What is the thin grey tube next to the filter
The tube is off next to the filter at the bottom of the machine and water is coming out,where do I plug it back in please!
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 06, 2012
BIKER T
  • 909 Answers
SOURCE: Machine leaks through the filter
REMOVE WATER THEN UNSCREW FILTER AND PULL OUT.CHECK THE O RING THEN TAKE NOTE OF CORRECT POSITION WHEN REINSTALLING IT.THERE ARE SOMETIMES GROOVES THAT THE FILTER HAS TO SLIDE INTO. MAKE SURE IT IS NOT CROSS THREADED. HOPE IT HELPS TERENCE
Posted on Jul 11, 2007
ginko
  • 19396 Answers
SOURCE: I have a 7 yr
check your door rubber gasket, see if water is coming out from there
Posted on Mar 29, 2008
barkencoa
  • 3463 Answers
SOURCE: loads of slimey grey water in filter drawer and horrible smells
First of all, you need to confirm if the leak is from the filter or the pump.
You can replace the filter seperately to the pump.
If you replace the filter, and it still leaks, then you are going to have replace the pump.
I would suggest that that you check and clean if needed the outlet pipe where the water enters the outside waste pipe.
Make sure that you do a boil wash periodically, to ensure that the drum and other internal parts are clean.
Clean the door seal and dry after each wash, it helps to leave the door slightly open
Please leave any comments that may have as regards to my suggestions.
Thankyou.
Posted on Nov 25, 2009
  • 1738 Answers
SOURCE: The machine is overflowing when you run it with a full load.
Not always. It can be anything from pressure switch value to mixer value not shutting off properly.
Posted on Dec 06, 2009
197jacobs
  • 226 Answers
SOURCE: There is a tube coming
no should hook back at the top and to bottom
Posted on Oct 17, 2010
Won't spin out. Has an LE error message
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Nov 26, 2010 | LG WM-2277HW Front Load Washer
My washer is not working it begins to spin stops and has the letters LE appearing.
Goodluck..
May 27, 2008 | LG Washing Machines
IE is the error I keep getting. How do I reset?
Hi, plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit.
When you have rinse problems, it is usually the outlet filter.
Take care
Jun 13, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Wont drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For most front loaders:
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
For some front loader models after removing the bottom toe panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
You could also check the exit hose of the washer for blocks. Next snake out your wall drain, it helps.
Jun 12, 2010 | Samsung WF337AA Front Load Washer
Tromm LG front loader error code
Already answered by an expert :-
Thanks.
Jun 17, 2009 | LG WM-2277HW Front Load Washer
Zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Dec 17, 2008 | Zanussi ZWF1430W Front Load Washer
WM1832CW, wont drain and spin, has LE error, was able to drain water, using spin only function, still would not spin, sounds abnormally, drum is not moving at all. I know LE means motor overload, but what...
Dec 12, 2008 | LG WM-2077C Front Load Washer
Spots of Grey lint left on clothes after washing
Have you cleaned the filter on the front bottom of the machine?
May 11, 2017 | Bosch Washing Machines
Water spitting out the top of the Siphon tube when filling...
Suggestion: Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit.This tube controls the water level. Next clean out your outlet filter, it could be clogged, refit. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Frigidaire GLTR1670A Front Load Washer
Maytag LAT9800ABW
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Do not overload your machine, the manual will tell you the max load. Check to see if any hose has come loose from behind the machine; look inside from behind.
Sep 11, 2007 | Maytag LAT2300 Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
