Question about Sony Vintage Mds-101 Compact Chassis Mini Disc Player Recorder Powers Up
Any disc inserted just gets ejected
These MDs play fine on my working device. The panel says "Reading TOC" and switches to "Ejecting"
Leave the machine on for a few hours and try it again. I had the same problem and this somehow solved it.
Posted on Oct 13, 2013
  • Sony Master
  • 1,258 Answers
Either the loading is not completing of the mechanism or the laser pickup lens is dirty.
Posted on Jan 29, 2013
  • Paul Schanbacher
    Paul Schanbacher Oct 13, 2013
    I have a MDS 101 that i stored away for a couple of years and it was doing the same thing. I left it on for a few hours and came back and it worked fine. I probably tried it 50 times before I walked away.
  • 4234 Answers
SOURCE: I have two rack mountable
I have repaired a number of these over the years, the main problem is usually the loading mechanism or the optics. Neither is cheap. Where are you located?
Dan
Posted on Feb 17, 2009
HW_Dude
  • 87 Answers
SOURCE: Spontaneous MD erasure
Well, depending how the content was recorded, there may be a slim chance to recover the audio. To me it looks like TOC was not written successfully, effectively deleting the TOC.
You can try TOC cloning with this 'blank' MD using another MD player, but your track markers will be lost during the cloning. If it works, at best you will end up with ONE long track. Then you can edit and reset your track markers.
It may be also be a good idea, to try the JE440 carefully with junk content to make sure it still works ok when writing TOC. You may have an intermittent problem too. I'd be very careful editing MD in this unit until it has been confirmed the TOC writing works ok. You may want to check the over-write head assembly and the cable that connects it. Sometimes these cables develop hairline cracks causing intermittend write action.
Check out www.minidisc.org forum for TOC cloning.
Good luck recovering your audio.
Posted on Mar 18, 2009
SOURCE: MDS-JE470 mini-disc capstan motor will not rotate disc and ejects
I have not had your problem myself, however, I am pretty sure the disc/s you are trying to play are not in the same readable format your MD player is, hence, the ejecting. I think you might have to either connect your player to a computer and re-initialise the system format/s and/or you may just have to (annoyingly) replace all of the MiniDiscs you have - which is not the best/rewarding way to go... quite irritating actually !!
Good luck to you though !!
Posted on Mar 25, 2009
SOURCE: MDS-JE480 MiniDisc Deck
The problem with the TOC reading and then appearing C13 is a problem with bad electrical contacts.
Remove the connection to the mains outlet, remove the top cover (5screws) and the remove the 2 paper flatcables that connect the main PCB and the disk unit on both sides. Plug them back in and possible your problem is solved.
A better solution is, of coarse, to replace both cables by new ones, as the quality is rather bad, and once disconnected, they should be replaced.
Good luck!!!
1000 soluciones
Posted on Jun 22, 2009
Obertelli
  • 3006 Answers
SOURCE: Sony MDS-JE480...Inserting disc..C13 error READ
The c13 error means that the player is unable to read the table of contents (TOC) on discs any more.If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
On the plus side, there are millions of MD units now lying unused as folks have moved on from them and as they're mostly worthless people don't generally bother with trying to sell them. Almost every piece of MD gear I own has come free of charge via my local FreeCycle and Freegle groups. Whatever you do, don't buy a used player from anyone: they're all getting on now and the TOC error is an age-related fault which may occur at any time.
If you wish to see exactly what features other machines have then visit the superb equipment browser at minidisc.org. The site is hosted but n longer maintained though so some information is out of date, but it's still the most comprehensive source of free information about MD available.
Sorry here's probably no hope for your MDS-JE480, but I hope that my reply has given you a practical alternative means of solving your problem.
Posted on Oct 07, 2010
Disc ejected and then retracted.
Check on the web for the fix. Many people had an issue with the Sony MDS-JE500 series MD units as the little lever switch that indicates that a disc is loaded goes bonkers and it might be as simple as 'adding' a non-sticky item to the lever. Do a Google search for 'mini disc switch fix'. Good luck.
Jan 25, 2014 | Sony MDS-JE520 Mini Disc Player
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
Toc not writing
I was going to note that when you first turn the MD recorder on is when it will write the TOC for the disc - so even if you turn it on and press eject, it is smart enough to write a TOC first, then eject the disc. Good find on the battery loss.
Sep 02, 2013 | Sony MDS-JE520 Mini Disc Player
SONY MDS JE 530. (C14) Toc error.
You may well be right. Try a different brand of disc.
Apr 01, 2013 | Sony MDS-JE330 Mini Disc Player
Your owners manual (you DID read your owners manual, right?) says the machine cannot read the TOC on the disc.
It might be a disc problem and it might be a deck problem?
Have you tried a different minidisc?
Have you changed any of the SET-UP settings? Take a look at them, too.
Apr 01, 2013 | Audio Players & Recorders
UPON EJECTING THE DISC FROM MY MDS-JE440 IT IS WIPING ALL DATA AND BLANKING OUT THE DISC COMPLETELY ! IT HAS ONLY STARTED DOINING THIS IN THE LAST DAY OR TWO AND I'VE LOST MUSIC OFF 6 DISCS COMPLETELY, SO...
I think your recording head failed, you should stop using the deck and get a similar used one which works, repairs are usualy not cost effective.
Prodigital in Philadelphia does repairs, I paid about $250 for a replacement loader unit installed + shipping.
Feb 09, 2011 | Sony MDS-JE480 Mini Disc Player
Sony mds-je520 on stand by led on bur cant tern on player
Make sure the "TIMER" "Rec"/"off"/"Play" switch is set to "OFF".
Then press power, and you should be in business as soon as it read the TOC on the disc. Without any disc inserted, it should go straight to being ready.
Apr 27, 2010 | Sony MDS-JE520 Mini Disc Player
Jb 940 md player. Recording a full disc, always results in playback stopping around 38 mins. previously recorded discs will play back ok, so suspect record process not completing. When played in spare...
When you get done recording, do you wait until the "TOC" light stops flashing? If you cut off power before the Table Of Contents is written, then it can't find all your music. Even if you eject, it should still flash a little red TOC or UPDATE before it spits the disc out. Check for that. okay?
Apr 11, 2009 | Sony MDS-JB940 Mini Disc Player
Mar 16, 2009 | Sony MDS-JE440 Mini Disc Player
I have two rack mountable minidisc players can any one in the world fix these things(frustrated).An MDS-E 12 & an MDS -E 10.One just fell over backward from the ground in a wooden rack. The other electric...
Dan
Jan 23, 2009 | Sony MDS-E12 Mini Disc Player
Sony Vintage Mds-101 Compact Chassis Mini Disc Player Recorder Powers Up Logo
111 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
