Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
JD 6920s 2004 AutoPowr - Park lock can not be disengaged - (error - yellow PLC 328021.31 Park lock solenoid valve, open circuit. ) after 2-3 hours plowing. After one day all is ok, but problems is evry day.
2 Suggested Answers
  • 5370 Answers
SOURCE: jd 318 tractor won't start
yes it matters.Take note of which color was on which tab.If you connect new solenoid, like how the old solenoid wires were connected.Then only it will work.Otherwise it will not work.--- Locate the positive wire that connects the solenoid with the starter. It will be virtually the only wire that runs from the solenoid to the starter post. One wire goes to battery the negative wire and other goes to ignition switch. ----------------
The red wire from the circuit breaker goes to terminal "B" of the ignition switch. On your tractor there should also be a light green wire in this terminal. Terminal "S1" should have the single purple wire that goes to the coil of the solenoid, Terminal "S2" should get the purple wire and the purple/black wire. ------------
This will help.Thanks.Helpmech.
Posted on May 11, 2011
20% of the time I cant get key to lock into the lock position, dash lights go out,BUT ignition circuit is left on,its like trying to remove key,w car Not in park.Could it be the neutral safety switch?
No , it's not the park neutral switch , The park neutarl switch won't allow the vehicle to start if not in park or neutal , has nothing to do with turning off the vehicle . Problem with the shift lock contro system probably !
Park Lock Control System (Regal)
The park lock control system is a safety device that prevents an inadvertent shift out of PARK when the ignition is OFF. The system consists of the following components:
• The automatic transmission park lock solenoid
• The brake to shift relay
• The body control module (BCM)
• The powertrain control module (PCM)
With the ignition in the OFF position the park lock control solenoid is de-energized. This mechanically locks the shift lever in the PARK position. With the ignition in the ON position, battery voltage is supply to the park lock control solenoid. The control circuit of the park lock solenoid is provided a ground through the brake to shift relay when energized. The body control module (BCM) supplies a ground for the brake to shift relay when the body control module (BCM) receives a class 2 message from the powertrain control module (PCM) indicating the transmission is in the PARK position. This closes the normally open contacts of the brake to shift relay and grounds the park lock control solenoid. This energizes the park lock control solenoid releasing the mechanical park lock.
Sorry , but your best bet would be to take your vehicle to a qualified repair shop .
Nov 15, 2016 | Buick Cars & Trucks
My 2003 GMC ENVOY won't shift out of park
Automatic Transmission Shift Lock Control System
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
The automatic transmission shift lock control solenoid
The automatic transmission shift lock control switch
With the ignition in the ON position, voltage is supplied to automatic transmission shift lock control switch. Voltage flows through the normally closed contacts of the automatic transmission shift lock control switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid causing the transmission shift lever to be physically locked in the PARK position. When the brake pedal is pressed the contacts in the automatic transmission shift lock control switch open, de-energizing the automatic transmission shift lock control solenoid. This allows the shift lever to be move out of the PARK position.
Shift Lever Does Not Move with Brake Pedal Depressed ?
  1. Turn ON the ignition.
  2. Press and hold the brake pedal.
  3. Attempt to move the shift lever out of the PARK position.
Does the shift lever move out of the PARK position?
Go to Testing for Intermittent Conditions and Poor Connections
Go to Step 3
  1. Turn OFF the ignition.
  2. Disconnect the automatic transmission shift lock control switch.
  3. Turn ON the ignition, with the engine OFF.
  4. Attempt to move the shift lever out of the PARK position.
Go to Step 7
Go to Step 4
  2. Leave the automatic transmission shift lock control switch disconnected.
  3. Connect a test lamp between the A/T shift lock control solenoid supply voltage circuit at the automatic transmission shift lock control solenoid and a good ground.
  4. Turn ON the ignition with the engine OFF.
Does the test lamp illuminate?
5
  2. Connect a test lamp between the ignition 1 voltage circuit of the park lock solenoid and a good ground.
  3. Turn ON the ignition with the engine OFF.
Go to Step 6
Go to Step 9
6
  2. Connect a test lamp between the ignition 1 voltage circuit of the park lock solenoid and the park lock solenoid ground circuit.
