Question about Ingersoll Air Tools & Compressors
Problem with Ingersoll Air Compressor. SSR - EP 30 SE. Low system air pressure and an alarm shows up
SSR - EP 30 SE. Low system air pressure and an alarm shows up 1st.
  • 89 Answers
SOURCE: compressor spits out oil when unit is stopped
MIGHT CAN HELP. NOT AN I.R. EXPERT BUT KNOW A GOOD BIT ABOUT SCREW COMP. ARE YOU SHUTTING UNIT DOWN SUDDENLY WITH EMERGENCY STOP OR SOMETHING. SOME UNITS DO THIS MORE THAN OTHERS BECAUSE THE WAY THE VALVE CLOSES. BURPING OIL THROUGH THE INTAKE IS ALSO CAUSED BY SUDDEN STOP INSTEAD OF THE UNIT SLOWLY SHUTTING DOWN AND THE OIL IS RUNNING BACK SLOWLY. THE UNIT ACTUALLY TURNS BACKWARDS A LITTLE BIT. YOUR OIL SHOULD NOT COST THAT MUCH. YOU CAN CONTACT ME FOR PARTS AND PRICING ON THE OIL. YOU CAN SAVE ALOT OF MONEY WITH AFTERMARKET SERVICE PARTS AND OIL -THEYRE JUST AS GOOD AS OEM.I WOULDNT USE 30W OIL ! YOUR POOR AIR DELIVERY MAY BE AFFECTED BY WORN PARTS DUE TO LUBRICATION. HOW OLD IS UNIT? MODEL # ? CONTACT ME JBRIDGERS@CA-EQUIP.COM FOR INFO & PRICING. ME AND 1 TECH WOULD PROBABLY COME DOWN AND FIX IT FOR YOU FOR AN ALL EXPENSE TRIP FOR FREE. WE ARE IN NC AND DONT GET OUT ENOUGH.
Posted on Jan 27, 2009
  • 5 Answers
SOURCE: how long should it take to fill up 80 gal tank
10 to 13 minutes from 0 psi to max and auto-shutoff. Tank will be extremely hot, also. Hope this helps!
Posted on Jul 15, 2009
  • 583 Answers
SOURCE: need to know how to adjust pressure regulator for low/high limits
sorry to be contradictory here, but better not to mislead or scare someone... Thepressure relief valve has absolutly nothing to do with cut in cut out pressure settings.the pressure relief valve is abrass fitting on the outside of the tank hexagonal fitting with a thin shaft coming out of the centre normaly with a ring on it not unlike akey ring .THAT is a blow off valve a safety device, that long before the air pressure is too great for the tank,will blow offthe air pressure in the tank ,try it, grab the ring and pull it out and it will dis charge any air in the tank ,that ios what it will do if thair is too great in the tank.. tanks are pressure tested and the appropriate valve fitted. NOW FOR YOUR ORIGINAL PROBLEM .you will find a control box ,useualy black or dark brown bakerlite cover,the electric cord goes into it ,also there will be another electric cord coming out and going to the electric motor that drives the compressor . If you take the cover off this you will find the cut in and cut out adjustments that allow you to set the cut in and cut out pressure as high or low as you want,that is whith in the capascity of the unit.It is self explanitory and there will be ( or should be ) instructions inside the cover .If you have any difficulty come back to me preferably with themotor and compressor sizes and i will walk you through it NOW AS MUCH AS THIS GOES AGAINST THE GRAIN, SHAG79 IT WOULD BE FAR BETTER IF YOU KNEW A BIT MORE ABOUT THE THINGS YOU ARE ADVISING THEM ABOUT EXPLOSIONS AND DEATH !!! WHAT ARE YOU-----A ******???
Posted on Aug 13, 2009
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
compman66
  • 169 Answers
SOURCE: The compressor starts and stops after a short
More than likely it is a problem with the inlet control, commonly I have found wear in the throttle linkage can cause this or a faulty sump pressure sensor that is out of calibration.
Posted on Mar 07, 2010
Ingersoll Rand SSR EP60 60hp Compressor w/ Intellisys 39817655 controller. Need to reset target pressure. What is the secret button sequence to access programming mode on this controller? I am aware of...
OK, Compressor should be shut down and showing (ready to start) in display. Press load/unload button once then press hidden right button within 3 seconds. This will let you access the set point program. It will include language, temperature and pressure, rated pressure,etc. Make sure you look at the data tag affixed to the unit and see what the rated pressure is for your unit. You can endanger yourself and equipment by over pressurizing the components of the compressor.
May 19, 2011 | Ingersoll Rand Stationary Air Cooled...
What does alarm start fault mean on the control panel on a ingersoll rand ssr ep-30 air compressor
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Mar 28, 2011 | Ingersoll Rand Stationary Air Cooled...
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
Aug 25, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
236 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
