Question about Radio Communications
Red light flashing
Led on radio flashing 5 times then a beep repetitively
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Robert,
What's flashing? your Radio? Your Toilet? your Partner?
I need more info about your radio, before I can help you>
I need the Make/Model of your radio, without this info, I think it is the Red Leds on a cop car flashing.
Don't be afraid to give as much info as possible.
Cheers,
Peter
Posted on Mar 18, 2013
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
ERASE ALL PROGRAMMING
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
http://napcosecurity.com/download/PL3000_WI1280A.04_PROG.pdf
Good luck-and please provide feedback if this helps!
Nov 04, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
I have a Chamberlain Whisper Drive and it started beeping. Reading the manual, it seemed that I needed to replace the battery. It is about 5 years old. Replaced the battery and the LED is no longer red but...
On the back of the garage door opener there is a red button. Depress this button and sync your keypad to the opener. This will re-establish the code and reset the remote.
May 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hp compaq dc 7100 , my problem is that as i start my pc than 4 beep with time interval 0.2 sec with led than after 0.5 sec it start again , remain continously
Are they Long Beeps? Does the RED led light on the front show up?
If there is no RED led light blinking, then the problem is your RAM.
If there IS a RED led Light showing up, then the problem is your Power Supply.
Mar 27, 2011 | HP Compaq dc7100 PC Desktop
SONY VPL FX-40 projector. After plug in-ON/Standby LED is red for few seconds and starts flashes in red(repetition rate of 12 flashes). After pressing I/O key-ON/Standby LED flashes in green(few...
A Flashing Red ON/STANDBY LED means one of the following
2 Flashes - The internal temprature is high. Check the air holes are unobstructed.
4 Flashes - The fan is broken
6 Flashes - The internal electrical system has failed.
There is no entry in the manual for 12 red flashes.
Feb 19, 2011 | Sony VPL-FX40 Projector
Power to TV, cant power on, red light flashing
The repetitive blinking light is a trouble code which is used to determine which series of boards may need to be replaced. How many times does the red light blink?
Aug 20, 2009 | Panasonic Viera TH-42PX80U Plasma TV
My philips 50p8341 beeps then flashes the red led 4 times
4 Blinks means that an incorrect voltage had been detected on the +5V circuit coming from PSU to digital control board.
The PSU must be tested and eventually repaired or replaced.
Aug 08, 2009 | Philips Televison & Video
Motorola BPR40 how to clone
How To Clone a BPR40 Radio
Cloning duplicates the contents of your radio (master radio) into the new radio (slave radio). Tuning and alignment information are not affected by cloning.
Set Up the Master Radio
1. Turn off the radio.
2. Press and hold Programmable Button 1 (the top programmable button) and turn on the radio. Keep pressing the Programmable Button 1 until beep is heard twice.
3. Release Programmable Button 1. Notice the LED changes to RED
Set Up the Slave Radio
2. Press and hold Programmable Button 1(the top programmable button) and turn on the radio. Keep pressing Programmable Button 1 until the beep is heard three times.
3. Release Programmable Button 1. Notice that the LED changes to GREEN
BPR40 Radio to Radio Cloning Procedures
1. Connect the cloning cable to both the Master and Slave radio.
2. Press and release Programmable Button 1 of the Slave radio.
3. Within 2 seconds Press and release Programmable Button 1 of the Master radio.
4. The LED for both radios show flashing orange during cloning.
5. Once cloning is completed, an
Mar 24, 2009 | Radio Communications
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
PC won't Boot Up
Here is what is says in the owners manual in what to do in this case, Hope this is a Help, Happy Holidays
Red Power LED
flashes five times,
once every second,
followed by a two
second pause.
5 Pre-video memory
error.
1. Reseat DIMMs. Power on the
system.
2. Replace DIMMs one at a time to
isolate the faulty module.
3. Replace third-party memory with
HP memory.
4. Replace the system board.
Red Power LED
flashes six times,
once every second,
followed by a two
second pause.
6 Pre-video graphics
error.
For systems with a graphics card:
1. Reseat the graphics card. Power on
If you need anymore let me know and I will post them for you.
Dec 15, 2007 | HP Compaq dc5100 PC Desktop
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
