Question about Kitchen Ranges
Electrolux cooker hood lights don't work
There was a loud crack and both lights stopped working. The extractor fan works fine. Replaced both bulbs, but still nothing. I suspect there is another fuse in the assembly somewhere, but I'm b*ggered if I can find it.
SOURCE: Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Posted on Feb 16, 2008
  • 1314 Answers
SOURCE: F60 SS Cooker hood
short in light switch
Posted on Dec 30, 2007
SOURCE: cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Posted on Feb 18, 2008
  • 131 Answers
SOURCE: My cooker hood has stopped
If the hood is old and greasy, get a new one and keep it clean.
Posted on Mar 10, 2008
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
Where are the fuses in a Victoriana Deluxe Leisure cooker? The extractor fan and light have stopped working
It would be fused to the house current most likely through a circuit breaker on your service box.
Jul 19, 2016 | Kitchen Ranges
Dww061350b
if both fan and light have quit working then you have an electrical supply problem. start with checking for thrown breakers in the breaker panel. if none are tripped then you have a broken wire or a wire no longer making a good connection. try twisting the wire nuts tighter were it wires in above it
Jun 02, 2012 | Kuppersbusch Kitchen Ranges
Hygena APP2500 cooker extractor hood?the lights on the hood work but the extractor itself does not work, is this likely to be the motor that needs replacing or the switch unit ? Plz advice
if u have a meter u can check the switch and the motor,By putting it on the continuity mode and check to see if u have a bad motor or switch
Apr 02, 2011 | Dryers
I've replaced both lights in my Faber (Classic) cooker hood but though the extractor fan works the lights dont and they're powered by the same source. The light switch is on and the flap close switch is...
Probably the transformer is blown on the hood, please write info@faberspa.com if no in North America or go to : http://faberonline.com/service.html
Jan 27, 2011 | Faber (272607) Kitchen Hood
My neff cooker hood's fan and light suddenly don't work-worked yesterday! please help
My light and Extractor have stopped working. Some1 advised Transformer may have gone. Is it beside Motor and how is it accessed to fix ? Thanks
Jan 31, 2010 | Kitchen Ranges
Elica oven hood fan not working
fan & light on elica extractor fan not working over cooker
Feb 25, 2009 | Kitchen Ranges
The extractor on my Baumatic fan stopped working. Thsi was shortly after the light bulbs blew which I replaced and they work OK. Any suggestions as to how i can resolve this?
Sounds like it was the main fan motor - that caused the lights to blow in the first place.
Isolate from supply, and get the fan motor checked out. If it is burnt out (inside) you will need a replacement.
Hope this helps.
Jun 05, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Kitchen Ranges Logo
430 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
