Home | Ricoh | Caplio RR630 Digital Camera | Card error
Ricoh Caplio RR630 Digital Camera
Problem for Ricoh Caplio RR630 Digital Camera
Card error
By gbravi on Jun 09, 2007
card error
Clarification Request
Posted by bryan66 on Aug 21, 2008
card error
Same Problem
Apr 27, 2009
-   card error in olympus d-390. nothing wrong with card as far as i can tell because my computer reads the card just fine.-   ablamlpal
Feb 16, 2009
-   card error after having the pictures removed after formatting. tryed new caed same results-   Guest
Jan 29, 2009
-   Olympus 1030 SW, 'card error' appears when viewing certain image and will not function until turned off and on again. If this image is not viewed the camera functions as normal, however, problem image cannot be deleted. -   Guest
Jan 16, 2009
-   I have a Nikon D1 I purchased used and everything works fine except I get a card error on any card I load into the camera...have not figured solution yet.
Art
-   petrosem
Jan 11, 2009
-   new card placed in camera--"card error" continues to appear-   jts122
Solution #1
posted on Aug 06, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
go to your menu on your camera click reset all settings see how that works!!!
Solution #2
posted on Jun 09, 2007
Not Helpful)
jackboy
Rank: Wiz
Rating: 77%, 4370 votes
Carefully clean the card contacts.
put a piece of paper around the card and insert it and holding one end of the paper pull the card in and out thus polishing the contact in the camera- take great care here.
Remove paper
Now try
what happens?
Was this helpful?
Yes
No
Solution #3
posted on Nov 03, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
scream i have just took loads of lovely piccys in brighton and the message when i try to download my photo said card notinitialized
Solution #4
posted on Jan 03, 2009
Not Rated)
heavenjaden
Rank: Apprentice
Rating: 0%, 0 votes
my camera---media error what does this mean
Was this helpful?
Yes
No
Solution #5
posted on Dec 31, 2008
Not Rated)
jmarinonyc
Rank: Apprentice
Rating: 0%, 0 votes
Hello All,
I had the same problem with my finepix S5200. Worked fine for years, then one day "Card Error". Reformatting on both camera and computer did not work, in fact my PC could not complete the reformat.
Anyway, as weird as this sounds, how the problem became resolved was simply cleaning out the slot where the xD card is inserted. There may have been some dust or who knows what causing the problem. Not guaranteeing a fix for everybody.... but give it a shot, worked for me :).
Was this helpful?
Yes
No
Popular Solutions for Ricoh Caplio RR630 Digital
Questions and Unsolved Problems for Ricoh Caplio RR630 Digital
Do you recommend Ricoh Caplio RR630 Digital Camera?
Answer
Answer
I have a Premier DC 6370 (Ricoh RR 660) for years. suddenly the lcd screen has turned so white I... (More)
Answer
no menu, "card error" . cannot format or access menu.
Answer
I plugged it in to my computer as usual and it seems to have blown all my usb ports, now No computer... (More)
19 Other Users Have The Same Problem - Continued
Comment by Spideog, posted on Dec 15, 2008
Internal memory works. SD card is in"ERROR" state. Where to from here?
Comment by chandradunn, posted on Dec 13, 2008
after i get the card error it asks me to format the card..i did this and it still doesn't work.
Comment by thaydock, posted on Dec 08, 2008
I have tried putting in two new sd cards in and it is displaying "card error" on the LCD for both.
Comment by krey8ivbrain, posted on Dec 07, 2008
The camera was working fine then not. Now I turn on the camera and get a card error and nothing else. I was able to put the card into my printer and get all the pictures. I tried the original card that came with the camera as well as a new one, nothing works. I tried a fix site but I can't even get the camera to show the firmware for an update...
Comment by Guest, posted on Dec 06, 2008
my fiance got me a camera for christmas and i take about 15 picture and then when i show them to my friends it says card error and i can't take anyore i have to erase all the pictures and start all over
Comment by Guest, posted on Nov 28, 2008
same problem
Comment by pelmet, posted on Nov 27, 2008
i recently purchased a new 2gb xd type m memory card for my camera but when inserted into camera it is showing card error is this card compatible with my mera???? thanks keith
Comment by gmoore229, posted on Nov 26, 2008
My camera got dropped. It says" card read error". I cannot get my pictures now nor can I take a picture. The camera does still come on but goes directly to that error.
Comment by fredageeds, posted on Nov 19, 2008
camera shows card error and won,t do anything
Comment by Guest, posted on Oct 23, 2008
same. Except started as soon as i put card in
Comment by kebrdlebev, posted on Oct 04, 2008
I would give the same description as the others on the card error. Bought a new one, camera locks up on all buttons except pressing to format card, which jumps right to card error message. Nothing works to fix this. Has anyone contacted Olympus, if that's an option?
Comment by lmnop123, posted on Aug 30, 2008
I have the same problem with a card error on a new memory card. I don't see a solution. Can anyone help?
Comment by iwas1now66, posted on Aug 23, 2008
#1 Problem Power on button did not work. Sent camera to Fujifilm service and was fixed for $80.00 usd. Received camera and pressed power on, works great.
#2 New problem. Card Error. Changed card. Same Result, Card error. I have charged battery, been thru entire menu and even reset to original. Tried format but seems short in time. About 2 sec. and card error in tour face again. Before I send camera back to Fujiidiot, any suggestions welcome.
Thanx, Dave in St. Louis
Comment by rashidl, posted on Aug 22, 2008
I have same camera, just bought fuji XD N type 1gb memory card, but camera shows card error.
Does this new card need to be formatted or something?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Caplio RR630 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 709
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
