Question about Canon imageRUNNER 400S Copier
Switch main power off and on e001 - Canon imageRUNNER 400S Copier
2 Suggested Answers
SOURCE: On copier sow display bord "Swith main power off and on E001
When switch on ImageRUNNER 330s Grayscale Copier then no display on dispaly board. But Copier front yellow led is on. Please solve this problem.
Posted on Nov 12, 2009
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
Ihave canon 400 problems. e051, e901, e805 problems frequently please suggest me
by the look at your problems:
E051 - Horizontal registration sensor problems
E001 - Fixing temperature faulty
E805 - The Fan rotation problems
It can be that You have problems with DC contoller ( main pcb ) or the copier is in worst condition and there are faults on every segment.
For E001, you can try to reset error:
1. The following error codes cannot be reset by merely turning off and then on the main power.
They require resetting in service mode:
E000, E001, E002, E003, E004, E032, E717
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
2) Press the OK key.
3) Turn off and then on the main power.
2. Error codes other than the above may be reset by turning off and then on the main power.
n Detail Code
Some error codes offer detail codes, which may be checked in service mode:
COPIER>DISPLAY>ERR (3rd block from the right)
BUT I THINK THAT THE BEST SOLUTION IS TO CALL SERVICE TO RECTIFY THE PROBLEM OR YOU BUY NEW MACHINE:..
Hope that helps!
Jul 22, 2011 | Canon imageRUNNER 400S Copier
Respected sir my ir400 canon xerox mashin masage is switch main power off and on.e001 i have machin switch main power off and on but problem not a solve pls discription this probem and solve. thanking...
it is related to fing unit.
you can go in service mode by pressing (additional function +2 +8 + additional finction)
touch on copier then go in function after that touch on clear
Err -then press ok
dcon then press ok
rcon then press ok
if then after problem not solved you have to replace fixing unit thermistar
because it is related to fixing temperature.
Apr 12, 2011 | Office Equipment & Supplies
Inherited this 2200 w/ new political office. Was working fine and making clear copies - then error code E000000-0000. Restarted machine - tried Press * Press 2 Press 8 Press * - got nothing. Help.
E000
Indicates either of the following: the main thermistor (TH1) has poor contact
or an open circuit; the thermal switch (TP1) has an open circuit; the
main/sub heater has an open circuit; the main power supply PCB is faulty;
the DC controller PCB is fatly; the door switch is faulty.
In the case of E000 through E003, the code will not be reset when the main
power switch is turned off, requiring the use of service mode
(COPIER>FUNCTION>CLEAR>ERROR).
However, if E001 or E003 is detected within 3 sec after the front door
switch is identified to have been opened or closed, the code will be reset
when the main power switch is turned off and then on. This consideration is
to prevent a service call in response to an error detected when the switch
operation is not fully stable (as immediately after turning off and then on
the main power switch).
Feb 03, 2011 | Canon imageRUNNER 2200
E00001-002 Error cod?
Thanks for using Fixya.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Go into service mode, go to COPIER > FUNCTION > CLEAR > ERR.
Select ERR to highlight, and press OK key.
Turn off the copier using the main power switch (on the right side of copier).
Wait at least 10 seconds and then turn the copier back on using the main power switch.
If the error is still there then you will need to take your printer to a canon service center.
Good luck and have a nice day.
Nov 08, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
May 29, 2009 | Canon ImageRUNNER 330s Copier
Power not on
sorry to say you have blown the main breaker on the main switch or your power cord is bad but on the off side check the power board for a bad cap.
Oct 20, 2007 | Office Equipment & Supplies
Canon imageRUNNER 400S Copier Logo
old marine
old marine
