Question about RCA L32HD31 32 in. LCD HDTV
My rca hd tv will not pull in hd
I have cable and the tv has trouble with a strong hd connection.
    Top Expert:
  • RCA Master
  • 14,553 Answers
Its either the set or the signal, one or the other---since its a smaller set have you considered moving set to a friends house and trying there.
If using a box for HD it is possible as well.
Let me know what you have tried or not.
Posted on Dec 05, 2012
I connected my dvd player to my hdtv and its only in black and white. I have adjusted the settings numerous times and it isnt fixed. the cables are all in the right color matching holes..how do i fix this?
Ur RCA AV component cable set might bad replace it with another RCA set of cable or tv have HDMI and also DVD player too for HD connection by a HDMI cable through HD hub?Buy and used a HDMI cable connect tv and DVD player to together one HDMI cable for a better functions.
Mar 21, 2011 | Hitachi P50H401 50 in. Plasma HDTV
What type of cable do I use to connect the Home Entertainment System. I have an HD tv with a cable supplied HD box. Do I connect the HES to the tv or the cable HD box? Which "wire" do I...
if your HES has a HDMI input and output run 1 HDMI cable from the cable box to the HES then another from the HES to the TV.
If the HES does not have HDMI in then run the HDMI from the cable box to the TV
and an Optical digital audio cable from the cable box to the HES
Dec 03, 2010 | RCA Televison & Video
I have a customer on the phone who has a olevia flat screen and can not locate an input for his cable wire. where are they located?
here are the only signal inputs located at the back of the tv.
1 x HDMI input ( 19 pin HDMI Type A )
2 x component video input ( RCA phono x 3 )
1 x VGA input ( 15 pin HD D-Sub (HD-15) )
Audio line-in ( RCA phono x 2 )
2 x S-Video input ( 4 pin mini-DIN )
2 x composite video/audio input ( RCA phono x 3 )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x SPDIF output ( TOS Link )
1 x audio line-out ( RCA phono x 2 )
1 x subwoofer output ( RCA phono )
1 x serial
If you are looking for a coaxial cable input.. it is actually not available so you have to connect a converter from coax cable to RCA cable for you to connect it on your tv.
Jun 04, 2010 | Olevia 237T 37 in. LCD TV
I have a 2006 RCA 52 inch rear projection TV and I am having trouble finding a HD cable that will fit my TV and the DVD player. Do you have any ideas?
Try another method,get the same result.Ur tv have a S-Video connection in ur tv?Use that the S- Video cable,and that connection.Than use the RCA Red,Yellow hook up for the audio.
Apr 29, 2010 | RCA HD52W58 52" TV
Sony kp 51ws510 upgrade to HD - how to do this
There are inputs on the back of the set. If your tv is Sony 51ws510 then it is capable of HD, but you have to have component or DVI cables to connect the tv to the HD device (HD cable box or DVD player).
<br>
<br>
On your set the component inputs on the back of the tv are video5 and video6 in the middle located in a vertical line (red, green, blue rca video connections with red and white rca audio connections).
<br>
<br>
You also have a DVI input toward at the top of the input panel (white connector with red and white rca audio connectors).
Jan 03, 2010 | Sony KP-51WS510 51" Rear Projection...
My menu says dtv Currently unavailable. How do I use the HD feature on my Olevia LT32HV
Do you have a High Definition cable/satellite reciever or a Blu-Ray player? Does your tv have a HDMI input or component or DVi or all of those? Most newer HD components use the HDMI connection. The HDMI connection is a single cable that has both video and digital audio together. The component connection is a connector with three rca jacks that are red, green, and blue. Audio is connected seperately with this connection via red and green rca audio jacks or a digital audio connector. The last is a DVi connector that is found on computers. Some older HD tvs and components use this connection. There are adapters available to turn a DVi connection into a HDMI connection. So if your TV does not have a HDMI connection but your HD reciever does you can use and adapter but you will not have any audio this way without using a seperate connector for the audio.
Sep 16, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
Psp connection to the TV
The cables you speak of is called component cables. They only go into color coded connection in the back of your tv. The best way is to look behind your television and more than likely there should be rows of either three or five connection and or markings saying RCA or Component connection. What your looking for is component.
Just to give you some info:
The cables you own will play vids, music, and games. But in order for the games to work you must have a HD TV.
If you see RCA jacks for your psp 2000 (slim) or 3000 (lite) than the only things will work is vids, & music (on any TV so long there is a RCA connection doesn't have to be HD).
Hope that helps.
Jan 23, 2009 | Sony PlayStation Portable (PSP) Console
I recently purchased an xbox, but because of the cable box, i dont know to to get video
Your cable box and TV should have RCA input jacks (Red, White, and Yellow) Red & White are for Audio and Yellow is for video feed...
HD Receivers & HD TV's are just slightly more upgraded with better video feed connections.
HD video can use three color coded RCA jacks for the video feed or a HDMI cable; if you can use the HDMI connection on your TV I recommend using that because it's less confusing to plugin the input cables. Try turning your TV to it's side to see what inputs you have available to connect your device to.
After you have it pugged your device into the input jacks press the "Input" key on your TV remote and power up the device.
Most TV's have more than one input, so you may have to cycle through the TV inputs by press the input key again until the video feed is displayed.
(If you don't have a "input" button on the TV or remote control you can try entering channel "00")
Nov 28, 2008 | RCA T09081 9 in. TV/VCR Combo
Connect MM36110 to Directv HD Receiver
Use both VGA cable where require,the rest use HDMI cables
Aug 17, 2008 | RCA MM36110 36" TV
RCA HDTV Cabel Connection
HD doesnt come over the coaxial cable into the TV. It has to use HDMI, composite (5 color RCA cables) or DVI. they can all be soldered back on if you ripped one out. easier to use another input if you have multiple formats back there.
May 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA L32HD31 32 in. LCD HDTV Logo
79 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
