatability issues.
Apr 22, 2010 | Acer Aspire M3100 Refurbished Desktop PC -...
Can't load qx3 driver in 64 win 7
The QX3 is not compatible with Windows 7 64 bit, only 32 bit.
Jan 05, 2010 | Intel Play QX3 Monocular Microscope
E-Machines eMachines Desktop PC Logo
27 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
