Question about Refrigerators
Have a new frigidaire how long does it take for ice bin to fill after waterline install
Installed waterline last night icemaker working but not much ice this morning
  • 441 Answers
Ice maker will call for water 12-14 hours after plug in. If the ref was running and then Waterline was connected it should call for water in 4 hours or less. Easy rule, after 24 hours, ice bin should be full.
Posted on Dec 06, 2012
SOURCE: kitchenaid superba icemaker leaking/freezing in freezer section
Thank you, I am going to go check right now
Posted on Nov 09, 2008
  • 85 Answers
SOURCE: kitchenaid ref's icemaker water line shutoff
http://home.howstuffworks.com/icemaker.htm
click the link.
Posted on Feb 26, 2009
waelmet
  • 6 Answers
SOURCE: Icemaker not signalling for water.
cheek the condenser fan.if its opration is not correct.
Posted on May 23, 2009
  • 358 Answers
SOURCE: My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Posted on Jul 14, 2009
  • 36 Answers
SOURCE: I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Posted on Jul 24, 2009
Installed new icemaker still not making ice
Some icemakers have to be turned on inside the Freezer at the Icemaker itself, it might be as simple as a small on/off switch or a lever that completes the curcuit to the solenoid that allows the tray to fill. Remember: None of that will matter if the Ice Tray "Overfull" Safety Bar is in the Up position because that is a Safety switch that shuts OFF Power to the Icemaker. For You Novices... That's the bent silver Wire rod thingy that hangs over the Ice Bin/bucket deal. Simply grasp it and see if it will move down a bit, gently. If it moves freely, downward, You should hear the Icemaker start working! WARNING: Don't use the first few batches of Ice, after the second or third cycle, it should be pretty clean.
Sep 26, 2014 | Kenmore Side by Side Refrigerator
Ice maker not dumping ice
It could be the harvest thermostat or the mold heater is bad on the icemaker. It is usually better to just replace the icemaker. Installing a harvest thermostat is a but tricky and the mold tray is 3/4 of the icemaker anyway..
Apr 08, 2014 | Refrigerators
Model FGHB2846LF3 ice maker not working
The ice maker has a heater element underneath it that is designed to melt the ice a little bit so that the fingers of the icemaker can scoop out the ice. If the element does not turn off and the fingers do not push the ice out it will melt with the result that you have. Appears that the cam conducting the operations is not working properly. Rather than buy this part separately (expensive) you can get a new working icemaker on ebay for about 45 dollars and you can easily install the unit yourself.
Nov 27, 2013 | Frigidaire FGHB2846LF
Is there a shut off valve on the ice maker?
There should be a shut off valve at the beginning of the water line that the installer tapped into when installing your icemaker. Mine runs down through my kitchen floor into my laundry room and is tapped into a copper cold waterline with a small handle attached to it.
To stop icemaker from making ice simply raise the lever to the up position that is attached and hangs next to your icemaker tray. This works on most models.
Aug 24, 2010 | Kenmore 53642 / 53644 Side by Side...
GE Fridge icemaker is not working - Help!!
I installed a new icemaker (cost approx $100) and its making ice. Very easy to install yourself (remove 4 screws holding part below icemaker, then unplug icemaker, and unscrew the 2 screws holding it in place.). Good luck-
Jan 28, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
Water runing down back side of icemaker and forming icicle.
If it is running down the back of the icmeaker then you need to make sure the inlet tube is properly installed into the fill cup on the icemaker. If the tube is in the right place then your icemaker fill level needs to be adjusted.
Dec 07, 2008 | Refrigerators
Refrigerators Logo
713 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