Go to Step 8
Go to Step 11
7
Inspect for poor connections at the harness connector of the automatic transmission shift lock control switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 14
Go to Step 13
8
Inspect for poor connections at the harness connector of the park lock/automatic transmission shift lock control solenoid assembly. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 12
9
Repair the open or high resistance in the park lock solenoid ignition 1 voltage circuit. Refer to Circuit Testing or Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 14
10
Repair short to battery positive voltage in the A/T shift lock control solenoid supply voltage circuit. Refer to Circuit Testing or Wiring Repairs in Wiring Systems.
Go to Step 14
11
Repair the open or high resistance in the park lock solenoid ground circuit. Refer to Circuit Testing or Wiring Repairs in Wiring Systems.
Go to Step 14
12
Important: Depress the button on the side of the shift lock actuator. With the button is depressed, cycle the plastic straw within the shift lever 3 to 5 times. The straw should move smoothly and freely except near the top of the travel where additional force will be required to mechanically actuate the park lock mechanism inside of the shift lock actuator. If there is stick/slip or abnormal friction while cycling the plastic straw or if the straw is altogether stuck in the lever, the entire control assembly (shifter and shift lock actuator) needs to be replaced. Refer to Transmission Control Replacement . If there is no abnormal friction, replace the shift lock actuator. Refer to Automatic Transmission Shift Lock Control Actuator Replacement .
Did you complete the replacement?
Go to Step 14
13
Replace the automatic transmission shift lock control switch. Refer to Stop Lamp Switch Replacement in Lighting Systems.
Go to Step 14
14
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Jul 09, 2016 | GMC Cars & Trucks
2004 pontiac sunfire wont shift out of park
Problem with shift interlock system .
Automatic Transmission Shift Lock Control Description and Operation
With the ignition in the ON position, battery positive voltage is supplied to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid receives a ground from the BCM. When the automatic transmission shift lock control solenoid is energized, the shift lever mechanically locked in the PARK position. When the driver presses the brake pedal the PCM sends a class 2 serial data message to the BCM. The BCM turns OFF the ground control circuit and this de-energizes the automatic transmission shift lock control solenoid. When the automatic transmission shift lock control solenoid is de-energized, the shift lever may be moved out of the PARK position. The BCM determines transaxle shift lever position through a class 2 serial data message from the PCM. The PCM receives inputs from the park/neutral position switch and determines shift lever position. When the BCM receives this information and determines that the shift lever is out of the PARK position, the automatic transmission shift lock control solenoid ground is opened.
Did you perform the A Diagnostic System Check - Automatic Transmission Shift Lock Control?
Go to Step 2
Go to Diagnostic System Check - Automatic Transmission Shift Lock Control
  1. Turn ON the ignition, with the engine OFF.
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
  2. Disconnect the automatic transmission shift lock control solenoid.
YES - Go to Step 4
NO - Go to Step 5
Test the A/T shift lock control circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 9
NO - Go to Step 6
5
Inspect for poor connections at the harness connector of the automatic transmission shift lock control solenoid. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 9
Go to Step 7
6
Inspect for poor connections at the harness connector of the body control module (BCM). Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 9
Go to Step 8
7
Replace the automatic transmission shift lock control solenoid. Refer to Transmission Control Replacement in Automatic Transaxle-4T40-E/4T45-E.
Go to Step 9
8
Replace the body control module (BCM). Refer to Body Control Module Replacement in Body Control System.
