Question about Panasonic Viera TH-42PX80U Plasma TV
THERE is a problem with my panasonic plasma tv the model # is TH-42PX80U I THINK IT IS ON SLEEP MODE OR IT IS on standby mode or i think it is on sleep mode with a password to unlock it from sleep mode
  • 362 Answers
We should try a hard restart first, unplug the tv for a couple of hours then try again. Let me know how it goes and please rate this solution. lone99star
Posted on Jan 12, 2009
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Power off
Just look in the menu options for "Sleep mode" and set it to OFF! If that doesn't work, try unplugging the television for an hour or set. That usually resets it to the factory default setting. You might be able to reset it by looking in the menu options and select "Factory Reset" and that should reset the Sleep mode. Hope that helps!!
Oct 20, 2012 | Panasonic Viera TH-42PX80U Plasma TV
I HAVE A PHILCO URC2070 & NEED THE CODES FOR A PANASONIC TV
Codes for PANASONIC: 0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Jul 08, 2012 | Panasonic Viera TH-42PX80U Plasma TV
I cannot turn off closed caption on screen. Panasonic Viera Plasma TH 42PV60A
hi,
To exit closed caption do the following.
1. Press the menu button and select CC and press OK button.
2. In CC menu select MODE and using right arrow or left arrow button select it OFF
3. Press OK button
4. Press menu button to exit menu option.
ok
Mar 10, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Audio settings. can't get pointer on the remote to go to default audio settings. Right now audio is very poor.
Sometimes bad audio can be caused by putting your tv in surround
mode. By putting television in stereo mode for this model can sometimes get better audio. There is also an issue with this model
that requires a technician to alter the service settings for audio.
Oct 22, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera TH-50PX60U Plasma is stuck on one channel. Only the power function works on the remote and only the On/Off function works on the TV. Any ideas??
Forced to factory default: press and hold [VOLUME ( - )] on the TV and press [MENU] on the remote 2 seconds. Exit: Unplug Power to reset.
If it does not help, the main board need to replace. For further questions, please add your comment.
May 20, 2010 | Panasonic Viera TH-42PX80U Plasma TV
I want to know the perfect color settings for the th-42px80u
The Settings are :-
-Picture menu Picture mode: Custom
Picture: +80
Brightness: +60
Color: +44
Tint: -8
Sharpness: 0
Color temp: Warm
Color management: On
x.v.Color: Off
Zoom adjust: [grayed out]
-Advanced picture submenu
Video NR: On
3D Y/C filter: [grayed out]
Color matrix: [grayed out]
MPEG NR: [grayed out]
Black level: Light
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 10, 2010 | Panasonic Viera TH-42PX80U Plasma TV
My panasonic viera 42 inch tv is getting in standby mode after 2 seconds. Little red light is blinking but tv immidiatelly after turning on goes off.
It sounds like the power supply is bad.Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Mar 05, 2010 | Panasonic Viera TH-42PX80U Plasma TV
How do I connect my Wii to my Panasonic plasma tv?
the wii leads are colour coded look for the colours on tv then switch tv into that input mode e.g ( common or EXT ) make sure wii is on
Nov 29, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Side bar covering information
all you have to do is just the size..Should be a rolvalution button on your remote.. 50 should be 19.9
Apr 29, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera TH-42PX80U Plasma TV Logo
739 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
