How to put pictures from my camera to my computer if i don't have cord. can i use my memory card from camera & how do i do that. please help!
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: KODAK EASYSHARE Z710 DIGITAL CAMERA
Hi Tanya
It sounds like something was corrupted when you transferred your pictures to the computer.
If you have all the pictures safely on your computer, it will be ok to reformat the memory card and then just copy and paste the pictures back to the card.
Insert the card in your card reader, go to My Computer, you should be able to see the card as a removable drive. You can click and open it just like a folder and see what is on the card.
I would also back up the pictures to an external drive or dvd so they are extra safe!
SOURCE: transfer pictures from the internal memory to the memory card
http://www.kodak.com/global/en/service/publications/urg00402toc.jhtml?pq-path=6863
There is a listing to call their tech support.
I cannot find a way other than usb connector.
Here is a link to the manual as well...
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00402/Z730_GLB_en.pdf
SOURCE: Need to put Pictures from Camera onto Memory Card
Hi there. Here is how you do it. Go into the menu and navigate to the Copy screen. Choose an option. One is to copy pictures from the camera's internal memory to the SD card, and the other is copy from the SD card to the camera's internal memory. Then press OK. On the next screen, you have two option choices, either copy all images, or selected images. Hope that helps.
SOURCE: how to transfer pictures from internal memory to
Make sure a card is installed. In any still or video mode, press the Menu button. Press up/down to highlight Image Storage then press the OK button. Press up/down to highlight Internal Memory then press the OK button. (You'll need to set this to Auto later if you want pictures to go to a memory card instead of the internal memory.) Press the Review button, then the Menu button. Press up/down to select Copy>> then press the OK button. Press up/down to highlight what you want then press OK.
SOURCE: Took pictures on camera without inserting card, no cord
Yes, there is.
Insert the card into the camera. Make sure the storage location is set to internal memory.
Press the Review button, then press the Menu button. Press up/down to highlight Copy, then press OK. Press up/down to highlight an option, then press OK.
Note: this process is actually a copy, not a move. The originals will still be in internal memory. After you transfer the pics to your computer, you can then delete them normally.
To change the storage location, press the Menu button. Press up/down to highlight Image Storage, then press OK. Select Internal Memory and press OK.
Testimonial: "Exactly what i needed to know. Thanks!"