Go to Step 9
9
System OK
Go to Step 2
Jun 29, 2016 | Pontiac Cars & Trucks
My x type 3.0 has fault readingP1647 could you tell me what this means please
OBDII DTC
P1001 Key on engine running unable to complete; key on engine running aborted
P1100 Mass air flow sensor intermittent
P1101 Mass air flow sensor out of self test range
P1104 Mass Airflow (MAF) Sensor Ground Circuit Malfunction
P1107 Left MAP Sensor Circuit
P1108 Right MAP Sensor Circuit
P1112 IATS Circuit High Voltage
P1113 IATS Circuit Low Voltage
P1121 Pedal Position Sensor Circuit A Range/Performance
P1122 Pedal Position Sensor Circuit A Low Voltage
P1123 Pedal Position Sensor Circuit A High Voltage
P1137 No Rear HO2S Response
P1138 No Rear HO3S Response
P1157 No Rear HO2S Response
P1158 No Rear HO3S Response
P1171 All Cylinders Too Lean
P1172 All Cylinders Too Rich
P1176 Adaptive Fuel Metering Trim Too Lean
P1177 Adaptive Fuel Metering Trim Too Rich
P1178 Adaptive Fuel Metering Trim Too Lean
P1179 Adaptive Fuel Metering Trim Too Rich
P1187 Both Front HO2S Heater Circuits (High Resistance)
P1188 Both Front HO2S Heater Circuits (Open Short to Ground High Resistance)
P1190 Both Front HO2S Heater Circuits (High Battery Voltage Short to Voltage)
P1193 Both Front HO2S Heater Circuits (High Resistance MAF Sensor Fault)
P1194 Both Front HO2S Heater Circuits (Open Short to Ground High Resistance)
P1196 Both Front HO2S Heater Circuits (High Battery Voltage Short to Ground)
P1198 Fuel Level Sensor (High Voltage)
P1199 Fuel Level Sensor (Low Voltage)
P1201 No. 1 Fuel Injector
P1202 No. 2 Fuel Injector
P1203 No. 3 Fuel Injector
P1204 No. 4 Fuel Injector
P1205 No. 5 Fuel Injector
P1206 No. 6 Fuel Injector
P1221 Pedal Position Sensor Circuit B Range/Performance
P1222 Pedal Position Sensor Circuit B Low Voltage
P1223 Pedal Position Sensor Circuit B High Voltage
P1224 Electronic Throttle Control Position Error
P1226 Mechanical Guard Circuit Range Performance
P1227 Mechanical Guard Circuit Low Input
P1228 Mechanical Guard Circuit High Input
P1229 Throttle Control Circuit Malfunction
P1230 Fuel Pump Relay Malfunction
P1235 VSV 1 Circuit Range/Performance
P1236 VSV 1 Vacuum Circuit Failure
P1237 VSV 2 Atmosphere Circuit Failure
P1238 VSV 3 Release Circuit Failure
P1240 Throttle Position Sensor Voltage Malfunction//Sensor Reference Voltage Low (Throttle
Fuel Tank Pressure)
P1241 Throttle Position Sensor Voltage Low Input//Reference Voltage Low (Throttle Fuel
Tank Pressure)
P1242 Throttle Position Sensor Voltage High Input
P1243 Throttle Position Sensor Ground Malfunction
P1245 Crank Signal Low Input
P1246 Crank Signal High Input
P1313 Misfire Catalyst Damage Bank No. 1
P1314 Misfire Catalyst Damage Bank No. 2
P1315 Misfire Excess Emissions
P1316 Misfire Rate Above Limit
P1335 Crankshaft Position Sensor Circuit
P1336 Camshaft Position Sensor (CMP) Circuit Performance
P1361 Ignition Coil Primary Circuit (Cylinder No. 1)
P1362 Ignition Coil Primary Circuit (Cylinder No. 2)
P1363 Ignition Coil Primary Circuit (Cylinder No. 3)
P1364 Ignition Coil Primary Circuit (Cylinder No. 4)
P1365 Ignition Coil Primary Circuit (Cylinder No. 5)
P1366 Ignition Coil Primary Circuit (Cylinder No. 6)
P1367 Ignition Monitor (Bank A)//Ignition System Failure Group 1
P1368 Ignition Monitor (Bank B)//Ignition System Failure Group 2
P1371 Early Activation Ignition Coil (Cylinder No. 1)
P1372 Early Activation Ignition Coil (Cylinder No. 2)
P1373 Early Activation Ignition Coil (Cylinder No. 3)
P1374 Early Activation Ignition Coil (Cylinder No. 4)
P1375 Early Activation Ignition Coil (Cylinder No. 5)
P1376 Early Activation Ignition Coil (Cylinder No. 6)
P1392 Variable Valve Timing Solenoid A Low Input
P1393 Variable Valve Timing Solenoid A High Input
P1396 Variable Valve Timing Solenoid B Malfunction
P1397 Variable Valve Timing Solenoid B Low Input
P1398 Variable Valve Timing Solenoid B High Input
P1400 EGR Valve Position Circuit (Valve Sticking Open or Short)
P1401 EGR Valve Position Circuit (Open Short to Ground)
P1408 EGR Temperature Sensor Circuit
P1409 EGR Valve Circuit
P1440 EVAP Purge Valve Open
P1441 EVAP Valve Circuit
P1443 EVAP Valve Circuit
P1447 EVAP Valve Circuit
P1448 EVAP Valve Circuit
P1454 EVAP System
P1474 Charge Air Coolant Pump Relay
