Question about Canon PIXMA iP1800 Printer
What does Canon Pixma iP2600 printer error message 5201 mean?
  • 8 Answers
SOURCE: pixma ip500 error message 5C00 - what does it mean?
I have the same message and print haed does not move at all.
I will pay for it to be fixed next week (after Easter) and let you know the cause.
Cheer's Steve
Posted on Mar 22, 2008
  • 92 Answers
SOURCE: I HAVE A PIXMA ip2600 canon printer need win me softwear to run
It says that this printer is not supported on windows 98, but they do list a driver and software package at the following link. You might want to try it.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=16278
I hope this helps, Good luck.
Posted on Sep 13, 2009
SOURCE: canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
Posted on Dec 06, 2007
pineworks
  • 4041 Answers
SOURCE: My canon ip2600 printer has a paper jam error, but there isn't.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
SOURCE: Pixma iP2600 Photo Printer InkJet: Canon iP2600 error codes...
my printer will not print out anything. it starts to but the paper never enters into the printer, it is almost like it is jamed but it isn't.
The message says there is an error, push resume and try again.. same thing, it starts to push paper thru.. acts like a jam.. same message.. but paper is not jammed
Posted on May 19, 2010
Canon iP2600 Printer yellow light flaxes message says an ink cartridge is not installed properly
have you tried cleaning the printheads ?
There is an option for cleaning head in printer's properties : select this and you will be able to clean printehads for the canon iP2600
Jan 19, 2012 | Canon Pixma iP2600 Photo InkJet Printer
Canon iP2600 series-USB002 error message "The
You may need to reset your printer by software.
To reset your printer jast go to:Use ip reset software:
http://serviceprinter.wordpress.com/2008/03/26/ip-tool-canon-resetter/
Download canon ip 2600 printer resetter.
Run it on your pc.
And try to reset your printer with the resetter.
Thank you.
Aug 30, 2011 | Canon Office Equipment & Supplies
I can't print in my Canon Pixma IP1980... service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix...
service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix this?
Dec 08, 2010 | Canon Office Equipment & Supplies
May 16, 2010 | Canon Pixma iP2600 Photo InkJet Printer
What does the error code 5100 for my Ip2600 canon printer mean? How do I fix it?
Try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All Best: Pineworks
Jan 17, 2010 | Canon Pixma iP2600 Photo InkJet Printer
I just bought the Pixma i2600 printer. Is is
Just for future use, is the printer a Pixma i2600 or an iP2600?
According to the usa.canon.com website, there is a WIN 7 driver available for the Pixma iP2600. So if we are speaking of the same printer, then the answer is yes, Canon does support Win 7 for this printer.
Don
Oct 22, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Will iP-tool.exe v.1.1.5 reset my iP2600 ink levels to 100%
Yes it does reset ink levelsas well as do several other things very well.....highly recomend the program for an ip2600
May 13, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Canon PIXMA  iP1800 Printer Logo
370 people viewed this question
old marine
old marine
