Question about LG 50PG20 50 in. Plasma HDTV
I have a 50 Inch LG Plasma a couple of months old, We have Direct TV and use the DVR allot. The TV has an issue when we change the channel it goes black and sits there forever, you have to turn the TV on and off to get the channel to come on, I am wondering if this the TV or the Sattelite? Need Help!
    Top Expert:
  • LG Master
  • 14,553 Answers
Try disconnection of everything, it could be the set OR the signal coming in, do not void your warranty on the set by opening it.
I would first depending on the sat system reboot that to see if issue is there and talk to the provider.
You really need to find out if set or signal and my money would be the signal.
Another thing you might check is this set slow to change inputs from video to tuner etc, I have seen sets that were,.
Posted on Dec 05, 2012
    Top Expert:
  • LG Master
  • 74,459 Answers
Make a hard reset to this set and check. If it do not help you, replace this set, as it has fault with its main tuner board. Why do you spend for it, when the set is in warranty period?.
  • 5 Answers
SOURCE: LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Posted on Jun 03, 2008
  • 135 Answers
SOURCE: 1/2 the screen goes black
Hi there! According to the Model Number supplied, this is a 42" Plasma. This problem would normally be caused by the bottom Y-Drive board. However it may also be one of the connector plugs which was not plugged in properly in the factory. Check where the Y-Sus Board is located. There are 2 Y-Drive boards connected to the Y-Sus Board. Top and Bottom. The Bottom one may be at fault. Be careful when removing any flexible ribbon cables as these can easily tear. Also unplug from mains before removing the cover. If the panel is 4 months old it should still be under warranty. Make notes before dissassembly. Best Wishes and Good luck, Jus004.
Posted on Aug 21, 2009
SOURCE: LG 50inch Plasma received loud sound then went black
I had the same problem with my LG 50 inch TV that I bought from Best Buy in Nov 2006. Fortunately I had the service plan. They had to replace the power supply board as 9 capacitors popped, so the TV would turn on them pop and go black and turn itself off. The TV has been a pain. I have the built in DVR and that has failed twice. I have had 3 repairs through best buy. One more time they owe me a new TV when they come out.
Posted on Sep 05, 2009
  • 94 Answers
SOURCE: 50 inch LG Plasma TV 2yrs old keeps powering off
power supply or main board issue depending on several factors
Posted on May 28, 2010
savers2008
  • 286 Answers
SOURCE: I have a 50 inch LG plasma it keeps sticking on a
This sounds like a software problem. Have you tried updating the software for this TV. You can download from Internet, save it to a flash drive then plug in to TV. And update.
Hope this helps..
Posted on Apr 12, 2011
One channel is on spanish language in every program on lg plasma 50 inch
you can change this on your remote , goto their website and look there also ck youtube,
Apr 21, 2015 | LG 50PX5D 50 in. Plasma HDTV
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
I have a 50 inch LG plasma it keeps sticking on a channel and i have to turn it off and then turn it back on to change channel it also gets stuck between channels giving a blank screen
Hope this helps..
Apr 12, 2011 | LG Televison & Video
vera partner what you have is a problem of poor voltage or damaged card card check your x that is the bottom of the plasma must consist of at least four cards
Aug 21, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Sanyo 50 inch plamsa just quit!
the power supply of the tv is too sensitive. you need to have a good spike guard for this.
Jan 10, 2009 | Sanyo DP42746 42 in. Plasma Television
42 LG Plasma
It can be fixed but about $300 in parts.
May 18, 2008 | LG 50PX4DR 50 in. Plasma TV
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
42 inch LG Plasma TV - Lost picture
sounds like it may be a software upgrade
Oct 16, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 50PG20 50 in. Plasma HDTV Logo
47 people viewed this question
Computer Repairing
Computer Repairing