P1475 Radiator Fans Slow Malfunction
P1476 Radiator Fans Fast Parallel Circuit Malfunction
P1506 Idle Speed Control Circuit (Low RPM; Bank B)
P1507 Idle Speed Control Circuit (High RPM; Bank B)
P1508 Idle Speed Control Circuit
P1509 Idle Speed Control Circuit
P1512 Throttle Position Sensor Idle Switch Sense Circuit
P1513 Throttle Position Sensor Idle Switch Sense Circuit
P1514 Park/Neutral Position Switch High Load Neutral/Drive
P1516 Gear Change Park/Neutral Malfunction
P1517 Engine Cranking Park/Neutral Malfunction
P1607 MIL Output Circuit
P1608 Automatic Transmission
P1609 Internal ECM Error
P1641 Fuel Pump Relay No. 1
P1646 Fuel Pump Relay No. 2
P1739 Automatic Transmission
P1775 Transmission Control Module MIL Circuit
P1776 Torque Reduction Request Signal
P1777 Torque Reduction Circuit
P1780 Automatic Transmission
P1781 Automatic Transmission
P1782 Automatic Transmission
P1783 Automatic Transmission
P1785 Automatic Transmission
P1790 Automatic Transmission
P1791 Automatic Transmission
P1792 Automatic Transmission
P1794 Automatic Transmission
Mar 22, 2013 | Jaguar Cars & Trucks
2004 Pontiac sunfire shifter gets stuck in "park" when cold.
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of thew following components:
• The automatic transmission shift lock control solenoid
Do you know what a DTC is ? Diagnostic trouble code !
DTC B2708
The body control module (BCM) controls the automatic transmission shift lock control solenoid. Positive voltage is supplied via the ignition 1 voltage circuit to the automatic transmission shift lock control solenoid. The BCM controls the ground circuit of the automatic transmission shift lock control solenoid . When the brake pedal is depressed, the BCM removes the ground allowing the solenoid to disengage. This action allows the vehicle to be shifted out of the PARK position.
Conditions for Running the DTC
DTC B2707
Your best bet mite be to have a qualified repair shop check it .
Jan 15, 2018 | 2004 Pontiac Sunfire
I can't get it out of park what can be the problem
if you can't move the shift lever at all the shift lock solenoid is not disengaging which can be a bad fuse/relay, a broken or loose wire on the solenoid itsself, a stuck shift lock solenoid, the sensor that detect the brake being pressed, or an electrical problem in the ignition start by checking for fuses/relays next check if your brake lights are working when brake is pressed(same sensor) if you have to go further locate the shift lock solenoid and check if its stuck or functiioning at all if its not disengaging try putting a 12volt power source directly to the solenoid terminals(remember u have to connect both power and ground) if that moves the soolenoid your issue is that the solenoid is not receiving power when it is suppose to check wiring for short or broken ciruit. If you can move the shift lever the problem is in the linkage, trans controller, or the trans solenoid if that's the case get it towed to a tranny shop
Jan 05, 2012 | 2004 Mercury Mountaineer
I have an 04 Kia spectra with a PO121 code. What domestic this mean
Well.... Here is a full list of the codes I can find that Kia list. Oddly it jumps from P0120 to P0122
I hope the attached will help, but you may need to talk to your dealer.
Diagnostic Codes
Kia
Without Onboard Diagnostics (OBD-II)
2 Distributor no Signal.
3 Distributor G Signal.
7 Fault on SGT Signal.
8 Mass Air Flow Sensor.
9 Engine Coolant Temperature Sensor.
10 Intake Air Temperature Sensor.
12 Throttle Position Sensor.
14 Atmospheric Pressure Sensor.
15 Oxygen Sensor.
16 EGR Valve Position Sensor.
17 Feedback System.
18 Injector No. 1 open or short.
19 Injector No. 2 open or short.
20 Injector No. 3 open or short.
21 Injector No. 4 open or short.
24 Fuel Pump Relay open or short.
25 Pressure Regulator Control Solenoid Valve.
26 Purge Control Solenoid Valve.
28 Solenoid Valve (EGR) open or short.
34 Idle Speed Control Solenoid Valve.
35 Deteriorated Injector.
36 Deteriorated Air Flow Sensor.
37 Intake System Air Leakage.
41 Variable Inertia Charging System Solenoid Valve.
46 A/C Cut Relay open or short.
48 Power Stage Group 1 Malfunction (inside ECM). Injector 1-4 Purge Solenoid Valve, EGR Solenoid Valve or Damaged Power Stage.
