Question about Wurlitzer Jukebox CD Player
Where to get program codes for a 1990 rowe cd-100a
    Problem Solver:
  • 18 Answers
You should have no problem obtaining a manual for that unit. Google it and several sources will be available.
Posted on Oct 05, 2013
How do i get free play on my cd-100a compact disc juke box
and why would it have free play when it uses CD's
Mar 12, 2016 | Audio Players & Recorders
I just purchased a Rowe AMI CD-100a. It was a barn find. Once I learned to initialize, I tried to play individual tacks or entire CDs. For each track, the unit picks the CD, places it down on the player...
Could be the power supply voltage is low, possibly due to a bad capacitor, it seems that when the counter advances it is pulling the voltage down enough to cause the problem you are experiencing. If you can select a disc in the service mode, the counter should be inactive, and you can see if the disc will play through.
Sep 29, 2013 | Wurlitzer Jukebox CD Player
Rowe CD100A Jukebox CD carousel keeps turning.
if you got the service manual with it, it will tell you how to pull up the error codes and what to check.....I got lucky cause I just bought one and it had the manuals in it...mines is a rowe ami cd-100c. ....I just googled ur model and a pdf manual pop up for downloading. ...hope that helps!!!!
Mar 14, 2013 | Audio Players & Recorders
What is the difference between the Lexmark 100 and the 100A Printer Cartridge for the Lexmark pro 705? Is it just the number of pages they will print or is the 100A able to be refilled?
The regular version (#100) is not refillable. It is the "Return Program" or "Prebate" cartridge. Supposedly, when you buy this cartridge you agree to return the empty cartridge to Lexmark. In return, Lexmark gives you roughly $5 off the retail list price of the cartridge.
The "A" version (#100A) can easily be refilled. However, the price of the cartridge is roughly $5 higher than the regular version, so most people unknowingly buy the regular version. So it's really depends on you if you want to refill your cartridge you should buy 100A
Please let me know if you have any further questions or concerns.
Thanks.
Apr 30, 2010 | Office Equipment & Supplies
I need to know which relay is the abs relay on my 1990 corrado
relay 13 is abs pump relay,relay 14 is abs relay
If you look at fuse box,there is a row of fuses,other end row of relays
You need to check second row relays,far left and next right
Apr 01, 2010 | 1990 Volkswagen Corrado
Error 100a
HP uses a Tattoo system that has to be applied to the Motherboard and the Hard Drive. That error indicates that one of those is missing. You will have to get the tattoo program from HP.
Dec 10, 2009 | HP Pavilion dv6000z Notebook
100A battery fuse blown?
They more than likely shorted out your 100a link fuse by grounding out your alt cable while replacing it. Sounds like they didn't disconnect the battery before hand. Your car has an idle program which it re-learns every time you lose power, or in your case, turn off the switch. You need to replace this fuse or your car will not charge.
Jul 21, 2009 | 1999 Mitsubishi Montero Sport
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
TELEFUNKEN TDR-100A DVD RECORDER REGION UNLOCK CODE
You do not need a region unlock code for this recorder as it supports both NTSC & PAL
Dec 09, 2007 | Televison & Video
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
41 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
