Screen just displays that then cuts off.... Not sure if fan is cutting on either
  • Computers & ... Master
  • 5,660 Answers
Remove all Ram Memory, and clean the gold plated contact pins with a pencil eraser. Use air to remove the eraser dust. Reinstall. I'm betting more on Power Supply failure, but we'll see. What model number of MAC is it? Post back in a Comment. Not a Solution. Do not have Clarification, or Comment option available.
Posted on Dec 05, 2012
How do you check a fan motor
You need to check the volts at the motor while it's running, to make sure some safety is not shutting it off. Then check the amps on the motor while it's running. Also you need to check your capacitor and wiring.
Apr 30, 2014 | Heating & Cooling
A/C fan cuts out completely when on high fan AND recirculate
Replay the blower resistor. Used to be you could replace the relay, but they are built into the resistor now. Should be under the passenger side dash. Usually behind the blower. There will be four to six small wires going to it and two big wires coming from it going to the blower motor.
Jul 13, 2013 | 1996 GMC Yukon
Why does stereo amp cut out at higher volume
You seem to have the answers to your question. I would just resolder the connections anyway without checking. If it solves the problem you have saved yourself a lot of money. If it doesn't follow the other steps in order of cheapness!
May 03, 2013 | Audio Players & Recorders
A/C cuts out if fan on max. speed.2000 Mazda MPV fan very slow in 1,2,3 but powerful in 4. However a/c works in 1,2,3 but with fan on 4 it cuts out and won't restart. Obviously the fan resistor
sounds like a fault with the switch unit for the fan ,to know for sure i would need the offending vehicle in front of me take the switch out and have a play ,also of course threaten it with the lump hammer but all joking apart its difficult to diagnose without a play to determine exactly what the problem is
Aug 20, 2012 | 2000 Mazda MPV
We have a newmac wood furnace with a honey well fan limit control. It cuts in but will not cut out.
if it is the fan that wont cut off, make sure the manual over ride button,(white push/pull) is in the auto position.if the burner will not cut off then the spring on the control is failing and the control should be replaced.control can be found online or at most heating supply companies.
Dec 20, 2010 | Honeywell L4064B2236 Fan/Limit Control...
I can't figure out how to remove shortcuts from the home screen of my LG Chocolate Touch. I can drag shortcuts such as calendar or calculator to my home screen so that I can simply open them in one touch....
go to your main menu, go to settings. go to displays. scroll down to "short cut bin" snd make sure it is turned on. a faded arrow will now appear on the right side of your display screen. drag the icon you want to get rid of to the arrow which will turn into a trash can.
Nov 12, 2009 | LG CHOCOLATE VX8500 Cellular Phone
It won't cut on. just charge light and the on light and fan does.
Check you memory Remove and put back(Make sure remove the power and battery first), Check your bios /CMOS time. try again. No solved
Try to access the F8 and scan your computer, no solved, See TechGuy.
JMC
Aug 13, 2009 | Toshiba Computers & Internet
Tuono R 2007 Engine cuts out when fan kicks in and won;t
By fan you mean the radiator fan? If so try the following. If a coolant temperature of between 239oF(115oC) and 275oF(135oC) appears on the multifunctional digital display, stop the vehicle and leave the engine running at 3000 rpm for about 2 minutes, allowing the coolant to circulate regularly in the system. Then position the ENGINE STOP switch to "OFF" and check the coolant level to make sure it is ok. If after checking that everything is ok it still does the same thing the you should probably go to a mechanic.
Jun 20, 2009 | 2007 Aprilia Tuono 1000 R
Fujitsu-siemens lifebook P1610 - screen cuts out after 20 seconds left alone, have checked hibernation sequence, display modes etc. cannot find logical reason for it, really annoying! Can you help?
Go to the display properties and make sure there is no screen saver. Also go to the power option and make sure you have selected the never option for turning off the monitor
Oct 09, 2008 | Computers & Internet
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
