Code error with scanner model no: MFC-240C
Code error (CC3-205-03031F02). I don't know what means that code error. All I know is that the scanner doesn't work anymore. I unplug the cable related to the computer, I restart and try again to scan but the code error still there. I would very appreciate to get an answer as soon as possible because I have some work to achieve. Otherwise, I'll call my technician tomorrow, first in the morning. Thank you for the attention paid to my request. Diane
  • 1 more comment
  • dianeb03 Jan 12, 2009
    Brother, Model No: MFC-240C
  • dianeb03 Jan 15, 2009
    The problem has been identified by my technician and the solution was to change the mouse.
  • odiegh
    odiegh May 11, 2010
    what make and model printer
Thank you, my technician fixed it.
Posted on Jan 12, 2009
Brother mfc-430w printer install problems vista
Start > Accessories > Command Prompt
OR
Start > Run > type "cmd.exe" (without quotes) and click OK
In the black window that opens, type "sfc /scannow" (without quotes) and
press Enter. Have your Windows XP CD handy.
If you don't have a WinXP CD, see: http://www.updatexp.com/scannow-sfc.html
Jan 04, 2012 | Brother MFC 240C All-In-One InkJet Printer
Troubleshot 46 on mfc-240c
Error code 46 means that your ink absorber pad needs to be replaced. According to Brother, only an engineer can do that, but you can get more information from them by contacting Brother support:
http://www.brother-usa.com/Support/
Click on "Send us an Email" and tell them your printer's model number, the error code, and whether or not your machine is covered by a warranty.
Jun 09, 2010 | Brother MFC 240C All-In-One InkJet Printer
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
The brother printer mfc-240c says that please wait and then it starts beeping and again plzz wait. What is the problem. What should i do
Please push the menu button, then start mono, then 4x arrow up. Display should be ||maintenance|| and printer should beep. What error code does the display show up?
You have to open the scanner as if you were changing the cartridge. There is a "-----;-" cover which hides the flatcable. Remove this cover and reinsert the flat cable to the mainboard by simply sticking it into position. May or may not work, it may have wiggled loose.
Sep 07, 2009 | Brother Multi-Function Center MFC-240C...
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
XX
The machine has a mechanical
problem.
—OR—
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
HELP ON MFC-240C
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Sep 01, 2008 | Brother MFC 240C All-In-One InkJet Printer
Error code cc3-205-03031f02 will not scan
What model do you run? Is it a brother mfc 240c or something diffrent?!!
I ve never seen such an error code for brother mfc 240c printers!
Dec 27, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC-240C init. unable AF error message
Sure. No prob.
Open scanner cover as you would do to check for a paper jammed sheet.
Do open the plastic which runs from middle to the right side (looks like a "Z" turned clockwise). Use a small screw diver for that. beneath you will find th flat cable of the scanner. You have to reconnect the flat cable by simply sticking it into position onto the main circuit board. make sure flat cable is in good position and click the" Z  "onto the channel. Close cover then power up and do what ever you want to do with your mfc ;-)
Dec 12, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Oct 23, 2007 | Brother MFC 420CN All-In-One InkJet...
Error change unable 51
Unload the software. Restart the computer come off line. disable the anti virus Re install follow the prompts exactly. If still introuble take a look at www.fixyourownprinter.com
Aug 31, 2007 | Brother Multi-Function Center MFC-240C...
360 people viewed this question
k24674
jasbo
jasbo