49 Power Stage Group 2 Malfunction (inside ECM). Idle Speed Control Valve Failure or Damaged Power Stage.
56 Idle Speed Control Valve Closing Coil open or short.
57 A/C Compressor Input Signal short.
73 Vehicle Speed Sensor open or short.
87 Malfunction Indicator Lamp short Circuit.
88 ECM Data.
99 Battery.
OBD-II
P0100 Mass Air Flow or Volume Air Flow Circuit Malfunction.
P0101 Mass Air Flow or Volume Air Flow Circuit Range/Performance problem.
P0102 Mass Air Flow or Volume Air Flow Circuit Low Input.
P0103 Mass Air Flow or Volume Air Flow Circuit High Input.
P0107 MAP/BARO Circuit Low Input.
P0108 MAP/BARO Circuit High Input.
P0110 A/T Circuit Malfunction.
P0115 Engine Coolant Temperature Circuit Malfunction.
P0116 Engine Coolant Temperature Circuit Range/Performance Condition.
P0117 Engine Coolant Temperature Circuit Low Input.
P0118 Engine Coolant Temperature Circuit High Input.
P0120 Throttle Position Malfunction - Circuit A.
P0122 APP/TPP Sensor Switch Low Input - Circuit A.
P0123 APP/TPP Sensor Switch High Input - Circuit A.
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control.
P0130 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 1.
P0131 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 1.
P0132 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 1.
P0133 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 1.
P0134 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 1.
P0135 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 1.
P0136 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 2.
P0137 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 2.
P0138 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 2.
P0139 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 2.
P0140 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 2.
P0141 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 2.
P0170 Fuel Trim Malfunction - Bank 1.
P0171 System too Lean - Bank 1.
P0172 System too Rich - Bank 1.
P0261 Injector Circuit Low - Cyl. 1.
P0262 Injector Circuit High - Cyl. 1.
P0264 Injector Circuit Low - Cyl. 2.
P0265 Injector Circuit High - Cyl. 2.
P0267 Injector Circuit Low - Cyl. 3.
P0268 Injector Circuit High - Cyl. 3.
P0270 Injector Circuit Low - Cyl. 4.
P0271 Injector Circuit High - Cyl. 4.
P0300 Multiple/Random Misfire detected.
P0301 Misfire detected - Cyls. 1-4.
P0302 Misfire detected - Cyls. 1-4.
P0303 Misfire detected - Cyls. 1-4.
P0304 Misfire detected - Cyls. 1-4.
P0325 Knock Sensor Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range/Performance - Bank 1 or Single Sensor.
P0335 Crankshaft Position Sensor Malfunction - Circuit A.
P0336 Crankshaft Position Sensor Range/Performance - Circuit A.
P0340 Crankshaft Position Sensor Circuit Malfunction.
P0342 Crankshaft Position Sensor Circuit Low Input.
P0343 Crankshaft Position Sensor Circuit High Input.
P0400 EGR Flow Malfunction.
P0403 EGR Circuit Malfunction.
P0404 EGR Circuit Range/Performance Malfunction.
P0420 Catalyst System Efficiency below Threshold - Bank 1.
P0422 Main Catalyst Efficiency below Threshold - Bank 1.
P0440 Evaporative Control Malfunction.
P0441 Evaporative Control System - Improper Purge.
P0442 Evaporative Control System - Small Leak detected.
P0443 Evaporative Control System Purge Control Valve Circuit Malfunction.
P0446 Evaporative Vent Control Circuit Malfunction.
P0447 Evaporative Vent Control Circuit Open.
P0448 Evaporative Vent Control Circuit Short.
P0450 Evaporative System Pressure Sensor Circuit Malfunction.
