Samsung tv keeps switching off as soon as it's switched on what should I be looking for to fix it?
I've taken the back of the tv off and had a look at all of the capacitors and none of them are bulging or leaking, is there anything else I can take a look at myself? What should I be looking for? Don't want to pay for a technician if I can fix it myself. Any help is much appreciated.
  • 933 Answers
The tricky part is that a bad capacitor doesn't always have a bulged top. sometimes they look perfectly normal. I would suspect a fault with either the power supply or main board. You don't have to pay to have a technician fix it, but pay a technician to properly diagnose the set. Once you have a proper diagnosis, you can then buy the part and install it yourself and save money.
Posted on Dec 06, 2012
  • 192 Answers
SOURCE: Samsung hdtv tv monitor no power no light
This is just a shot in the dark but it's possible that your power supply uses a full wave rectifying bridge made up of 4 diodes to convert the AC to DC. Check these diodes out to make sure they're not shorts or opens. You can use an ohm meter. They should look like a low resistance from their anode which is the + terminal to their cathode which is the - terminal and a high resistance the other way around. If your power supply has a little starter relay in it you can also check to see if the relay coil has been blown. It should look like a low value resistor. Unsolder and replace anything that doesn't pass these tests.
Posted on May 14, 2009
  • 2318 Answers
SOURCE: Samsung 32'' LN32A330J1 not turning on
Check this website to find the part(s) you need.
Posted on Dec 29, 2009
Testimonial: "The link provided by the expert was excellent. I was able to find the product easily. Replaced the capacitor and thanks !!! the TV is working again"
  • 304 Answers
SOURCE: I have a Samsung LNS3251D 32-Inch LCD HDTV , that
In almost all cases where the set is taking a long time to turn on and then turning off it will be the Power Supply board that will have bulging capacitors, usually three to five. Look on the upper right side of the Power Supply and look for any blown caps. You can replace these caps and you will be fine. Now the other cause can be the Power Switch is shorting out. You can disconnect the the Power Switch but not the IR sensor and then turn ON the set with your TV remote and see if this stops the problem. If you are not skilled in component level repair on the Power Supply board then buy a new Power Supply board and install it.
Posted on Apr 16, 2010
  • 304 Answers
SOURCE: My Samsung LE23R8 TV keeps switching itself on.
You either have a bad Power Supply board or the front Power Switch is shorting out. Have a tech check out.
  • 1156 Answers
SOURCE: I have an element TV
power supply board is dead, if you know basic electronics' and soldering you can handle it ? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.
Good luck in solving the problem.....
Posted on May 17, 2011
Screen size and resolution keeps changing while I work.
some tv devices are set by default to auto adjusting, look in tv's setup and adjust the resolution manually.
Feb 23, 2013 | Toshiba Computers & Internet
Singer confidence quilter beeps 8 times won't sew
http://www.singerco.com/uploads/download/549_7469_efs.pdf
http://www.singerco.com/uploads/download/683_7469_efs.pdf
here are 2 links for a free manual, you can choose which one you need
try changing the needle
if you just bought the machine,, you may have to take it back & get
another one
Jun 08, 2012 | Singer 7422
TV - Samsung LE32A457C1D White picture
This happen on all inputs including rear ones?
May 24, 2012 | Televison & Video
I prefer to keep Yahoo Classic?
check & see if this will work for you
Login to your account
After you've logged in
you'll see your email folders on the left side
What's new and inbox tabs in the middle
upper right side of the page look at the three links
Click OPTIONS and when the drop down menu appears
choose MAIL CLASSIC
A dialog box will pop up with two choices -- SWITCH TO YAHOO MAIL CLASSIC
If you're sure you want to switch click the first option
your computer's speed & your internet connection the switch may take several seconds. When it's done you'll be back with Yahoo Mail Classic
Sep 20, 2011 | Computers & Internet
I've bought a new samsung pl121 camera & taken a
Your camera is obviously defective. It may have been a return and resold to you. In any case, you should return it immediately....this problem will only get worse.
Aug 20, 2011 | Samsung Cameras
My LCD TV Series 530 keeps on blinking and would not turn on. why does it keep doing that?
I've experienced similar issues with a 42" Samsung LCD TV. From what I've read online, I believe it could be a problem in the circuitry of the power supply. Apparently, Samsung used under rated capacitors in the power supply and the result is a turn on delay or blinking on and off. If this is the case, then the capacitors would need to be replaced to fix the issue.
Aug 07, 2011 | Samsung Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
