Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Timer is 45 min. and come back later and it has 120mins.on the timer.
  • Maytag Master
  • 8,220 Answers
Have not came across one of these yet but I have a service manual:
Repair Manuals 2
Posted on Dec 05, 2012
  • 3 more comments
  • bwest1963
    bwest1963 Dec 05, 2012
    thank you anyway. it does not do it all the time.but i will not leave home with it on. have a great day.
  • Dan Webster
    Dan Webster Dec 05, 2012
    If that is the model with 2 belts you may have this problem: http://foggyfacts.blogspot.com/2012/07/n...
  • Dan Webster
    The nut that hold the small belt pulley on the motor comes off and the blower stops. Incredible engineering flaw IMHO.
  • Dan Webster
    https://docs.google.com/file/d/0B5If-wTg...
  • Dan Webster
    The google docs link is the manual
I turned the knob for 45 min drying time and it was still running 3 hours later and no heat now.
Very likely you now have 2 problems.
First, the timer has "failed", and is not advancing.
That should require a new or used timer.
Those are available many places, such as "Sears Parts Direct" (this web site will give you the part number of the part you will need), Amazon, or e-bay.
Next, you may or may not need some part that will let the dryer heat.
There could be one of about 6 or 8 parts that have failed, each one will need to be checked with an electric meter to find that faulty one. Again, "Sears Parts Direct" will help you with the part number when you need a part.
God bless your efforts.
Mar 21, 2016 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Engine shuts off after driving 45 min when parking in reverse.But 15 min before this engine and slippery road icon comes on.2 hrs later car starts and drives normal then shuts off again 45 min later.
most commonly found problem relates to an electronic component heating up and shutting down. Have you checked to confirm there is fuel pressure when the vehicle shuts off. Is the check engine light on. Have you checked codes ? I suggest hooking up a fuel pressure gauge and letting vehicle run till it shuts off while monitoring the fuel pressure. If you loose fuel pressure, next step is to confirm there power going to the pump, if there is power going to the pump with no fuel pressure replace pump. Another suggestion would be to check for spark when vehicle stops running to eliminate an ignition problem. good luck
Aug 17, 2015 | 2008 Toyota Highlander
How stop sprinklers from starting over
You only program the first zone to turn on at a specific time. The rest of the zones go in sequence.
Aug 22, 2014 | Orbit 6 Station Indoor Dual Program...
The dryer itself works fine, the timer goes too fast, if I set it to 150 mins it will be back at zero in about 10 mins probably less, this has only just started happening, I have always used 30-45 min
This is a mechanical timer that has an old fashioned timer spring inside. The spring is corroded or broken. If you want to save a buck, With the breaker supplying power turned off, Open the panel and look for an opening in the actual switch and, using the narrow tube that comes with CRC or WD40 spray and lubricate it. Then exercise the switch while the power is off. Second choice...order the part from the manufacturer!
Dec 28, 2012 | Dryers
I've recently purchased a FirgidAir laundry dryer (Model FCED3000ES ELE). The company installed drying time is 45 min that doesn't dry load well. I want to extend drying time to 1hr. Could you...
If you are looking to increase the time, the dryer comes with additional wheels for the timer. The one with the least number of posts is the longest time. I forget if it has two or three posts. You just remove the timer from inside the coin box and slip off the 45 minute wheel, and slide on the 1 hour wheel, and then put the timer back. Very simplet.
Jun 14, 2011 | Frigidaire FCED3000ES Dryer
1993 toyota camry 4 cylinder runs 15 mins and shuts off and wont start back up until 30 - 45 mins later
This could likely be a problem with your cooling, Next time you turn your car on pay attention to the temperature gauge and see if it rises above the norm.
May 02, 2011 | 1993 Toyota Camry V6
Takes 2 hrs to run a 45 min cycle
defo a heating element fault or an ntc fault. More likely to be the element though.
Mar 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Car slipped out of DRIVE position only revving the RPM's.
Tranny low on fluid. When you stop or turn it all goes to one side causing the problems.
Jul 28, 2009 | 2003 Chrysler 300M
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
78 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