P0452 Evaporative Control System Pressure Sensor Low Input.
P0453 Evaporative Control System Pressure Sensor High Input.
P0455 Evaporative Control System - Large Leak detected.
P0470 Exhaust Pressure Sensor Malfunction.
P0500 Vehicle Speed Sensor Malfunction.
P0501 Vehicle Speed Sensor Range/Performance.
P0505 Idle Air Control System Malfunction.
P0506 Idle Air Control System Malfunction - RPM Lower than expected.
P0507 Idle Air Control System Malfunction - RPM Higher than expected.
P0510 CTP Switch Malfunction.
P0561 System Voltage Unstable.
P0562 System Voltage Low.
P0563 System Voltage High.
P0601 Internal Control Module Memory Checksum Error.
P0604 Internal Control Module RAM Error.
P0703 Torque Converter/Brake Pedal Switch Malfunction - Circuit B.
P0705 Transaxle Range Sensor Circuit Malfunction (PRNDL Input).
P0706 A/T Range Sensor Circuit Range/ Performance.
P0710 Transaxle Fluid Temperature Sensor Circuit Malfunction.
P0711 A/T Fluid Temperature Sensor Circuit Range/Performance.
P0715 Input/Turbine Speed Sensor Circuit Malfunction.
P0722 Output Speed Sensor Circuit No Signal.
P0726 Engine Speed Input Circuit Range/ Performance.
P0727 Engine Speed Input Circuit - No Signal.
P0731 A/T Gear 1 Improper Ratio.
P0732 A/T Gear 2 Improper Ratio.
P0733 A/T Gear 3 Improper Ratio.
P0734 A/T Gear 4 Improper Ratio.
P0740 Torque Converter Clutch System Malfunction.
P0743 Torque Converter Clutch Circuit Electrical.
P0750 Shift Solenoid "A" Malfunction.
P0753 Shift Solenoid "A" Electrical.
P0755 Shift Solenoid "B" Malfunction.
P0758 Shift Solenoid "B" Electrical.
P0760 Shift Solenoid "C" Malfunction.
P1000 Readiness Function Code.
P1115 Engine Coolant Temperature Signal from ECM to TCM.
P1121 Throttle Position Sensor Signal Malfunction from ECM to TCM.
P1170 Front Heated Oxygen Sensor Stuck.
P1195 EGR Pressure Sensor (1.6L) or Boost Sensor (1.8L) Open or Short.
P1196 Ignition Switch "Start" Open or Short (1.6L).
P1250 Pressure Regulator Control Solenoid Valve Open or Short.
P1252 Pressure Regulator Control Solenoid Valve No. 2 Circuit Malfunction.
P1307 Chassis Acceleration Sensor Signal Malfunction.
P1308 Chassis Acceleration Sensor Signal Low.
P1309 Chassis Acceleration Sensor Signal High.
P1345 No SGC Signal (1.6L).
P1386 Knock Sensor Control Zero Test.
P1402 EGR Valve Position Sensor Open or Short.
P1449 Canister Drain Cut Valve Open or Short (1.8L).
P1450 Excessive Vacuum Leak.
P1455 Fuel Tank Sending Unit Open or Short (1.8L).
P1457 Purge Solenoid Valve Low System Malfunction.
P1458 A/C Compressor Control Signal Malfunction.
P1485 EGR Solenoid Valve Vacuum Open or Short.
P1486 EGR Solenoid Valve Vent Open or Short.
P1487 EGR Boost Sensor Solenoid Valve Open or Short.
P1496 EGR Stepper Motor Malfunction - Circuit 1 (1.8L).
P1497 EGR Stepper Motor Malfunction - Circuit 2 (1.8L).
P1498 EGR Stepper Motor Malfunction - Circuit 3 (1.8L).
P1499 EGR Stepper Motor Malfunction - Circuit 4 (1.8L).
P1500 No Vehicle Speed Signal to TCM.
P1505 Idle Air Control Valve Opening Coil Voltage Low.
P1506 Idle Air Control Valve Opening Coil Voltage High.
P1507 Idle Air Control Valve Closing Coil Voltage Low.
P1508 Idle Air Control Valve Closing Coil Voltage High.
P1523 VICS Solenoid Valve.
P1586 A/T-M/T Codification.
