Question about Microwave Ovens
Russellhobbs microwave model RHM2018 will not heat liquids up
Milk did not heat up today every thing seemed to be working light on plate going round timer working all seemed ok but milk came out cold
  • 4 Answers
SOURCE: Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Posted on Nov 23, 2007
  • 1214 Answers
SOURCE: Microwave hums
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Posted on Jan 24, 2009
  • 686 Answers
SOURCE: Panasonic microwave oven model NN-T774SF remain on
buy new one magnatron is bad
Posted on Feb 26, 2009
  • 234 Answers
SOURCE: microwave doesn't work
There is a reset somewhere around the top or close to heating element
Posted on Mar 13, 2009
ginko
  • 19396 Answers
SOURCE: kenmore microwave model 665.68681891 runs but won't heat
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
I have a Russell Hobbs RHM2018 microwave oven with grill and the turntable will not stop going round and the light stays on until I unplug it? Once plugged back in it carries on in the same way? If I
The switch for the turntable does not disengage anymore. Could be a relais, could be an electronic switch. When opening the door, a second switch, in series with the other one, connected to the turntable motor disengages, stopping the motor. The light is switched on, because you opened the microwave. Perhaps you never noticed this, but it is the normal way that should work.
Aug 31, 2014 | Microwave Ovens
Does not heat everything else works ge microwave oven JNM1851SMSS
It will be one of three things, magnetron, "heats food" high voltage diode,"sometimes cracks" or the high voltage capacitor, "usually shorts"
Mar 23, 2012 | General Electric JNM1851 1100 Watts...
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
Microwave Quit Heating
The Magnotron goes out on many of the lower priced models in the first yr.,(and some of the higher end ones too!) As the components there do most of the hard work. Better to just find a recycler who takes them and scrap it.
As for the replacement that sounds like an excellent idea!
Sep 02, 2017 | Emerson MW8778 Microwave Oven
Microwave seems to work but doesn't heat up
HI, when the Magnetron becomes unstable, the microwave will not heat anything. simply replace the Magnetron. This device creates the heating action and it is damaged and not functional at this time.
Jun 01, 2009 | Sharp R-1870 Convection/Microwave Oven
Microwave problem - my Kenmore model 62359 won't heat
hi mark,
actually, we didn't find any solution for the problem. we just bought a new one.
thanks,
cency
Nov 13, 2008 | Microwave Ovens
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
