E Motion LCD TV Model X26/29E won't turn on - seems stuck in standby (red light on). Remote control is OK.
This problem started as an occasional fault, which could be cured by turnrng mains off, then on.
My sisters e-motion lcd tv is locked in, standby mode. I think that replacing the psu (power supply unit) is the answer. but be careful of introducing static damage to the components as you can cause latent component damage and then future repair is not so easy to locate! always make sure that you fault find using the proses of elimination ie start from the begining !! Make sure you have a 240v supply going in and then probe for your outputs.. If your out put measurements are ok then you can eliminate your power supply unit as your problem circuit .....
Posted on Jun 02, 2014
  • Dawn Solly
    Dawn Solly Apr 25, 2017
    Hi just got a second hand e motion tv. Seen workin now back at mine . It wont turn on. No light cpmin on tv at all. Have tried different sockets and changed fuse. Any suggestions please?
SOURCE: Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Posted on Nov 06, 2008
  • 187 Answers
SOURCE: how to reset lg lcd tv
Whe you press the power button the TV led have to blink several times and the it have to change to blue, meaning Tv is on.
If you press the power button and the led start blinking and goes off, then you need to replace the mainboard because it is damaged.
Bye
Posted on May 27, 2009
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
  • 65 Answers
SOURCE: Acoustic Solutions TV Fault
I think you are looking at a power board problem. I had the same thing happen to a Vizio and I replaced the power board and it solved the problem. It could also be the input board but most likely the power board.
Thanks,
Ced
Posted on Jul 13, 2009
  • 55 Answers
SOURCE: My Daewoo LCD TV (DLT-32C3FTB) will not come off standby.
Common problem on power supply board, replace dried out electrolytic capacitors
Posted on Oct 06, 2009
How can i repair a tv that turns on but has no picture or sound
Have you tried a factory reset? I had a similar problem my TV was stuck on standby (red light only) I did this
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
and it worked!
Oct 16, 2015 | Sony KDL46EX400 46 in. HD-Ready TV
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
Tv won't turn on. Blinking in standby in red. Won't start
This is an indication of protection error and might require attention of a qualified service technician.
Aug 17, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
MY LCD PHILLIPS MODEL 42PFL3704D/47
Good day!!!
if you have power problem without blinking lights or standby lights (red) the possible problem is power supply board..However if the TV have blinking or standby light but won't turn ON..there are multiple cause of that and need further troubleshooting..
Mar 11, 2012 | Philips 42PF9431D/37 TV
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
Hitachi 42LDF30U LCD TV stuck in standby mode
Hi there mine has started doing the same thing today, on other hitachi models it is a serious fault warning, i will come back when i find out more.
Jul 07, 2010 | Hitachi Televison & Video
Can't power on TV occasionally
It is possible that the conductivity of a power diode is diminished after a period of time causing the unit to receive just under the needed current to function. Test the resistance of internal components after periods of tine or seek manufactures assistance.
Apr 12, 2010 | Samsung LN52A650A LCD TV
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Magnavox 15MF237 LCD - stuck in standby
just one idea.. some set you may program to stay on in case you use cable box and when you turn on the box tv turn on same time but may be defective tv there is relay,transistor and the micro that may be bad so check your settings again ... Good luck
Apr 10, 2008 | Televison & Video
Televison & Video Logo
1,702 people viewed this question
Top Televison & Video Experts