P1608 PCM Malfunction.
P1611 MIL Request Circuit Voltage Low.
P1614 MIL Request Circuit Voltage High.
P1624 MIL Request Signal from TCM to ECM.
P1631 Alternator "T" Open or No Power Output (1.8L).
P1632 Battery Voltage Detection Circuit for Alternator Regulator (1.8L).
P1633 Battery Overcharge.
P1634 Alternator "B" Open (1.8L).
P1693 MIL Circuit Malfunction.
P1743 Torque Converter Clutch Solenoid Valve Open or Short.
P1794 Battery or Circuit Failure.
P1795 4WD Switch Signal Malfunction.
P1797 P or N Range Signal or Clutch Pedal Position Switch Open or Short.
Jun 21, 2011 | 2004 Kia Spectra
2004 niisan infinty g35x code p2135
NISSAN OBDII DTC
P1105 Manifold Absolute Pressure/Barometric Pressure Switch Solenoid Circuit
P1110 Intake Valve Timing Control Circuit (Bank 1)
P1120 Secondary Throttle Position Sensor Circuit
P1125 Tandem Throttle Position Sensor Circuit
P1132 Intake Valve Timing Control Position Sensor (Bank 1)
P1135 Intake Valve Timing Control Circuit (Bank 2)
P1137 Intake Valve Timing Control Position Sensor (Bank 2)
P1140 Intake Valve Timing Control Position Sensor (Bank 1)
P1145 Intake Valve Timing Control Position Sensor (Bank 2)
P1148 Closed Loop Fault Detected (Bank 1)
P1168 Closed Loop Fault Detected (Bank 2)
P1210 Traction Control System Signal Fault
P1220 Fuel Pump Control Module Fault
P1320 Ignition Control Signal Fault
P1336 Crankshaft Position Sensor circuit
P1400 EGR/EVAP Control Solenoid Circuit
P1401 EGR Temperature Sensor Circuit
P1402 EGR System Fault Detected
P1440 EVAP Canister System Leak Detected
P1441 EVAP Vacuum Cut Valve Bypass Valve Circuit
P1443 EVAP Canister Control Vacuum Switch Circuit
P1444 EVAP Canister Purge Volume Control Valve Circuit
P1445 EVAP Purge Volume Control Valve
P1446 EVAP Canister Vent Valve Circuit
P1447 EVAP Canister Purge Flow/Volume Control Valve Circuit
P1448 EVAP Vent Control Valve Circuit
P1490 EVAP Vent Control Valve/Bypass Valve Circuit
P1491 EVAP Vacuum Cut Valve/Bypass Valve Circuit
P1492 EVAP Canister Purge Control Valve/Solenoid Valve
P1605 Transmission Control Module A/T Diagnosis Communication Line Fault
P1705 Throttle Position Switch Circuit
P1706 Park Neutral Position Switch Circuit
P1760 Overrun Clutch Solenoid Valve Circuit
P1900 Cooling Fan Control Circuit
sorry but your code reader is not reading manufacturers codes ,if an american market vehicle then you should be able to read them but if this is a europeon model then how did you manage to get this code??
P0235....Turbo/Super Charger Boost Sensor 'A' Circuit
this is a generic code if its any help
Nov 02, 2010 | 2004 Infiniti G35 Sport Coupe
Torque convertor clutch circuit electrical code po743
CIRCUIT DESCRIPTION
The shift solenoid valve SL is turned ON and OFF by signals from the ECM to control the hydraulic pressure
acting on the lock–up relay valve, which then controls the operation of the lock–up clutch.
DTC No. DTC Detection Condition Trouble Area
P0743
 ECM detects open in solenoid SL circuit 4 times when solenoid
SL is not operated (2–trip detection logic)
 ECM detects short in solenoid SL circuit 4 times when solenoid
SL is operated (2–trip detection logic)
 Open or short in shift solenoid valve SL circuit
 Shift solenoid valve SL
ECM
Fail safe function
If the ECM detects a malfunction, it turns the shift solenoid valve SL OFF
Jun 10, 2010 | 1999 Ford Expedition
1992 Buick Park Ave Engine light somes on intermittently. Goes out When you increase RPM pass 1500 or decellerate below 1000. Thanks! Dave
THIS LIGHT IS TURNED ON BY ONE OF WELL OVER 200 DIFFERENT PROBLEMS IN THE ELECTRONIC CONTROLS OF THE ENGINE. TRANSMISSION OR EMISSION CONTROL SYSTEM, IN ORDER TO HAVE ANY HOPE OF FINDING THE ROOT CAUSE THE DEALER MUST TEST THE SYSTEM WITH A SPECIAL SCANNER TO SEE WHAT TROUBLE CODES ARE PRESENT, BELOW U WILL FIND A PARTIAL LIST OF THE FAULTS THAT CAN BE PRESENT WHENEVER THE LIGHT IS ON..
