Question about Maytag SkyBox MBV1976A Beverage Dispenser
Flapper Door Sensor
I need a flapper door sensor and parts select.com is out of them I ordered 1, 4 months ago and they have now refunded my money they do not know if they will get any more in. can anyone tell me where to get 1 fast.
  • 221 Answers
Remove the door sensor assembly from the door. Purchase a brush used to apply flux during a soldering operation. Also purchase a tube of blue RTV sealant.
Cut the bristle on the brush to half their size to make them more rigid. Use the brush to remove all the white crud built up on the board. Once the board is clean, coat it lightly with the RTV except for the black reed switch at the end of the board. Reinstall the board and see if this corrects your problem and keeps the board working.
I hope this helps.
Posted on Apr 25, 2009
Skybox cools but nothing else works, no LED lights, no dispensing
If none of the LEDs are working, sounds like the transformer has went bad. First look at the board for a fuse to see if its blown, if so replace, see what happens next. To check and change the transformer you need a volt/ohm meter. If you do, and are feeling ambitious, I'll need some info off the schematic or the transformer itself, and I will walk you through it.
Dec 28, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
I have an LG model LFX25974ST refrigerator. My issue is the ice flapper that allows the ice to drop will not open.partment and clog up. if i hold the flapper door open manually the ice drops down and
http://c.searspartsdirect.com/lis_png/PLDM/F1107036-00005.png
405A
on diagram Motor,dcPART NUMBER: EAU59551201 $27.41
Back ordered Call Marcone appliance ... Or goto searsparts
but this is the part you need.... To access it take outer door appart
see diagram on searsparts.com
Jan 16, 2014 | LG LFX25960ST Stainless Steel French Door...
Fuel tank flapper valve broke
THe flapper valve will be part of the filler housing and it will require the replacing of that end of the filler tube. Possible get a 2nd hand one fromk the wreckers THe flapper will be on the bottom of the tank and I cannot see any connection to the engine light which would have come on immediately if there was a connection. Run fault codes to determine which sensor./ servo put the light on
Oct 24, 2013 | 2008 Hyundai Tucson 2.0
Skybox will not dispenser beverage
ok i have the solution to the dispensing problems on the maytag skybox vending machine ... u need to open the main door and unplug the main harness , next remove the door from the hinges and place upside down somewere were it is good to work on ,next remove the 2 screws that cover the flapper sensor , next remove the seal around the door,behing the seal you will see a series of screws, remove all of them a regular phillips screwdriver is fine, next remove the back cover from the door, there you will need to unplug the flapper sensor from the main board just follow the cable and youll find the plug, once you have unplugged the plug continue by removing the complete sensor and wire, next you will see 3 wires one of the wires has xxxxxxx all over the wire this wire you will NOT touch as it can short out your unit now the other 2 wires you need to separate and cut once you have cut the 2 wires strip the ends and unite both ends together tape up and tuck away once you have done this put the door back together and mount on the unit and continue vending hope this helps .....
Dec 01, 2012 | Maytag SkyBox MBV1976A Beverage Dispenser
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Won't dispense
I had the exact same problem. I installed a new flapper door switch and it is now working. Here's the order info from partselect.com:
Item
Number
Description Availability Shipping
Method
Unit
Price
Quantity
Ordered
Extended
Price
PS901892 BOARD, FLIPPER DOOR P In Stock 3-5 Business Days $14.81 1 $14.81
Dec 29, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Why did i buy this? It never works!
I have cleaned the sensor on the door and it has fixed the problem, by wiping it off with a rag.
Dec 14, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox won't dispense anything
check the door where the cans come out. there is a sensor or the left side. if it is too far away from the door or if it's broken, it will do exactly what you said. i read somewhere that you can adjust the sensor closer to the door. i just bought one of the last one of these on the shelves 2 days ago and mine won't cool at all. stupid maytag..
Mar 01, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
283 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
