Question about Bose Wave Radio
Power surage after power outage, radio wont turn on-or work! can it be fixed?
BOSE ACOUSTIC WAVE SER. NO. 023583C22841573AC
  • 6 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
  • 20 Answers
SOURCE: Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Posted on Dec 31, 2008
BillB-SA
  • 2761 Answers
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Posted on May 19, 2009
cjackHD
  • 71 Answers
SOURCE: How can I get the Bose Wave radio to work in Europe??
Yes. The tuner spacing option should do this. If it's a Wave Music System or a Wave Radio II, go into the 'setup menu' and look for 'tuner spacing'. -If it's older, you may want to call Bose for a solution.
Posted on Jun 12, 2009
DigidocTN
  • 22 Answers
SOURCE: Bose wave radio will not power on. used to work
I repaired mine recently. Check transistor Q4 for an e-b short. The replacement costs less than $1.
Posted on Jun 27, 2009
Buttons to change time not working
Bose Support - Owner Manuals
worldwide.bose.com/axa/en_au/...manuals/page.html
Bose CorporationFind Bose product informations for headphones, multimedia speakers, stereo ... IV ·Wave® SoundTouch music system IV · Acoustic Wave® music system II ... manualsfor home theatre systems and speakers ... manuals for stereo speakers ...‎Music systems - ‎Home theatre systems and ... - ‎Headphones - ‎Multimedia speakers
[PDF]The Bose® Wave® Radio Owner's Guide
products.bose.com/pdf/customer.../wrv3_guide.pdf
Bose CorporationThese CAUTION marks are located on the bottom of your Wave radio: ... the user to the presence of important operating and maintenance instructions in this.
Nov 01, 2015 | Bose Wave Radio
Lost remote control for bose wave model number AWRCC1 will the additional bose acoustic wave music system remote control work
Check this site to get setup codes and model number of a suited universal remote control. It has many details you want. Check this site too.
Apr 21, 2013 | Bose Wave radio remote control - Graphite...
One speaker doesn't work on my bose wave radio/cd?
I can only get one speaker to work continuously. The other works intermittently. If I move the power cord a bit, I can sometimes to get the one "bad" speaker to work. When it's working, the speaker sounds fine. This is driving me crazy. The power cord is new, so I think it has something to do with the power supply. The unit is a '95 Bose Acoustic Wave CD-2000.
Nov 04, 2012 | Bose & Wave& Music System
After a power outage, my Bose radio went to military time. I've tried to re-start it by unplugging, re-unplugging, etc. Help!
To switch between 12hr and 24hr format:
1) Turn your Wave Radio off
2) Press and hold "Clock Set"
3) Press "On/Off" to switch between 12hr or 24hr format.
Dec 27, 2010 | Bose Wave Radio
Alarms will not work
Hi. Often following a power outage there is a power surge when the power is restored. If you do not have your Bose protected by plugging it into a surge protector, an internal fuse will blow to protect the rest of the radio. Once that fuse is replaced you will be back up and running. J.
Jul 09, 2010 | Bose Wave Radio II
Would like to connect Bose Acoustic Wave II sustem
If your TV have audio output ( RCA or any kind ) then you can hook that up ( you can buy the cable from radio shack ) then to BOSE audio input w/c is the AUX input.
Apr 26, 2010 | Bose Wave Radio
I have a bose acoustic wave,single disc model CD-3000. The CD is not working,the CD spins but won't play. The radio works great.
Had the same problem. Mine the cd drive got out of alignment. Sorry to say the fix is to have it replaced. BOSE will do this for about $150. Typically this includes the one year service agreement, a full system "tune up" and a one year warrenty.
Call BOSE and they will take care of you.
Jul 29, 2009 | Bose Acoustic Wave music system II -...
Recorded audio CD will not play
Most likely the recorded format is wrong and that is the cause.
May 05, 2017 | Bose Wave Radio
Bose Acoustic Wave music system popping speaker
Had the same problem on the same machine 15 or so years ago...took it to the Bose factory shop in Framingham (or real close )Massachusetts, and they fixed it in 20 minutes...cost around $50...at the time they said it was a real common problem, and an easy fix.
Jan 20, 2009 | Bose Acoustic Wave music system II -...
Power
There's a line fuse on a circuit board inside the radio. CAUTION: disconnect the set from its power source before you open it up or start poking around inside it. If you're lucky, all you will need is a simple fuse replacement. The sets are, however, notorious for "blowing" power transformers. If the fuse is not the problem, you will likely need to send the set to Bose for repair. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Sep 16, 2008 | Bose Wave Radio
Bose Wave Radio Logo
50 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