P0001 Fuel Volume Regulator Control Circuit/Open
P0002 Fuel Volume Regulator Control Circuit Range/Performance
P0003 Fuel Volume Regulator Control Circuit Low
P0004 Fuel Volume Regulator Control Circuit High
P0005 Fuel Shutoff Valve Control Circuit/Open
P0006 Fuel Shutoff Valve Control Circuit Low
P0007 Fuel Shutoff Valve Control Circuit High
P0008 Engine Position System Performance (Bank 1)
P0009 Engine Position System Performance (Bank 2)
P0010 A Camshaft Position Actuator Circuit (Bank 1)
P0011 A Camshaft Position - Timing Over - Advanced or System Performance (Bank 1)
P0012 A Camshaft Position - Timing Over - Retarded (Bank 1)
P0013 B Camshaft Position - Actuator Circuit (Bank 1)
P0014 B Camshaft Position - Timing Over - Advanced or System Performance (Bank 1)
P0015 B Camshaft Position - Timing Over - Retarded (Bank 1)
P0016 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
P0017 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B)
P0018 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
P0019 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor B)
P0020 A Camshaft Position Actuator Circuit (Bank 2)
P0021 A Camshaft Position - Timing Over - Advanced or System Performance (Bank 2)
P0022 A Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 B Camshaft Position - Actuator Circuit (Bank 2)
P0024 B Camshaft Position - Timing Over - Advanced or System Performance (Bank 2)
P0025 B Camshaft Position - Timing Over - Retarded (Bank 2)
P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0027 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0029 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0033 Turbo Charger Bypass Valve Control Circuit
P0034 Turbo Charger Bypass Valve Control Circuit Low
P0035 Turbo Charger Bypass Valve Control Circuit High
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
P0040 O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1
P0041 O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0045 Turbo/Super Charger Boost Control Solenoid Circuit/Open
P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
P0049 Turbo/Super Charger Turbine Overspeed
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0053 HO2S Heater Resistance (Bank 1 Sensor 1)
P0054 HO2S Heater Resistance (Bank 1 Sensor 2)
P0055 HO2S Heater Resistance (Bank 1 Sensor 3)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
P0059 HO2S Heater Resistance (Bank 2 Sensor 1)
P0060 HO2S Heater Resistance (Bank 2 Sensor 2)
P0061 HO2S Heater Resistance (Bank 2 Sensor 3)
P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
P0067 Air Assisted Injector Control Circuit High
P0068 MAP/MAF - Throttle Position Correlation
P0069 Manifold Absolute Pressure - Barometric Pressure Correlation
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range/Performance
P0072 Ambient Air Temperature Sensor Circuit Low
P0073 Ambient Air Temperature Sensor Circuit High
P0074 Ambient Air Temperature Sensor Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake Valve Control Solenoid Circuit (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
P0087 Fuel Rail/System Pressure - Too Low
P0088 Fuel Rail/System Pressure - Too High
P0089 Fuel Pressure Regulator 1 Performance
P0090 Fuel Pressure Regulator 1 Control Circuit
P0091 Fuel Pressure Regulator 1 Control Circuit Low
P0092 Fuel Pressure Regulator 1 Control Circuit High
P0093 Fuel System Leak Detected - Large Leak
P0094 Fuel System Leak Detected - Small Leak
P0095 Intake Air Temperature Sensor 2 Circuit
P0096 Intake Air Temperature Sensor 2 Circuit Range/Performance
P0097 Intake Air Temperature Sensor 2 Circuit Low
P0098 Intake Air Temperature Sensor 2 Circuit High
P0099 Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
Jun 24, 2009 | 1992 Buick Park Avenue
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
102 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
