Question about Muratec Copier
My muratec mfx2030 printer won't work in windows 8, i tried pinging the port still won't work. how can i get the two to communicate?
AGPTEK sc9-5870 thermal printer won't print
I got mine to work by changing the port from USB001 to USB002 prints great now, there is problems with installing on windows 8, you have to disable driver verification or the driver won't install.
Good printer don't give up on it.
Feb 07, 2013 | Brainydeal Agptek High-speed 58mm Pos...
Cannot get wireless connection to printer
Print a configuration page from the printer and get the ip address of it. Make sure you can ping the printer. Open a command prompt and type ping <ip of printer> and see if you get a reply. If you get a reply go to the printer properties on your computer and make sure the port is set to the ip of the printer. If it isn't create a new Standart TCP/IP Port and type in the ip address. Leave the port name alone.
Oct 21, 2012 | Toshiba Satellite Pro A200-EZ2204X...
Can't get windows xp home edition to recognize wireless printer, even after assigning printer TCP/IP address. Windows 7 computer prints to it, but the Windows XP computer can't even find the...
Hi!
You din't wrote what's the model of your printer, but I think we can find a solution:
1. Try to ping the IP adress you assigned to the printer. If that works, please download the latest drivers or installation software from the manufacturer of your printer (or second option use the installation disk that came with your printer). If it does not reply to ping, be sure the IP adress you assigned to the printer is in same range as the IP adresses on your network.
2. It is possible that the installation software itself manage to find the printer on the network, and that means the problem is solved
3. If not, install the printer as it is local attached (e.g USB or LPT port)
4. After installing as local printer, please go to printer proprieties, go to port, choose add a new port, choose standard tcp/ip port and write for the port the IP adress you assigned to the printer.
5. Apply changes and ...that's it.
Please let me know if it helped,
Aug 10, 2011 | Microsoft Windows XP Home Edition
I've been using a dell 3100 through a home network for several years. Suddenly I can't print. The network can't find the printer. I can print to it if I connect through USB. I have tried...
Hi
Please check the mention below option
1) First you get any error in your printer screen
2) If you are print through Network please ping your printer if you are not getting the print.
Open command prompt and type ping 192........your pinter ip, if you r getting reply to your printer
its mean your connect to printer.
3) Remove your printer driver and install again.
Jun 01, 2011 | Dell 3100cn Laser Printer
I am attempting to set up a Muratec MFX-1430 printer for a client and it does not seem to be communicating via the network. I have it plugged directly in to the Belkin wireless router that the desktop PC...
IF YOU HAVE THE INSTALLATION CD THAT WAS SUPPLIED WITH THE MACHINE THERE IS A "MANUAL SECTION" IN IT THAT EXPLAINS HOW TO SET UP THE INSTALLATION.
iF YOU DONT HAVE THE CD YOU CAN DOWNLOAD IT FROM MURATECS WEB SIT AT THIS FOLLOWING LINK http://www.muratec.com/new/support/manuals-for_muratec0o34534021023994938849.asp
Oct 01, 2010 | Muratec MFX-1430 Copier
I have a Muratec 2850 Printer that I need to print to over the internet. I can "PING the router Ip address and I have set the route to forward. I am able to access the printers software remotely but can...
The 2850 needs to have the Officebridge set-up disc run to create the GDI port on your PC.
If you are trying to set up using the "add printer" wizard the it most likely will not work as the port is not created properly.
Aug 09, 2010 | Muratec - NETWORK PRINTER OPTION...
IoGEAR printserver GPSU21 with VISTA
Yes, the GPSU21 is tested to work with Vista 32 and 64-bit Operating System. The things you need to do is listed below:
1. There's no need for you to install the CD that came with it, if the MFP Utility is already installed in another computer.
2. Get the IP Address of the GPSU21 from the computer that has the MFP Utility installed.
- Open the MFP Utility > locate TCP/IP at the lower portion of this window and click the plus (+) sign. > get the IP Address.
3. After getting the IP Address of it, go to your Windows Vista computer and ping the IP Address (just to make sure that Vista is seeing the Print Server).
- To ping, follow the steps below:
- Click the start menu and open the MS DOS Command Promt.
- On the black screen, type this "ping (type the IP Address of the print server): just like this
- C:WINDOWS\Desktop\Scott>ping 192.168.x.x and then hit enter.
4. Once you get ping statistics 4 packet sent; 0% loss. Then the Print Serve is communicating with Vista.
5. On you Windows Vista computer, make sure that the printer is working when directly connected to it. Because there could be a possibility that the printer driver is not properly installed that's why the server is not working.
6. On Vista, go to the Control Panel > Printers > Locate the printer icon (the one that is set as you default printer)
7. Right-click on the printer icon and then select properties > go to Ports tab.
8. Click on Add port button > select Standard TCP/IP > click on "New Port" (beside Cancel)
9. Hit next > type the IP Address of the print server. > Next
10. Click on Custom > Settings button
11. For Protocol: select LPR
12. For the Queue Name: type L1 > Click on OK > Finish.
13. Then under the printer properties, you will see the Standard TCP/IP is selected
14. Hit Apply so that the printer name would appear right next to that port > OK
15. Try printing a test page.
NOTE: After following the steps, you should be able to print using your Vista computer. I configured this print server with Vista several times and it does work with Vista.
Feb 19, 2009 | IOGear GPSU21 Print Server
MFX -2380 (Muratec) issue with net work printing
In network environments the muratec's usually have to have the setup disk run. They do not work on the standard TCP/IP port. The disk creates a muratec port for the pc to print to.
Jul 21, 2008 | Muratec MFX-2830 Black and White Copier
Network
GO to the controll pannal and printers and say add printer choose network printer if u know the ip just put your ip address and say next it should detect it if not try to go to command promt and ping the ip with the ping command
if it gets the repply frmtheip so its comunicating
Jun 15, 2008 | Muratec MFX-1200P All-In-One Led Printer
Muratec Copier Logo
121 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
