Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
How to replace door lock
The dishwahser door will not close tight. I think the lock is broken. Could anyone advise what part to look for and how to repair. Thanks
    Sergeant:
  • 236 Answers
It may just need adjusting. it is located inside the top center of the door. check catch and lock. most of the lock is inside the door and is accessible by taking off the front panel.
Posted on Jun 11, 2007
Door will not lock light stays on
Usually this is caused by the door being bent, the hinges being bent, or a worn out door strike/catch not holding the door tightly closed. Lol, got kids?? Mommy's little helpers love to lean on the doors(the ones that open/close vertically). Also, slamming the dryer door can break the little plastic arm attached to the door switch--I see MANY switches with the arms broken in-half or the strikes/catches damaged from slamming. Usually a relatively simple repair to replace the strike/catch.
Aug 13, 2015 | Kenmore Dryers
Need the wiring diagram for 1999 Suzuli Baleno power locking
try removing the fuse from the panel in the trunk and replacing it. it work for a lot of people including myself. Look at the doors and trunk closely if they close tight and release a bit you have a leak in a vacuum line
Jan 15, 2014 | Cars & Trucks
Door wont open on Hotpoint WM51 First Edition
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
In your case you might have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Apr 25, 2013 | Washing Machines
Washer. door lock wont lock. I hear a click click, like it's locked, but the indicator lock light is not on, then a couple seconds later I hear another click click like it's unlocking and then...
the actual door lock switch inside the wall of your washer where the door clips in has most likely burnt out or a piece has broken out of it i have found the only way to fix this problem is to replace the door lock switch
Jun 07, 2011 | LG WM-2277HW Front Load Washer
My Diplomat dishwaHser ADP8352 door drops like a stone How DO i FIX THIS
LOOK AT THE BOTTOM OF DOOR AND YOU SHOULD SEE THE SPRINGS THAT SLOWS THE DOOR FALL. SOME GET BROKEN TAKE OLD BROKEN ONE AND FIND A MATCH AT PARTS OR APPLIANCE REPAIR DEPT.
Mar 08, 2010 | Dishwashers
Door lock problems for 2003 Honda
sounds like the central locking motor is gone
Aug 12, 2009 | 2003 Honda Civic
1999 Toyota Camry-we've replaced the selinoide on both front doors; the problem we're having now is sometimes the locks work great (along with the windows) and then out of the blue all doors quick working...
I would be looking at replacement of the master control switch. The other possibility is a semi-broken wire that powers the master control. What I would advise: the next time it happens, remove the master switch and plug/unplug/replug the connector. See if that helps. If not, close and open the door whilst manipulating the switches. If the switches start working, you have a bad power feed wire.
Apr 06, 2009 | 1999 Toyota Camry
Door open!
i had the same prob..and the cure was to change the bushes on the motor.its been fine since
Oct 28, 2008 | Whirlpool AWM6100 Front Load Washer
Washer does not lock
Hello, there little grip on machines door i think you need change it.
Sep 07, 2008 | Kenmore 46462 Front Load Washer
Broken Door Spring
hi you can do it if you have good hands open the cover side of the broken arm with the spirngs understand how the Mechanism works (in\out) and what went worng and hopefuly fix it or replace the springs that died good luck
Mar 23, 2006 | GE 24 in. GSD500X Built-in Dishwasher
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
168 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
